Blown Horn fuse - happened twice now
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Black07Taco, Mar 17, 2011.
  1. Mar 17, 2011 at 10:18 AM
    Black07Taco
    Black07Taco [OP] Member
    Washington
    07 Access Cab 4x4
    I've had my Tacoma (2007, 4 cyl) for about 4 months and the horn fuse has blown twice.
    Anyone have any ideas on what the issue is here??
    Thanks!
  2. Mar 17, 2011 at 10:27 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    Are the horns still in stock location? If not they may not be grounded properly.
  3. Mar 17, 2011 at 10:38 AM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    PreRunner SR5 TRD Sport
    Bull bar, wet suit seat covers, Accessory meter repair, Fog Lights with stick on, console lock.
    Bare wire touching metal between the horn and the fuse.
  4. Mar 17, 2011 at 10:41 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Solution: Quit blowing your own horn.
    Hmm, that wasn't helpful now was it?:D
    ^ What they said.
  5. Mar 17, 2011 at 1:24 PM
    Black07Taco
    Washington
    07 Access Cab 4x4
    Dark Knight - As far as I know the horns are in the stock location - I haven't move them. I will look into this to double check prior owner didn't do any mod.
    LGE - good thought. I'll look for that
    Moose - ha
  6. Mar 18, 2011 at 8:52 PM
    LGE RAW
    Rob
    Dothan
    If you have a multimeter, or a test light, you can unplug the horn and test the circuit back to the horn relay. With a multimeter, you can check the resistance between the horn wire and ground. It should be very high, if not an open. With a test light, connect the lead to the battery and the test light to the horn wire. It should not light up. If it does, or if you get low readings on the multimeter, then you definately have a short between the horn and the horn relay.
