BlowingFuses
Discussion in 'Lighting' started by Sixfeathers, Mar 31, 2011.
  1. Mar 31, 2011 at 6:50 PM
    Sixfeathers
    Sixfeathers [OP] Well-Known Member
    Kreg
    Maryland
    2011 Access Cab
    Led lights: Replaced Bulbs in front,Fog Light modification, Westin Nerf Bars, TS mod,
    My truck has a bad habit of blowing two fuses consistantly.The first fuse is the Gages fuse, the second fuse that keeps blowing is the Turn signal . I am confused. I have replaced the fuses two times in the last past 3 hours. ANy help is welcome. Thanks.
    Kreg
  2. Mar 31, 2011 at 6:59 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You have a brand new truck and have listed some mods that include lighting.
    The first thing I would do is remove your mods and see if the problems go away. If not, take it to the dealer and request they repair under warranty. If so, figure out if the problem is aftermarket parts or poor installation. Repair as necessary.
    My experience with electrical problems on new vehicles has taught me that it is usually the last thing I changed. I have saved a lot of time since then. I no longer believe that I never make mistakes when doing mods.
  3. Mar 31, 2011 at 7:17 PM
    98tacoma27
    Ben
    Not Beech Creek
  4. Mar 31, 2011 at 7:17 PM
    Sixfeathers
    Kreg
    Maryland
    2011 Access Cab
    I removed the Daytime Running lights mod and it blew fuses when removed the wire. I relplaced the fuse and all is okay. Could it be a bad ground . I want my running light mod! I looked at wires and inspected all connections, they are clean. I have future plans on adding a new fuse panel so I might do it sooner than thought.
  5. Mar 31, 2011 at 8:30 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    check and see if two wires are hitting each other in a bare part of the wire
  6. Apr 1, 2011 at 5:19 AM
    Sixfeathers
    Kreg
    Maryland
    2011 Access Cab
    I will check that. Dang rain is putting a damper on things. It was dark yesterday so maybe I am not seeing a bad or stripped wire as you state. Thanks for the info.
  7. Apr 1, 2011 at 11:07 AM
    Sixfeathers
    Kreg
    Maryland
    2011 Access Cab
    I took it to the dealer and they replaced the pigtail in the right rear turn signal. Go figure. That is why I don't like wiring things. thanks for the suggestions and all. Now to go put my little jumper back on.
