Blown head gasket repair IN A BOTTLE...
Discussion in 'Product Reviews' started by daregirl2, May 5, 2019.
  1. May 5, 2019 at 11:07 AM
    daregirl2
    daregirl2 [OP] dare girl2
    Paulette
    Sacramento
    97 Toyota Tacoma
    None
    This sounds too good to be true so therefore it most likely is.
    I have to ask anyways.
    I’m fairly certain I’ve blown a head gasket. Symptoms are Rough idle, fluid loss but not visable, moisture coming from exhaust, little bit of white smoke coming from exhaust pipe.
    I know what ultimately has to be done to repair this problem correctly. I just can’t afford it right now.
    My question is : are there any “head gasket repair “ in a bottle that actually work ? I’ve read several different website reviews.
    I’d just like to hear some opinions from some of my fellow Tacoma owners. And if there are some that actually work who makes them ?
    Thank you in advance,
    Daregirl2
  2. May 7, 2019 at 7:49 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I don’t have any first hand experience with that stuff but as far as I know that it’s all crap. If you have a blown head gasket the only way to resolve it is a new head gasket. I have never heard of anyone successfully using similar products.
    wilcam47 likes this.
  3. May 9, 2019 at 12:53 PM
    daregirl2
    Paulette
    Sacramento
    97 Toyota Tacoma
    None
    Thanx for taking th time to reply. Have a good day!
  4. May 9, 2019 at 1:11 PM
    eon_blue
    Azusa, CA
    That stuff does "work" in the sense that it's a major short term band-aid and long term might cause more problems than it resolves, so I've heard.
    Of course it won't 'fix' the blown head gasket but it's supposed to prevent the leaking from it, but mixing stuff with your coolant in general is not a good idea and the only real way to fix a head gasket is to get it replaced.
    I would only use that stuff if it was necessary to get me however many miles home or to a shop where I could get it properly fixed.
  5. May 9, 2019 at 1:15 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    It will work, and ruin your motor and cooling system. Do the job right and replace the head gaskets on both sides if a V6 and get a valve job done also. Motor will run for many more years. Good luck.
  6. May 11, 2019 at 9:25 AM
    daregirl2
    Paulette
    Sacramento
    97 Toyota Tacoma
    None
    Thank you for taking the time to respond. That’s pretty much what I figured, but wanted to ask anyways.
    I was afraid it would clog my radiator. Do you think not having a fan shroud put back in when radiator was changed, also the heater core being bypassed may have lent a hand to the blowing of the head gasket?
  7. May 11, 2019 at 9:31 AM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    Probably, without a shroud the fan is doing nothing
    Mully likes this.
  8. May 11, 2019 at 9:35 AM
    daregirl2
    Paulette
    Sacramento
    97 Toyota Tacoma
    None
    Thanx! Have a good day!
    mynewtoy likes this.
  9. May 11, 2019 at 9:47 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    head gasket is usually due to it getting rusted out or failure of the gasket. The bottle stuff is only going to clog your radiator or heater core. If your fan shroud isnt on it just wont pull air as effectively. Best to change your timing chain and water pump while its taken apart that far.
  10. May 11, 2019 at 9:08 PM
    eon_blue
    Azusa, CA
    If someone worked on your truck recently and didn't install the fan shroud, they should be held liable for the blown head gasket
  11. May 11, 2019 at 9:10 PM
    BlackGT99
    BlackGT99 Well-Known Member
    Noel
    2019 VooDoo Blue Tacoma TRD Pro
    ^not
    Hobbs and wilcam47 like this.
  12. May 11, 2019 at 9:17 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    I don't know if you could hold them liable.
    But if a fan doesn't have a shroud it's not pulling any air through the radiator, It's just moving air around in the engine bay.
    even the fan depth in the shroud matters. to deep or to shallow and it's not pulling the right amount of air
  13. May 11, 2019 at 9:22 PM
    eon_blue
    Azusa, CA
    I just mean it's hard to not to hold them accountable for it, if that's the case anyway.
    Brilliant argument
    mynewtoy[QUOTED] likes this.
  14. May 11, 2019 at 9:24 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    I just got the vibe that it was a friend or something that did the repair not a shop
    eon_blue[QUOTED] likes this.
  15. May 11, 2019 at 9:25 PM
    eon_blue
    Azusa, CA
    been there done that, got the t-shirt. Except it was my wife's car I messed up, in some ways being held liable for something like that is worse than being a shop and being held liable haha
  16. May 11, 2019 at 9:43 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    All these replies are correct, so save your money. and it is unlikely a missing fan shroud was related to a blown head gasket. Also many many years ago I had a blown head gasket on a different truck and had nowhere near the funds to cover it, so I asked the boss for an advance, Paid it off over time, --problem solved.
  17. May 11, 2019 at 9:46 PM
    Bishop84
    Bishop84 Well-Known Member
    I have never seen it solve any problems. Only create problems, or worsen them.
    Crodell6 likes this.
  18. May 11, 2019 at 9:56 PM
    michael roberts
    san diego
    07,4x4, white, AC.
    "Head gasket repair in a bottle" reminds me of the "Engine rebuilding pellets" they used to sell in the old J.C. Whitney catalogues.
    Rottencotton likes this.
