blown diff-re gear...
Discussion in '1st Gen. Tacomas (1995-2004)' started by DIRT YOTA, May 16, 2011.
  1. May 16, 2011 at 2:24 AM
    DIRT YOTA
    DIRT YOTA [OP] Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    So here is what happened
    Here is how I got home :(
    So as u can see I'm gonna be basically regearing my rear diff......so might as well regear front and step up right...
    Main question is are 4.56 gonna be too much for a 03 dbl cab 4x4 auto 3.4l with 285s? It is a daily driver, but offroaded frequently. And in a year or so paid off and a toy/part time street driving. Any thoughts or links would be helpful. Searched a bit figure 4.56 will prlly be best. Also any gear company better than another, and why? Been recommended east coast gear supply. Thanks in advance and if you wanna hear it happen on page 9 of this link there is a vid/pictures
    http://www.tacomaworld.com/forum/southern-california/155777-sat-14th-rowher-trail-4x4-trail.html
  2. May 16, 2011 at 3:38 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    4.30 would be ideal for 285's but 4.56 is the closest you can get.
  3. May 16, 2011 at 7:08 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Well there is 4.29 too right, but I think 4.56 might b a lil better.
    Wanna try a keep it under 2k :D we shall see.....
  4. May 16, 2011 at 7:10 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    If you pull the diffs yourself, purchase the parts yourself, and just pay a shop labor to set up the diffs, you might be able to sneak in under 2k.
  5. May 16, 2011 at 9:33 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Well the rear is pulled :D
  6. May 16, 2011 at 9:38 PM
    bowhunter11199
    bowhunter11199 Well-Known Member
    dang man that sucks. if you dont mind me asking how did you do this?
  7. May 16, 2011 at 9:47 PM
    DIRT YOTA
    Cory
    Camarillo, CA
  8. May 16, 2011 at 10:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor 15x8 D Window Steelies 33" BFG KM2s Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Wow. What a horrible noise.
    FWIW: My buddy went with 4.88s. On 33s that gear ratio seems a bit too much. 4.56s would definitely be better 285/75s.
  9. May 17, 2011 at 1:19 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I was deciding between 4.56 and 4.88. In the end I went with 4.88. I'm running 33s if you are in orange county anytime I'll take you for a drive or let you test drive it and see if you like 4.88
    Right now I'm getting 16-17 mpg average with the 4.88
    Also another reason I chose ecgs rather than a local shop was ecgs has a 5 year warranty. And they were 200 bucks cheaper than what I got quoted for set up minus install.
  10. May 17, 2011 at 4:30 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    :eek: That noise! Looked like a good time up to that!
  11. May 17, 2011 at 5:22 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    If it was me I would decide on a gear ratio. Then ship (or take) the 3rd member reliable shop (maybe ECGS). I would definetely take this opportunity to add a front locker if you do regear the front diff.
    Once they ship them back to you I'll help you install them. Its pretty easy to remove/install but its much more difficult to rebuild the 3rd member.
