blown 8 inch e-locker (2nd one blown on truck)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joshtaco08, Oct 2, 2017.
  1. Oct 3, 2017 at 4:09 PM
    #41
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I am starting to get a little grey but I found two of them.
  2. Oct 3, 2017 at 4:13 PM
    #42
    jowybyo
    Joe
    Baltimore, MD
    But they don't really have an equivalent for a similar price. Also, I'm not saying the 3rd generation axle is the answer. Just throwing it out there as an option over the 8.4
    TireFire and dtaco06[QUOTED] like this.
  3. Oct 3, 2017 at 4:14 PM
    #43
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Exactly, I was talking about affordable. Remember you still have to regear those, or th front diff or both. For that much dough I'd go Currie or something else that's tried and true.
    dtaco06[QUOTED] likes this.
  4. Oct 3, 2017 at 4:15 PM
    #44
    TireFire
    Olympic Peninsula
    Nothing is stronger than stock and nobody is better at setting up these diffs than those Japanese engineers
  5. Oct 3, 2017 at 4:19 PM
    #45
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    apples and oranges. ecgs is a build third, the one above is a full axle.
    hope you meant that as a joke lol. as one texans or mexicans setup the rear diffs lol
  6. Oct 3, 2017 at 4:22 PM
    #46
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Nitro gears suck balls
  7. Oct 3, 2017 at 4:29 PM
    #47
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    That's right!
  8. Oct 3, 2017 at 4:36 PM
    #48
    joshtaco08
    joshtaco08 [OP] Active Member
    Josh
    so most people think to go with the used 8.4 diff and axle housing and put detroit true trac in it? and if s do u no of if i do this of any check engine lights would come on or abs because those connections for the e locker won't be used anymore.. and do i need to upgrade the ring and pinion or they strong enough stock? and do u no if the axle shafts from the 8 inch r the same ones in the 8.4's. thanks!
  9. Oct 3, 2017 at 4:37 PM
    #49
    TireFire
    Olympic Peninsula
    To the contrary. Lower gears means less contact but equal power applied to a smaller surface so you know what that does. It will help your transmission tho which is the real expensive part
    Not kidding but I obviously wasn't lauding the new American made crap. New Tacomas look dope but nowhere near bulletproof anymore
  10. Oct 3, 2017 at 4:40 PM
    #50
    TireFire
    Olympic Peninsula
    Axle shafts are the same. No CEL and I suspect you don't need to worry about ABS because the locker simply turned the ABS off. But why not Detroit or ARB or harrop locker. True trac is only a LSD so not nearly as capable off-road
  11. Oct 3, 2017 at 4:52 PM
    #51
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Nope,they come in as a pre-assembled unit.
  12. Oct 3, 2017 at 5:06 PM
    #52
    paranoid56
    San Diego
    14 double cab taco
    last i checked they only sold built thirds. not a full axle.
  13. Oct 3, 2017 at 5:11 PM
    #53
    Monkeybutt2000
    Sorry,I meant at the factory the rears come in assembled.
  14. Oct 3, 2017 at 6:03 PM
    #54
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    Hell naw at $2k for a turd gen axle.
    Go big or go home, swap in a full floater e-locker axle from a 80 series land cruiser, 9.5 third member, disc brakes, and 4:10 gears. Gear the front to match.
    You should be able to get a complete axle for $600-$1k.
  15. Oct 3, 2017 at 6:39 PM
    #55
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    Don't they have an offset diff? Could open up a whole new world of drive line vibrations. Not to mention interference under flex.
  16. Oct 3, 2017 at 6:40 PM
    #56
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    he's gangster
  17. Oct 3, 2017 at 6:45 PM
    #57
    Toyoland66
    Colorado
    09 GX470
    Mostly stock on 35s
    They do, the swap has been done. Keep the flanges parallel and use regular u-joint driveshaft and it works. The offset is to the passenger side so no gas tank interference, Maybe exhaust?
  18. Oct 3, 2017 at 6:47 PM
    #58
    Toyoland66
    Colorado
    09 GX470
    Mostly stock on 35s
    If you wanna get real crazy just use the LC axle as a donor axle and get a ruffstuff or diamond housing, build it centered with custom shafts. Cut to length chromos are available.
  19. Oct 9, 2017 at 6:21 PM
    #59
    joshtaco08
    Josh
    bought an 8.4 housing and an 2008 8.4 diff from pre runner same gears and apparently from 2005-2008 pre runners had lsd diffs so now i got and 8.4 lsd diff in back. so worked out good seems like :) thanks for everyones input !
  20. Oct 9, 2017 at 6:55 PM
    #60
    TireFire
    Olympic Peninsula
    Pretty sure that's only a mechanical LSD until 2007. Post a pic of the diff you bought and I can tell you for sure
