Blown engine!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Homer608, Oct 5, 2020.
  1. Oct 5, 2020 at 6:02 AM
    Homer608
    Homer608 [OP] New Member
    2002 tacoma prerunner
    I have a 2002 tacoma with a 2.7L engine, with 238,000 miles. The head gasket blew Friday. Is replacing the engine my best bet? What about the transmission, will it last? Help!
  2. Oct 5, 2020 at 6:07 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Sorry to hear that, welcome to TW sorry that’s what brings you here. I’m not too sure, I think I’ve seen other recent threads on here about remanufactured vs fining an old used engine in decent shape. I would lean towards finding a good replacement engine with decent mileage to swap for yours. If there’s no internal damage a head gasket replacement could also be a good route. I don’t have a 2.7, but I’m sure someone will chime in who does.
  3. Oct 5, 2020 at 6:08 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What kind of mechanical skills do you have? No issues keeping the transmission unless you can find one hooked up to an engine for cheap and it’s the same as your current one if it’s not already experiencing issues.
  4. Oct 5, 2020 at 6:08 AM
    Homer608
    Thanks, I keep hearing that it's not worth fixing, I need my truck!
    GQ7227, Taco critter and 96BlueTacos like this.
  5. Oct 5, 2020 at 6:15 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I mean do what’s in your budget - if it’s a mint truck and you can fix it comfortably within your budget go for it.
    If you can get a replacement engine out of a running low miles vehicle then go for it if it’s in your budget.
  6. Oct 5, 2020 at 6:21 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Rebuild or find a good head. New timing chain and water pump then drive that bitch
  7. Oct 5, 2020 at 6:29 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
  8. Oct 5, 2020 at 6:35 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    I agree, a lot of the calculation will be what your mechanical inclination is, your budget and of course your time and access to tools. If you have mechanic skills, finding a good head and going that route like @Steves104x4 suggested seems to be a good route for repairing.
    Taco critter likes this.
  9. Oct 5, 2020 at 7:05 AM
    Glamisman
    Glamisman Well-Known Member
    a quick search shows that a used 3RZ-FE JDM motor is apx $2k. I am not saying to use a JDM, there are others, it is just the first thing that comes to mind.
    Abeyancer, 96BlueTacos and Dalandser like this.
  10. Oct 5, 2020 at 7:14 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    I have the 2.7 in my 98 and I just recently went through this So here's a story for you...
    For reference my mechanical background is power equipment technician 1 and 2 cyl air cooled stuff nothing this major lol but I thought it's only 2 more cyl how bad can it be...
    My truck had 219k on it and cyl 3 had almost no compression. Took the head off and realized the head was cracked between the the 2 exhaust valves. I bought an aftermarket head assembly from APRauto out of CO. It's a chinesium casting but came complete with cams and valves already installed. I also realized the previous owner did a horrible head gasket job and permatexed the new gasket on, inadvertently filling the oil and coolant holes and starving the top end. Pulled the entire engine for a rebuild. Had to replace the front timing cover(with timing chain) and oil pump plus have all the cyl bored out larger. Between parts and machine shop costs (i did ALL the labor myself) im into rebuilding the engine with 3k. I figured since I went through all that effort I should rebuild the transmission as well bought the complete rebuild kit and tore into that myself. I wish I hadn't, the gears were fine, none of the bearings had any play and the synchros weren't chewed up. Plus with my inexperience I questioned my mechanical abilities when I got it all back together because 5th gear would pop back into N when a load was put onto it. Instead of tearing it back apart I took it to a transmission shop that said they would rebuild it and instead just bought a 3rd party rebuilt trans and swapped it into mine.. that was 2k to have someone else do what I could've done. I was pissed, but learned a lesson
    Looking back I should've bought a low mileage import motor from Japan, they're less expensive than my engine rebuild cost and due to strict laws in Japan, they have less than 100k KILOMETERS on them. That way I could've just done a swap and been good to go. If your trans is shifting fine just slap a new clutch kit into it (have your flywheel resurfaced) and reinstall.
    If you have very limited mechanical experience i know another member on here @Das it mang just paid (I think) 3k to have a professional do just a head gasket job, that included a new OEM head .. but he only has 142k on his 2.4L so it made perfect sense to only do the head work
    Currygoat, miamijime, Clucky and 3 others like this.
  11. Oct 5, 2020 at 7:23 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    At 238K, I would go with a reman engine, especially if you can get one <100K miles. Time, cost & complexity-wise, a swap is (IMO) easier than doing a head, especially if it's a "driveway & beer" job. If you're going to get it done by a pro, get his estimates, but I'd still lean toward a new-to-you engine even if it was a few dollars more.
    Abeyancer likes this.
  12. Oct 5, 2020 at 7:53 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    124k* :thumbsup: lol but yes 3k for oem hg, head and all the other goodies associated with changing em. If u don't have a hoist and the time/experience
    Abeyancer[QUOTED] likes this.
  13. Oct 5, 2020 at 8:00 AM
    Abeyancer
    Jimmie
    PNW
    Only 124k?!?! Shoulda taken it to Toyota and asked for warranty work:D
    Das it mang[QUOTED] likes this.
  14. Oct 5, 2020 at 8:05 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    who told you its not worth fixing, some 3rd or 2nd gen clown?
    JudoJohn, ToyotaDriver and otis24 like this.
  15. Oct 5, 2020 at 8:15 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Bought it from a dodge dealer too, done did me wrong haha. w.e tho at least i got 30k out of it before i had to replace
  16. Oct 5, 2020 at 9:01 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Reman engine for me woulda made the bill 500 dollars cheaper. but if youre already paying that much, 500 dollars is worth it for the safe train of thought. I bought once to cry once, all depends on ur situation
  17. Oct 5, 2020 at 9:05 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    If you can do the work your self its a lot cheaper to replace a hg than buy a new motor. But if you dont have the skills then might just be about the same price to buy a lower mileage motor and swap it.
    JudoJohn likes this.
  18. Oct 5, 2020 at 9:51 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Even if you pay a shop $5k (random highish dollar amount. No idea what actual cost is) to do all the work that’s still way less than buying a full replacement truck.
    Right?
  19. Oct 5, 2020 at 10:22 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    But if your truck is a rusty pos and / or has a number of other high dollar (at the mechanic, not diy) maintenance issues due, use that $5k towards something worth it.
    Remanned engine would be the absolute worst choice of the engine swap hierarchy here.
    1. Low miles engine out of a running vehicle.
    2. Low miles engine out of a well reviewed and rated salvage yard with warranty.
    3. JDM long block from a well reviewed and rated seller.
    4. Overpriced remanned from LCE, Yotashop or other Yota________ shop that's well reviewed and well rated with warranty
    5. Less expensive remanned engine from remanned engine shop which puts cheap pistons, seals, bearings, etc. in their engines rebuilt by under-qualified staff.
    CrustyTaco and otis24 like this.
  20. Oct 5, 2020 at 5:21 PM
    Mtb_mafioso
    Mtb_mafioso Well-Known Member
