Blown Head
Discussion in '1st Gen. Tacomas (1995-2004)' started by NicNac22, Jul 20, 2011.
  1. Jul 20, 2011 at 7:50 AM
    NicNac22
    NicNac22 [OP] D.I.L.L.I.G.A.F
    Nic
    Wild and Wonderful
    95 V6 4x4 ex cab SR5 5sp PICKUP!!!
    fun stuff coming soon! New battery, radiator and CV joints and axles. Added some Rancho RS5000 shocks.
    How much would it be to replace a blown head in a 91?
  2. Jul 20, 2011 at 8:12 AM
    ERIC
    ERIC Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
    try checking with local shops. where you live will vary the price.
  3. Jul 20, 2011 at 8:15 AM
    YFZ_TRD
    YFZ_TRD 4Runner Pilot
    Lee
    Beaverton, OR
    2014 4Runner SR5
    You should provide a little more info. What engine, any other issues, etc. I could give you a ballpark if I knew what engine.
  4. Jul 20, 2011 at 8:15 AM
    NicNac22
    Nic
    Wild and Wonderful
    well im debating on diy. my grandfather has all the tools plus a shop at his house. and its not mine, its for sale, hes asking 600
  5. Jul 20, 2011 at 8:17 AM
    NicNac22
    Nic
    Wild and Wonderful
    i dunno what engine, i know that makes a diff, my guess would be just the 4 cyl. i have to wait for my break to be able to call the guy and ask him about it, so when i learn more info ill post it
  6. Jul 20, 2011 at 8:22 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    What led you to the head being blown?
  7. Jul 20, 2011 at 8:24 AM
    YFZ_TRD
    Lee
    Beaverton, OR
    2014 4Runner SR5
    I picked up an 87 with the 22RE 4 Cylinder. Got quotes of around $400 just to have the head surfaced and the head gasket replaced.
    But since the engine already had 245K on it and was 24 years old, I went ahead and bought a whole new long block for $1800. The truck has a whole new lease on life and the engine has a warranty on it so that if something else goes wrong its not coming out of my wallet.
    Age I'm sure. If the coolant isn't changed often enough the metal starts wearing away. Or overheating, but that's not as likely.
  8. Jul 20, 2011 at 8:26 AM
    YFZ_TRD
    Lee
    Beaverton, OR
    2014 4Runner SR5
    Also, don't DIY a head gasket job if you haven't done it before. That will more than likely open a can of worms.
  9. Jul 20, 2011 at 8:29 AM
    NicNac22
    Nic
    Wild and Wonderful
    haha ok, ill take your advice then cuz i havent done it, unless i can call my bro up here, he used to work on semi's and his cars all the time. it says in the add thats its blown, but i dunno what else is wrong with it, cuz im assuming it wont start with that.
  10. Jul 20, 2011 at 8:30 AM
    magnew
    magnew Well-Known Member
    Ft. Collins, CO
    TRD
    I had a 1991 V6, they were known to have bad head gaskets, well the engine went bad. I contacted my toyota dealer and I received a new engine from toyota. That was 10 years ago but if its a toyota recall its worth checkin into. I also bought the vehicle used with 110,000 on it already.
    Good luck
  11. Jul 20, 2011 at 8:32 AM
    NicNac22
    Nic
    Wild and Wonderful
    dont you have to own the vehicle for a certain period of time to eligable for recalls?
  12. Jul 20, 2011 at 8:34 AM
    YFZ_TRD
    Lee
    Beaverton, OR
    2014 4Runner SR5
    If you can get help from someone who knows their stuff, do it. No better way to learn. The 22RE is super easy to work on. But its still an engine that needs to be assembled carefully.
    If it's the 3.0 V6. I would say pass. My buddy who rebuilt his 3.0 says he still doesn't trust the damn thing.
  13. Jul 20, 2011 at 8:39 AM
    NicNac22
    Nic
    Wild and Wonderful
    thats kinda what i was thinking if its the v6 ill leave it to the pros, ill have $ left over for it, but if im able to do it myself i would love to learn. the only mechanical work ive done was a tranny swap on my 92 xploder
  14. Jul 20, 2011 at 8:42 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Barring a bad gasket, something causes it. Bad clutch fan, clogged radiator, low coolant, bad thermostat causes overheating and warped parts. Hydrolock can warp a head too, but more parts get damaged with that.
    Make sure you investigate the cause before blaming the gasket. Mechanical failures and operator error are more common than bad gaskets.
    Cover your ass before sinking money into the head. Have the engine inspected for cracks(dye penetrant), pressure test the radiator, replace the thermostat and clutch fan(if original).
    If it were my truck, I would rebuild the engine. Why only do the head on a suspect engine. To test it, you need to tear it down. Why not replace the wear items while you're in there, IMHO:)
  15. Jul 20, 2011 at 8:46 AM
    YFZ_TRD
    Lee
    Beaverton, OR
    2014 4Runner SR5
    I agree, you definitely need to find out what caused it. Or if the truck itself is worth the $600, just accept the fact you need to rebuild the entire engine or buy a new long block.
    My 1st gen 4Runner with the blown 22RE was $1400. The truck itself, even without an engine, was worth $1400 to me. The paint was beautiful, interior was in great shape, minimal rust, every electronic piece worked. So, I just accepted the fact I would be putting a new motor in it.
  16. Jul 20, 2011 at 8:49 AM
    NicNac22
    Nic
    Wild and Wonderful
    wow your goin over my head there. i have no idea about any of that or what to look for and like i said its not mine, this is just what the guy claims is wrong with it. so its sounding like your saying just replace the whole thing, and that should be about a grand or so im guessing? unless i have to pay someone to do it? which it would be more then of course. its sounding like i dont want to get into this. i dont want to go broke over it.
  17. Jul 20, 2011 at 10:49 AM
    YFZ_TRD
    Lee
    Beaverton, OR
    2014 4Runner SR5
    Yeah, not likely that it will work out in your favor financially. Could be a good project, but I wouldn't plan on it being a DD real quick.
  18. Jul 20, 2011 at 3:11 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Figure 12-24 hrs of work to remove and install engines. It depends on your skill level and tools.
    Unfortunately, engine problems are a good sign of user neglect. Since you can't test the rest of the truck, I'd pass.
  19. Jul 20, 2011 at 3:14 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    is it the 3.0?
    blown head or gasket?
  20. Jul 20, 2011 at 3:21 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I laughed when I read that...:laugh::laugh::laugh:
