Blowing Fuses!
Discussion in 'Lighting' started by Dafinga, Jun 17, 2013.
  1. Jun 17, 2013 at 2:21 PM
    Dafinga
    Dafinga [OP] Member
    Pete
    N. Cali
    2011 TRD Double Cab
    ICON Coilovers, Camberg UCA, Custom Bumper,
    Hi Folks,
    I am running 2 sets of ADV monster 44's in my Brute Force bumper. One set is split and runs two amber LED's with the driving lights and the other set is wired to my factory fog light switch. The second set of LED 44's are straight fogs. I am running them to a OTRATTW switch. This set of LED's runs fine for a while and then after I turn them on and off maybe 5 times, the 7.5 amp fuse blows. these LED's are supposed to draw 1.8 amps. I have another OTRATTW switch that runs my lightbar and The wiring is identical. I am not sure where I should start my troubleshooting. I did rewire the lights last weekend to make sure there were no issues with loose wires.
    Thanks
  2. Jun 17, 2013 at 2:26 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Impossible to diagnose over the Internet but I'd use an ammeter in series with the lights in question and measure the current of the circuit. Most inexpensive multimeters can be configured as an ammeter and have 10A fuses, the better ones can measure up to 20A.
  3. Jun 17, 2013 at 5:12 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Sounds like a bad ground. Had the same problem wiring my aftermarket fogs, kept blowing the fuse. Found a better ground and no problems since.
  4. Jul 15, 2013 at 11:14 PM
    crooks420
    crooks420 Well-Known Member
    Jesse
    San Gabriel
    05 AC Prerunner SR5, 12 DC LB 4x4, 70 FJ40
    Can you tell me how you wired the fogs????
    I have a 2012, with factory fog lights. I want to add another set of fogs on my pre-runner light bar, wired to the factory fog light switch. So when I hit the fog switch, both my factory and aftermarket fog lights come on.
    Any help would be appreciated.
    jesse
