Blown engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Flipzilla21, Jul 6, 2018.
  1. Jul 6, 2018 at 10:03 AM
    Flipzilla21
    Flipzilla21 [OP] Member
    California
    06 xrunner
    I was just curious... I was quoted around 4k for a engine swap for my 06 X Runner. I was just curious is there a difference between the x runner engines and a regular taco V6 engine? Should I just get a used or refurbished engine? A few of my friends told me I should get a crate motor. Any input would be greatly appreciated.
  2. Jul 6, 2018 at 10:06 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    @Torspd
    Oil pan right?
    Besides the 2012+ having air injection
  3. Jul 6, 2018 at 10:07 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Depends on the price I guess, if you can find a low mileage used engine in a write off truck. (Rear ender frame damage for example) and hear it running I would go that route.
    A refurb 4.0 would be hella expensive.
  4. Jul 6, 2018 at 10:38 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Correct on both parts. Some xrunner owners have swapped to the PreRunner/4x4 oil pans. Just need to hammer the crossmember a little.
  5. Jul 6, 2018 at 12:12 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    How the hell did you blow a 4.0?
    thatguymichael and Alexely999 like this.
  6. Jul 6, 2018 at 12:27 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oil starvation is the easiest way, due to their shallow oil pans.
    inwood customs likes this.
  7. Jul 6, 2018 at 1:17 PM
    Sharpish
    Brian
    How do you starve it? Extreme angle climbs/descents?
    TXpro4X4 likes this.
  8. Jul 6, 2018 at 1:28 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    doubt thats happening in an x runner.
    More likely is sharp turns causing sloshing of oil in the pan. I know someone made a pan spacer for the X runners that added in a baffle so oil didnt slosh up the sides.
  9. Jul 6, 2018 at 1:47 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    @Coupe perhaps?
  10. Jul 6, 2018 at 2:21 PM
    inwood customs
    Dave
    yes thats Coupe
    BassAckwards[QUOTED] likes this.
  11. Jul 6, 2018 at 2:26 PM
    TRD 4.0
    TRD 4.0 Well-Known Member
    Jorge
    CA
    06 4x4
    Bilstein 5100, BFG KO2 265/70/17, BHLM, 4th gen 4runner SE 17s
    :anonymous:You might want to consider an GM LS swap
    Fuerte likes this.
  12. Jul 6, 2018 at 2:30 PM
    lynyrd3
    Bill
    East Central Upstate NY
  13. Jul 6, 2018 at 7:44 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
  14. Jul 6, 2018 at 9:26 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Find a low miles 2007-2009 FJ with VIN number starting with 'J'. Unlike ALL Tacoma's and the FJ's with VIN starting with '3' or '5', the 'J' VIN 1GR-FE were actually made in Japan. Best 1GR-FE's in my opinion.I run a 2009 'J' VIN. I did the swap myself, wasn't bad at all.
    How did you blow it anyway? Head gasket? Stuck injector diluting the oil with fuel?
    Be aware... don't forget to read the fine print on crate engines and LKQ, etc... They claim there is a warranty, but read the fine print on what you have to do to qualify for the warranty!
    Also, for crate engines, make God durn sure that when they rebuilt that engine they DID NOT mill down the surface of the heads! Timing will never be spot on! It will always have a slight retard which equals rough idle! The ONLY thing a machine shop should ever do on a 1GR-FE head is a valve job.
  15. Jul 6, 2018 at 9:34 PM
    Bishop84
    Bishop84 Well-Known Member
    It's true, the J vin FJ/4runners dont leak from the timing cover. But I see more timing chain stretch engines from the J vin trucks.
  16. Jul 6, 2018 at 9:49 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Poor maintenance maybe? Sludge build up? Broken damper? Never heard that, but thanks for the info! I didnt see any slack or scarring on gears so I think I'm good, will keep an eye on it though! Thanks!
  17. Jul 6, 2018 at 9:51 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Lol, I'm leaning towards lack of maintenance... ALOT of young girls drive FJ's and unless daddy does maintenance, it don't get done, lol!
