Blown head gasket on my 06 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Webb158, Oct 2, 2015.
  1. Oct 2, 2015 at 8:14 PM
    Webb158
    Webb158 [OP] New Member
    Hi TW, I took my car in for a coolant leak that I though was somewhere on the exterior that i just couldn't find. The mechanic did a pressure test and everything checked out. I told him I had out a total of about 1.5 gals over the course of the month. He took another look and found that is was a blown head gasket that was drinking my coolant. He is a fairly reliable mechanic.
    So I will be attempting my first head gasket replacement here in the next couple weeks. I am reaching out to you guys for any wisdom, tips, tricks, that you guys could provide as I'm fairly young and inexperienced. I'm 24 and all mechanical experience i have has been on a 87 Suzuki Samurai and dirt bikes.
    I have a 06 Tacoma TRD sport, 4WD, 4 door, long bed.
    I would love any feedback, Thanks!!!
    -Joe
  2. Oct 2, 2015 at 8:49 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    first things first, set up your work area and thing about putting your parts down line in chronological order so when you reassemble you simply pick parts in the other direction. After that parts orders and proper tools. Maybe a manual, if things get you nervous its nice to find answers. Slow and Smooth. After draing the coolant and dropping the oil.
    Clean the Head real good and inspect very carefully for cracks. A machine shop can magnaflux it for you to.Clean faces perfectly and rub 5w-30 oil on both face before you install the gasket.
    put the head bolts back in lightly then torque them per specs and by pattern. Its a cake walk from then on out
  3. Oct 2, 2015 at 10:14 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Search for member named foampile. He is a novice who kept asking basic questions but was still able to do the headgasket job himself
  4. Oct 2, 2015 at 10:18 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    Haines repair manual is great tool as well to guide you along while working :thumbsup:
  5. Oct 3, 2015 at 5:20 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    What Leggo said ^
  6. Oct 3, 2015 at 5:53 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    You said you are 24 years old, so by definition, you have a smart phone. Use it to take pictures of every step and search the internet for more information. Take advantage of all the suggestions in this thread and what will inevitably come along.
    I tore down a Yamaha motorcycle engine to parts and got it back together by a parts lay out on the bench before digital photography and internet help using a thing made from paper with writing and pictures in it. Someone told me it was called a book or manual or something like that :rofl: You have a lot more resources to go with now.
    Tear in and have fun.
  7. Oct 3, 2015 at 6:12 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    How many miles do you have on it?
    Haines manuals suck. I have one and found more than a few inconsistencies. I would never trust one for any big job. It's not just the tacoma manual that has wrong information either. I have one for my civic also and it has wrong information.
    Someone did a good write up here on a head gasket change not long ago.
    You may want to look into alldata for a short subscription.
  8. Oct 3, 2015 at 6:36 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    DoorDing, Drivesector and beeftaco05 like this.
  9. Oct 3, 2015 at 12:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    www.cometic.com
    You also need a special socket to remove the head bolts. Throw them away. Get new ones or get ARP studs.
  10. Oct 3, 2015 at 4:05 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Don't search anything with Foampile in it, you want your truck to run again. Follow the link landphil gave you, it's all there. Take your time, don't cut corners.
    DoorDing likes this.
  11. Oct 3, 2015 at 4:39 PM
    Kbel
    Kbel Well-Known Member
    Kevin
    Fort Worth
    2018 MGM DCLB
    A smartphone, manual, sharpie, and zip lock bags to keep hardware separate. Mark the bags with a sharpie for what component they go to. Keep organized. Good luck. You got this!
    If you need special tools, ie torque wrench, usually the big auto part stores have a loaner program.
  12. Oct 3, 2015 at 5:12 PM
    wrangler2155
    wrangler2155 Member
    2006 Taco DCSB 6spd
    I would be checking to make sure 100% that it is indeed the headgasket that is leaking , there was a taco we had in the shop not too long ago that had a coolant leak on the pass side that looked like it was coming from the headgasket , but was indeed just a freeze plug of some sort , i dont recall the exact details of said freeze plug but i guess the guy had a block heater removed and they did a poor job resealing it. just food for thought , been working on toyotas for 10 yrs and have yet to see a tacoma with a headgasket leak.
  13. Oct 5, 2015 at 10:19 AM
    Hans Moleman
    Bay Area, CA
    I thought Foampile put his engine back together because it has been quite a while. Did he screw it up bad?
  14. Oct 5, 2015 at 10:49 AM
    Drivesector
    TRD sport
    Nah, it was still apart, he was contemplating using all the bolts for his timing chain cover or leaving 2 out because of striped holes. Also contemplating using all the O-rings or whatever on his fuel injection. He hasn't posted anything because i believe he was banned for a while for getting into a pissing match with just about all of Tacoma world because he is smarter than everybody.
  15. Oct 5, 2015 at 10:54 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    wouldnt a compression check indicate a blown head gasket? the mechanic came back with a good test showing everything was tight?
    i'm no pro. just trying to learn.
  16. Oct 5, 2015 at 11:08 AM
    jedirye
    jedirye Wannabe
    Florida
    2013 Baja Supercharged
    That made me lol. But it's a great idea. I will use that for future application!!
  17. Oct 5, 2015 at 11:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Hydro carbon test is a very good one.
    Continuous bubbles in the overflow tank. Gas pulsing out of the radiator, when the cap is off.
  18. Oct 5, 2015 at 12:01 PM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Head Gaskets going out on Tacos is very common, and not the easiest job. They updated the gaskets on either 07's or 08's, i never got a for sure there. I did mine with the help of my friend who's a professional. There's a lot of threads on this...
    There's a known issue of the timing chain cover leaking oil on the passenger side, where the power steering pump attaches. be aware of this and add extra gasket maker in that area upon reassembly. Also take your heads to a machine shop and have them pressure tested, milled and cleaned. make sure you put the head components in the same spots they came apart, they wear in a certain way and cannot be put in different places.
    Be 100% sure you got the timing chain on right, so the timing is set correctly.
    Above all, dont rush the job because if you do it wrong youll be really pissed later. And have wasted a lot of time and money.
  19. Oct 5, 2015 at 1:20 PM
    smd3
    smd3 Well-Known Member
    It almost seems like clockwork around 150k, doesn't it? That's just from what I recall seeing for posts on here. I hope you're right about the updated part!
  20. Oct 6, 2015 at 6:21 AM
    ranger098
    Brian
    Minnesota
    Ya i bought mine with 220k on it but there is a record of my truck going in the shop with a related issue at 170k, so 150k isnt too far off.... I surely got a good price on my 05 but knowing what i know now id probably only look for an 08 or newer cuz theyre pretty much issue free...
