blown head gasket
Discussion in '1st Gen. Tacomas (1995-2004)' started by usmrocks, Nov 24, 2009.
  1. Nov 24, 2009 at 2:34 PM
    usmrocks
    usmrocks [OP] Well-Known Member
    Daniel
    mississippi
    96 tacoma 4wd
    just like she came in 1996
    how much too fix?
    probably gunna sell the truck after this.
    i'm gettin sick of it
  2. Nov 30, 2009 at 2:09 PM
    usmrocks
    Daniel
    mississippi
    96 tacoma 4wd
    thanks for all the replies
    mechanic said engine was no good, 2200 to replace it
  3. Nov 30, 2009 at 2:16 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    Dont let the mechanic screw you, if all you did was blow a head gasket I wouldn't replace the whole engine. Get a high quality head gasket and torque wrench and have the head pressure tested for warp. If most you may have to replace the head... Not 2200 bucks.
  4. Nov 30, 2009 at 2:34 PM
    usmrocks
    Daniel
    mississippi
    96 tacoma 4wd
    So how much is the most it should cost?
  5. Nov 30, 2009 at 2:40 PM
    Firefighter160
    Josh
    Eastern VA
    05 DCSB Offroad
    For a good head gasket maybe $105, $25 fo change the oil, and $150 or so to pressure test it depending on the machine shop....
  6. Nov 30, 2009 at 3:16 PM
    usmrocks
    Daniel
    mississippi
    96 tacoma 4wd
    ok thanks, i'll look into it.
    any difference in head gasket brands?
  7. Nov 30, 2009 at 3:21 PM
    Firefighter160
    Josh
    Eastern VA
    05 DCSB Offroad
    Go for a toyota replacement or fel-pro...
  8. Dec 1, 2009 at 1:52 PM
    usmrocks
    Daniel
    mississippi
    96 tacoma 4wd
    apparently there is knocking that goes with this smoke. they are telling me i'll need a replacement engine possibly. they have one with 87000 miles and will put it in and everything for 2200
  9. Dec 1, 2009 at 3:12 PM
    Firefighter160
    Josh
    Eastern VA
    05 DCSB Offroad
    Oh if its knocking you may have a serious bottem end problem, 2200 still seems too high for a used engine replacement though... I would definetly check other places.....
  10. Dec 1, 2009 at 5:55 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    idk if its 2200 out the door engine and all sounds alright to me
  11. Dec 1, 2009 at 7:05 PM
    usmrocks
    Daniel
    mississippi
    96 tacoma 4wd
    well i misunderstood my dad, he told me 2100 for everything out the door, they also said it could be less but no more than that.
    they are working on a 2002 that threw a rod, wish i could've gotten the engine with 17000 they are putting in it haha
