blown fuse and need help... no power windows, locks, or running/tail lights.
Discussion in 'Technical Chat' started by ballen12434, Jun 23, 2010.
  1. Jun 23, 2010 at 12:58 PM
    ballen12434
    ballen12434 [OP] New Member
    Georgia
    08 Prerunner
    last night i was at the store and when i released my park brake, i heard a spark. i noticed smoke comeing out from under the dash and i got out to see what it was and there was a wire melted out from under my dash. it was a wire i spliced in and it had a nick in it an shorted out on the park brake. it was getting power from the "tail" fuse under the dash. i checked the fuse and its fine. and i also went on and checked every fuse i could find and all are fine. but my power windows, power locks, and running lights do not work. anybody have any suggestions about what to check or do to fix this problem?? thanks.
  2. Jun 23, 2010 at 1:23 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Fuse # 1 and #2 in the engine compartment may be NFG. They're big, 50 amp ones and don't actually look like a regular fuse. There bigger, They supply power to the other fuse panel. It's actually probably fuse #1 it supplies most of the power for the other fuse box.
    If you have that many problems it's got to be those.
    There numbered left to right #3 #2 #1 and the last position is probably empty.
    Repeat after me...
    "TyRaps are your friend..."
