Blown Head Gasket. Sell or Fix?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacNewbLoyalist, Nov 16, 2024.
  1. Nov 16, 2024 at 5:34 AM
    TacNewbLoyalist
    TacNewbLoyalist [OP] Member
    2015 Tacoma Utility Package
    ** new development: mechanic is offering me $5000 for my truck. Do I just take it and run?
    This is my second Tacoma. My first was a 2003 prerunner. I love my trucks! Unfortunately, my current truck has a blown head gasket and a rattling sound when the engine starts and the weather is cold. The mechanic quoted $3600 to fix the HG AND replace the timing belt, pulleys, chains, spark plugs. This is my work truck for my dog walking business and it has 146K miles on it. So I’m hoping it has more life to give?
    Do I pay to fix it in the hopes of not having to do much else ever again? Or see if a mechanic will take it off my hands for a low price?
  2. Nov 16, 2024 at 5:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    Get a couple more prices from reputable independents first
    Just to make sure youve got best options in hand
  3. Nov 16, 2024 at 5:42 AM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    The "rattling sound" is probably a loose heat shield around the cat on the driver's side. There are threads here on how to fix this with a hose clamp.
  4. Nov 16, 2024 at 12:05 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    $3600 to repair or 40k +\- for a new truck. Easy decision for me. Did you over heat it? The 2015 isn’t known for needing HG at 150k. I’m assuming this is the 4.0.
    Ricardo13x and oldtimertoyota like this.
  5. Nov 16, 2024 at 3:54 PM
    Taco'09
    Taco'09 Well-Known Member
    OP if you did overheat it, do you suppose you could post some details?
  6. Nov 16, 2024 at 3:59 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    I’m pretty sure all 2nd gen’s run a timing chain
    fatfurious2 likes this.
  7. Nov 16, 2024 at 4:03 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Is the coolant in the overflow bottle clean or dirty? I’m not feeling a HG.
    Ricardo13x likes this.
  8. Nov 16, 2024 at 4:05 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Fix it, but get another opinion and estimate. Finding a low mileage engine from a scrapyard and just swapping is an option I'd look at even if it costs more. If the head gasket is gone this early I suspect other damage.
  9. Nov 17, 2024 at 2:45 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I would get a valve clatter first thing in the morning (cold engine) if I gave it more then mild acceleration for the first few min. Truck felt a little tired too, 150K mi/4L. I did a crankcase flush with seafoam for 300mi and the valve clatter went away before i even dumped the oil with the flush in it. Incidentally the truck no longer feels tired, it's peppier in the midrange, easily felt pulling away from a traffic light. I'm pretty sure the flush helped the VVT system. To me it makes sense since the system is susceptible to contamination from the oil. Better verify, pretty sure all the second gens use a timing chain and no timing belts. You may be referring to the serpentine, good idea to get one with the new pulleys. If he is mentioning replacing the timing chain there's lots of tacomas with timing chains with 250K mi on them. They aren't a common replacement item like a belt would be. Pullies, serp belt and HG would be all I'd suggest and flush the crankcase.
  10. Nov 17, 2024 at 3:03 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    Side bar, I just bought a ford ranger with a bad head gasket. If you’re mechanically inclined and don’t mind taking your time it’s a job you can tackle at home. Especially if you have a 4 cyl (can’t remember what you said you had).
    my second gen had 253k miles when it got totaled, as much of a first gen fanboy I may be I have to give 2nd gen props for reliability. No one can ever make guarantees but if you do fix it you should be relative my problem free…also what’s the truck doing?
    if you’re in NC I have a pretty decent tool collection including cooling system pressure testers and block leak kit, I’d be more than happy to help you look at it
  11. Nov 17, 2024 at 3:04 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    This
  12. Nov 17, 2024 at 4:05 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    It does not have a timing belt. It has a chain and odds are the chain is fine . I would get another quote . Also 150 k on a second Gen is nothing , whether it’s a 4 cylinder or 6 cylinder . If the rest of the truck is in good shape fix it . The then if down the road you want to sell it go for it . But running well you will get great money for it . But definitely get another quote
  13. Nov 18, 2024 at 7:39 AM
    TacNewbLoyalist
  14. Nov 18, 2024 at 7:44 AM
    TacNewbLoyalist
    Yes it’s a 4-cylinder. here’s the mechanic’s diagnostic/estimate
    Estimate Date : 11/15/2024 2015 Toyota - Tacoma - 2.7L, In-Line4 (164CI) VIN(X)
    CUSTOMER STATES: ABNORMAL NOISE WHEN COLD STARTINGTHE VEHICLE/MISFIRE FOR A LITTLE AND CHECK ENGINE LIGHT ON.
    Diagnostic: FOUND COOLANT AND OIL MIXTURE IN OIL CAP DUE TO HEAD GASKET FAILURE (OIL AND COOLANT MIXING). IN ADDITION, MISFIRE OCCURRING DUE TO COMPRESSION LEAK IN CYLINDERS. RECOMMENDED CYLINDER HEAD REPAIR WITH REPLACEMENT OF TIMING CHAIN KIT.
    CYLINDER HEAD ESTIMATE:
    $159.99 CYLINDER HEAD GASKET
    $680.00 WATER PUMP/SP PLUGS/THERMOSTAT/TIMING CHAIN KIT/
    COOLANT/ENGINE OIL/BELT
    $2,700.00 LABOR
    $81.89 TAX
    $3,621.88 GRAND TOTAL
    013170
    120.00
    Parts/Supplies: 0.00
    $ 120.00
  15. Nov 18, 2024 at 7:55 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Get a second opinion.
  16. Nov 18, 2024 at 8:07 AM
    TacNewbLoyalist
    I should also add I bought this truck used at 109K miles on it with routine maintenance. It was a fleet vehicle for Orkin so who knows how the previous driver handled it. The 40K miles I’ve put on it have been mainly city miles and going up and down steep hills for dog pick ups. Still confused as to what could cause a HG repair this early on
  17. Nov 18, 2024 at 8:10 AM
    lynlan1819
    Tacoma
    Lifted
    Never trust just one repair shop,I don't care how friendly they are,get a second or even a third opinion before deciding what too do.
    TacNewbLoyalist[OP] likes this.
  18. Nov 18, 2024 at 8:22 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    Why is he putting in a timing chain, just because? I can see throwing in the waterpump to head off a future repair but the timing chain, not unless there's a compelling reason IRT the chain's condition which would be weird. Nothing about a head gasket failure puts the timing chain at risk, but if the OP is planning on a 300K lifespan....maybe.
  19. Nov 18, 2024 at 8:57 AM
    TacNewbLoyalist
    He said bc Toyota recommends it at 100K miles and they’ll already be working on the engine that installing a chain kit would just be paying for the parts. If I were to need spark plugs, chain kit, etc. in the future it would cost similar time in labor. $680 for the chain kit.
  20. Nov 18, 2024 at 11:38 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Clean the cap and drive it for a few days to see if it returns.
    condensation gets in the cap on colder days when not doing long rides.
    Did they do a leak down test or a compression test?
