Blown Head Gasket/H G Replacement Thread
Discussion in '4 Cylinder' started by Murrfk, Mar 28, 2011.
  1. Sep 29, 2014 at 5:28 AM
    #41
    buellfire
    buellfire Member
    Shawn
    NKY
    2003 Tacoma dlx 2.7 4wd extra cab
    All stock
    I am going through this right now with my 2003. I sent the head out for a reconditioning. It was only 220 dollars and that way I know everything is right. They are doing the valve adjustment and all. A local machine shop is doing the work. I bought the fel pro gasket kit and new head bolts also. Hope to have it all back together this week. Hope this helps shawn
  2. Dec 27, 2015 at 8:20 PM
    #42
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Doing mine this week. Here is the toyota removal and install that I found online. Head gaskets are sure a lot of fun.
  3. Jan 24, 2016 at 12:01 PM
    #43
    peedeeyota
    peedeeyota Member
    Bryce
    Coastal SC
    00 Tacoma 4X4 2.7 5spd
    Don't mean to resurrect an old thread, but i will be replacing my head gasket and getting a valve job done soon. Would the manual in the post above apply to my 2000 2.7 Tacoma? except for the COP seeing as i have coil packs. Just want to make sure I have the proper info before starting. Thanks!
  4. Jan 25, 2016 at 3:55 PM
    #44
    MadTaco461
    CA
    Kinda stock
    Yes, that manual will work for all years, just do whatever spark setup you have. Time consuming, but went smooth.
  5. Feb 8, 2016 at 4:51 PM
    #45
    MWFrels
    MWFrels Active Member
    Richmond, Texas
    2022 White Access Cab SR 4-cyl
    None
    Glad I found this thread. Turns out the 2010 I just bought has a blown Head Gasket. I was puckering real bad when I saw how much factory manuals for these later models cost. Not particularly liking the idea of using a Chilton's either. Those two PDFs just relieved quite a bit of stress. Thanks MadTaco461! Now to start collecting necessary hardware.
    M
  6. Feb 8, 2016 at 8:13 PM
    #46
    MadTaco461
    CA
    Kinda stock
    For a 2nd gen motor you'll want to pick up a haynes manual or search around a bit more. This is for a 2rz or 3rz motor. Yours has vvti. Not that it is anymore difficult, but you have a few details to look for and maybe different torque specs. I thought I saw the fsm for 05 plus on here.
