Blown fuse has caused problems
Discussion in '4th Gen. Tacomas (2024+)' started by rkm812, Dec 26, 2024.
  1. Dec 26, 2024 at 6:48 AM
    rkm812
    rkm812 [OP] Member
    2024 sr5
    I was hooking up a small trailer over the weekend and due to some faulty wiring on the trailer I blew a 30 amp fuse. I pulled most of the fuses looking for the bad one and in doing so I now don't have a heater, seat heaters, steering wheel heater and now I have to manually use the release trick to get it out of park. I have an appointment with Toyota but not until next week. Does anyone here have any suggestions?
  2. Dec 26, 2024 at 7:02 AM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    So you are pulling random fuses and not putting them back once you confirm they are good?
  3. Dec 26, 2024 at 7:18 AM
    rkm812
    rkm812 [OP] Member
    2024 sr5
    No, I checked each fuse and put them back where they came from. there was a blown 30 amp fuse in the passenger side fuse box that was bad.
  4. Dec 26, 2024 at 7:30 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Have you replaced the fuse and disconnected the battery for several minutes and reconnected?
  5. Dec 26, 2024 at 7:42 AM
    rkm812
    rkm812 [OP] Member
    2024 sr5
    Yes I did. After replacing the fuse I did disconnect the battery for 30 minutes. Nothing nothing was restored.
  6. Dec 26, 2024 at 7:51 AM
    Williston
    Williston Well-Known Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    You may have blown another fuse or relay in the process of removing and checking them, or the same/initially replaced fuse has blown again protecting the circuit. Replace the initially tripped fuse or relay with a confirmed equivalent good one removed from a working circuit. There may be another issue. At least check all of the currently dead circuits you lost. You may want to buy a few spares to troubleshoot with rather than cannibalize your current good ones and making the problem worse.
  7. Dec 26, 2024 at 7:52 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Forget your appt, just show up.......
    That's how its done...
  8. Dec 26, 2024 at 8:07 AM
    snickers
    Vehicle Interior Seat Heaters have 15 amp fuses each:
  9. Dec 26, 2024 at 8:35 AM
    rkm812
    rkm812 [OP] Member
    2024 sr5
  10. Dec 26, 2024 at 8:39 AM
    rkm812
    rkm812 [OP] Member
    2024 sr5
    That's good advise, although I have tried everything you had mentioned except for checking relays, I'm not sure how to do that. I bought a collection of random fuses yesterday which had a small fuse tester with them, made it much easier to test each fuse. They were all good, although I still don't have power to any of the heater related functions, along with the Park issue.
  11. Dec 26, 2024 at 8:40 AM
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    24 TRD Sport +.16 Mustang GT. 14 Street Glide
    Calling
    caribe makaira
  12. Dec 26, 2024 at 8:54 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Do you have more than one fuse box,I have a second gen and it has a fuse panel under the instrument cluster.
  13. Dec 26, 2024 at 9:07 AM
    Williston
    Removing and re-installing each relay may fix a contact/connection issue and bring things back to life. Also, try wiggling all of the connections and see if that wakes anything up. I see your truck is a 2024. Is it still under warranty? It's kind of early for any electrical glitches and having more than one circuit out is troubling this early on. My reason for suspicion being a relay or connection is the multiple failures you are reporting. I would also disconnect the negative battery post before doing any troubleshooting.
    rkm812[QUOTED][OP] likes this.
  14. Dec 26, 2024 at 2:55 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
  15. Dec 26, 2024 at 3:37 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Dealer ?
