Blowing through fan resistors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ButteTacoma, Aug 20, 2018.
  1. Aug 20, 2018 at 4:29 PM
    ButteTacoma
    ButteTacoma [OP] New Member
    Brian
    06' Tacoma TRD
    None
    06' Tacoma. Zero modifcations 190k miles...
    Just this summer alone I've had to replace my fan resistor 3 times? now I need to do it again... any ideas what is causing this?
    george101 likes this.
  2. Aug 20, 2018 at 4:39 PM
    Muddinfun
    Muddinfun Well-Known Member
    Sounds like you're not replacing the resistor connector. You need to replace the resistor connector at the same time.
    Partzguy likes this.
  3. Aug 20, 2018 at 5:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Blower motor is drawing too much current. Replace it
    EasilyDistracted likes this.
  4. Aug 20, 2018 at 11:27 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Look at both connectors on the motor. I'd be willing to bet one or both of them are burned.
    Check the plug that goes to the resistor connection and the white plug that goes to the motor? If they have burn marks you need to replace the connector plugs.
    Part number 90980-10916 Connector
    Part Number 82998-12380 Wire and terminal
    Not sold as a kit, sold as each. So you will need one of the plugs and two of the terminal and wires.
    Connector:
    Terminals:
    You may also have a burned resistor connector and may need these:
    Plug Number 82141-04M40
    Resistor Number 87138-04052
  5. Sep 8, 2018 at 6:40 PM
    ButteTacoma
    Brian
    06' Tacoma TRD
    None
    Thanks everyone, it was infact a bad blower its self. ordered a new one along with a new resistor and connector
    EasilyDistracted and b_r_o like this.
  6. Sep 9, 2018 at 6:41 AM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    What's the part number for the blower?
