Blown Head Gasket 19k
Discussion in '2nd Gen. Tacomas (2005-2015)' started by leochup, Dec 15, 2009.
  1. Dec 15, 2009 at 7:56 AM
    leochup
    leochup [OP] Well-Known Member
    Hi I’m new to these forums; I recently bought a 2006 access cab 4x4 6speed manual, speedway blue, TRD Sport.
    The car has a blown head gasket but I bought it $10k under retail value.
    My mechanic is telling me that I should replace the whole engine instead of just the gasket because of the labor involved in replacing the gasket is 23 hrs and then going in there and finding out that it has cracked block or heads will make the labor cost go up and still will leave me replacing the engine anyway.
    The car was always serviced a Toyota and have all the paperwork for it was diagnose with bad spark plugs and coils when it had 18,987miles but that only fix the problem temporarily and then went back to serv with 19,026 when they diagnose a Blown head gasket the car has exactly 19,050 on it do you guy think that driving the car for 63miles is enough time to blow a engine up?. The guy I purchased it from says that he never drove with the engine overheating and that it just felt like it would run out of power but the temp gouge was always fine.
    Can you please advice what you think I should do?
    Buy a used engine with low miles or go in there and try to replace head gasket?
    Thanks
  2. Dec 15, 2009 at 8:05 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Sounds kinda fishy to me. I would almost bet there was some negligence on the previous owners part.
    The mechanic does have a good point however I would still have him inspect it. Might as well pull the motor, pull of the head and inspect it and the block. If its bad, then you are going to have to pull the motor anyways to replace it. If its ok, it will be easier to work on the motor out of the truck anyways. The head will have to get sent off to a machine shop to be decked to ensure a good seal when it is reinstalled.
  3. Dec 15, 2009 at 8:05 AM
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
    ^ Talk about a major headache! For one if it was serviced at whatever Toyota dealership they didn't do their preventive maintenance to keep that young engine running strong. Secondly, I put a lot of blame on the previous owner as he should have know/felt/seen the problem and he let it go. Lastly, I would go to another dealer and get some estimates on the replacement/fix of your issue.
    P.S. How much did you actually buy it for? ($10k below book isn't a price)
  4. Dec 15, 2009 at 8:14 AM
    djs05tacoma
    djs05tacoma Well-Known Member
    Martinez, CA
    05 Double Cab TRD offroad 4x4
    3" OME Lift, 285's
    Where are you located? I saw on sacramento CL there was 4.0 a 6-speed together for sale for $2500 last week.
  5. Dec 15, 2009 at 8:17 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    isnt there a 5yr/60kmile powertrain warranty?
  6. Dec 15, 2009 at 8:21 AM
    Yoytoda
    Roland
    completely stock
    oh and it wont "blow" an engine to drive with a bad head gasket. just dont let it overheat, keep the water/antifreeze topped off. Where abouts are you located. Maybe he hydro locked it and blew the head gasket/ cracked the block.
  7. Dec 15, 2009 at 8:28 AM
    SUPMO72
    SUPMO72 Well-Known Member
    Cleveland Ohio
    09 MGM Reg 4x4 5spd
    OEM Fog Lights, Tailgate Lock, Color matched OEM Grill, GT seat covers, Undercover bed cover, OEM back up camera
    Pull the heads and check with a straight edge tool if the heads and block are warped if they are it got over heated. Also when you unlosen the head bolts if they come loose easy it got hot and may have pulled the threads from the block. I have also seen if it got really really hot when you pull the valve cover the middle of the cylinder head will be darker than the rest, they tend to bow in the middle. The 4.0l use a metal head gasket if its blown it got hot and something is warped, how bad you wont know till you pull it apart..
  8. Dec 15, 2009 at 8:47 AM
    leochup
    thanks for the fast replys, paid 14k for it here are the pic[​IMG]
  9. Dec 15, 2009 at 8:50 AM
    leochup
    I'm in Atlanta GA the only reason I don't want to put a used engine is because you really don't know what miles it has on it they always tell you these low miles and when you pop the valve cover you see there suldge built up, but i guess I really don't have a option, I'll keep my finger crossed and hope the head and block is not warped
  10. Dec 15, 2009 at 8:54 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Thats what I was thinking... Was it out of warranty?
  11. Dec 15, 2009 at 8:55 AM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    Where are you located? I have a 4.0L with 27K miles on it. I can do the install as well if you are located in WA. I've already done an engine swap on the Tacoma so I'm pretty familiar with it.
  12. Dec 15, 2009 at 8:58 AM
    leochup
    no it still has warranty but he said that the dealer won't cover it because it didn't have the Toyota antifreeze in it. the basic warranty expires 03/2010 and the it still has the powertrain warranty.
  13. Dec 15, 2009 at 9:01 AM
    all.on.black
    Auburn, WA
    Drain and refill with Toyota antifreeze and try another dealer.
  14. Dec 15, 2009 at 9:03 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    cant you just flush it real quick and fill it back up with the proper antifreeze then take it in?
  15. Dec 15, 2009 at 9:04 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I think I would have to call Toyota Corporate on that one and try to nicely ruffle a few feathers.
    If not, I don't know what would happen if you drain the rad, flush the system, and replace with the Toyota Super Long Life coolant and take it to another dealer?
    One thing is for sure though, with less than 20K miles and the coolant was already swapped out with non Toyota coolant, something must have went wrong.
    EDIT: I would flush and refill with Toyota coolant, visit another dealer and pretend you know nothing about the previous history because you just purchased it.
    I believe the non Toyota coolant factor is irrelevant because something must have went wrong FIRST to need the coolant topped up - OEM or not. Lets face reality, if something goes wrong while on a trip somewhere Toyota Coolant isn't available at every service station or auto parts store. The system has to be refilled with something to get you home.
  16. Dec 15, 2009 at 9:11 AM
    dorkman
    dorkman Well-Known Member
    Change the antifreeze back to Toyota, and take it to another dealer. They may track the dealer notes by the VIN but might be worth a shot.
    Who put in the wrong anti-freeze? Sounds like the guy who sold it to you is covering something up.
  17. Dec 15, 2009 at 9:14 AM
    leochup
    I guess I can try that, but I figured they would have record of all the work that has been done, because when pulled the toyota owner it gave me all this:
    Service History for VIN: 5TEUU42N06Z280081
    To sort by service date, click on Service Date header.
    12 Service Records found, displaying 1 to 10. 1 | 2 Service
    TypeService
    Date
    Service
    ProviderMileageRepair
    Order#Service
    Description By Dealer 07/24/09Chatham Parkway Toyota 19,026 0378772CHECK ENGINE LIGHT
    By Dealer 07/24/09Chatham Parkway Toyota 19,026 0378772ENGINE RUNS ROUGH
    By Dealer 07/24/09Chatham Parkway Toyota 19,026 0378772DEALER ACCESSORIES
    By Dealer 07/07/09Chatham Parkway Toyota 18,987 0378670CHECK ENGINE LIGHT
    By Dealer 07/07/09Chatham Parkway Toyota 18,987 0378670ENGINE RUNS ROUGH
    By Dealer 04/24/09Chatham Parkway Toyota 16,949 037133315K SVC FACT REC
    By Dealer 04/24/09Chatham Parkway Toyota 16,949 0371333CK ENG LEAKS FLUID
    By Dealer 08/15/08Chatham Parkway Toyota 11,301 034788010K SVC FACT REC
    By Dealer 01/23/08Chatham Parkway Toyota 5,901 03270405K SVC FACT REC
    By Dealer 11/07/07Chatham Parkway Toyota 3,179 0318967MT&BAL 1 TIRE
  18. Dec 15, 2009 at 9:15 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    My advice....
    pick up a used motor for around $1400-$1600 that is in good shape, drop that in, truck is up and running, your a happy camper.
    Then have the other motor inspected. if its good, sell it, if it needs major repair part it out, and recoup some of the cost from purchasing a new motor.
  19. Dec 15, 2009 at 9:19 AM
    leochup
    1 07/07/2009 CHECK ENGINE LIGHT CUSTOMER STATES CHECK ENGINE LIGHT ON ~|~VERIFIED CONCERN, FOUND PO300, PO301. RANDOM AND #1 CYLINDER MISFIRE. MOVED #1 COIL TO #3 CYLINDER AND MOVED ~|~#1 SPARK PLUG TO #5 CYLINDER. TEST DROVE WITH COMPUTER CONNECTED, NO MISFIRES. WHEN WE FIRST SWAPPED PLUG AND COIL RECEIVED MISFIRE IN #3 AND #5. SMOKE PRESENT COMING OUT OF TAILPIPE WHILE MISFIRE CODES PRESENT.
    INTERNAL (DEALER) PAY 2 07/07/2009 ENGINE RUNS ROUGH CUST STATES ENGINE RUNS ROUGH AND SEEMS LIKE HAS NO POWER ~|~ ~|~SEE JOB #1
    INTERNAL (DEALER) PAY JobDateOperationOperation DetailsPay Type1 07/24/2009 CHECK ENGINE LIGHT CUSTOMER STATES CHECK ENGINE LIGHT ON ~|~VEHICLE HAS BLOWN HEAD GASKET~|~VEHICLE HAS BLOWN HEAD GASKET
    NameQtyTRANSMITTER, TRAN1 INTERNAL (DEALER) PAY 2 07/24/2009 ENGINE RUNS ROUGH VEHICLE RUNNING ROUGH ~|~ ~|~VEH HAS BLOWN HEAD GASKET
    INTERNAL (DEALER) PAY 3 07/24/2009 DEALER ACCESSORIES SALES DEPT LOST KEYS DURING TRADE APPRAISAL ~|~CUT AND PROGRAMMED KEY BILL TO SALES ~|~HAD TO RESEED VEHCILE APPROVED BY WINSTON JR.
  20. Dec 15, 2009 at 9:37 AM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    There was a lot of good responses out there, but 23hr to pull the heads off?
    Never heard of such think. 23hr? cam-on.
    take care
    vbibi:(
