blown fuse
Discussion in '1st Gen. Tacomas (1995-2004)' started by 17hmrtaco, Jul 3, 2010.
  1. Jul 3, 2010 at 10:35 AM
    17hmrtaco
    17hmrtaco [OP] Well-Known Member
    jake
    03 4wd 4door black
    rims,2.5 lift
    i keep blowing my driver side low beam light could someone help me plz and if anyone has had the same problem could u tell me how you fivex it thanks
  2. Jul 3, 2010 at 11:12 AM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Have you added anything to the wiring inside the cab or out ?
  3. Jul 3, 2010 at 10:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What temperature bulbs are burning out, are they stock replacements or are they xtra bright silverstars (or equivalent)?
    Normally, heat, vibration and touching the glass surface of the bulb are what shorten the life of halogen bulbs. Just the low beam...on just one side...more that once...in a short period of time, indicates a bigger problem.
    If you did not "handle" the bulbs when you put them in I would say there may be a wiring issue.
