Blown engine!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Homer608, Oct 5, 2020.
  1. Oct 5, 2020 at 5:21 PM
    Mtb_mafioso
    Mtb_mafioso Well-Known Member
  2. Oct 5, 2020 at 5:22 PM
    Mtb_mafioso
  3. Oct 5, 2020 at 5:25 PM
    Mtb_mafioso
    Same thing happened to me. I did the work myself and now my truck is solid. All in all I prob spent about $900 but I got;
    Head swap
    New
    Timing chain/ components
    New water pump
    All new gaskets
    New belts
    Thermostat
    Temp sensor
    It’s scary to think of the project as a whole. But if you break it up into smaller sections and keep yourself organized you’ll realize it’s not that terrible.
    JudoJohn likes this.
  4. Oct 5, 2020 at 5:28 PM
    Mtb_mafioso
  5. Oct 5, 2020 at 5:38 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Either head swap or used engine. Trucks worth fixing unless you really want to overpay for a new truck or adopt someone else’s problems
    Das it mang likes this.
  6. Oct 6, 2020 at 5:56 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    I feel for the OP. I'm in a similar boat, myself.
    My '95 3.4 has 135K miles. Perfect body and frame.
    I'm fairly certain my HG is blown. I need to replace the fuel injectors. And I have multiple oil leaks.
    And I cannot begin addressing any of these issue until I find a stock intake system.
    On the other side of the ledger, the TB/WP was done in the past 10K miles. New coils. All new fluids. New vac lines and a few other things.
    I pinged my trusted wrench who exclusively works on Land Cruisers, and he said to fix what I've got rather than messing with a reman engine.
    The cost for this work is going to be a good chunk of what it would take to just buy another truck.
  7. Oct 7, 2020 at 10:26 AM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    I say fix it. Unless the body/frame is rusted to hell. A leaking head gasket is no reason to replace the engine on a Taco. Should be able to have head machined and replace all gaskets and timing chain (although you could do it without the chain, it's just good insurance while you are there). If the head is cracked, get another one and put it all back together.
  8. Oct 7, 2020 at 10:31 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The time and money to swap out a head (since 50% of them are going to be cracked on these engines) is like 2/3 what it takes to swap a long block - not worth a hg for me.
    Abeyancer likes this.
