Blown OEM 6x9, what to replace it with?
Discussion in 'Audio & Video' started by Jason12085, May 30, 2024.
  1. May 30, 2024 at 11:50 AM
    Jason12085
    Jason12085 [OP] Well-Known Member
    2013 MGM Access cab
    Have a blown 6x9 in the driver's side door. It distorts only on some low bass frequencies. Like a popping crackling noise. It doesn't have to be loud for it to do this.
    What would you guys recommend replacing the blown speaker with?
    Installed a Kenwood excelon HU that is rated at 22w RMS per channel. This made a noticeable improvement in the rest of the sound to the point I think In could make due with just installing another albeit used OEM speaker.
    But I was wondering if there are any options that might be better without installing an amp?
  2. May 30, 2024 at 1:20 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    You can find tons of used speakers here in the marketplace for cheap. You can also drop tens of thousands of dollars in upgrades.
    Power will always be the weakness.
    For the front speakers, you'd have to replace the woofers in the door and the tweeter in the dash. After speakers and parts, you're over $200 for the fronts (on the cheap end) and a few hours of work.
    Not bad, but it's definitely more than sticking an OEM back in there.
    Jason12085[OP] likes this.
  3. Jun 1, 2024 at 5:32 AM
    Jason12085
    2013 MGM Access cab
    I'm still trying to decide if I just want to replace the blown speaker with an OEM unit or aftermarket components <$200.
  4. Jun 1, 2024 at 7:47 AM
    18trdsport
    18trdsport Well-Known Member
    Bay Area, CA
    2018 TRD Sport ACLB MT
    The OEM speakers are pretty weak. Even an aftermarket HU with a small built in amp like yours can overpower those stock speakers easily. Crutchfield has a ton of 6x9 options for <$130/pair. Even the cheapest upgrades will be better than the stock pair.
  5. Jun 2, 2024 at 4:43 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Either get a replacement OEM or a set of Audison Prima 6x9 woofers.
  6. Jun 2, 2024 at 4:47 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Ahh yes, the classic “go big or go home” technique.
    still a modern favorite :D
    GirlLikeTrucks2 likes this.
  7. Jun 24, 2024 at 8:46 AM
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
    While you are replacing them. add some sound deadening on the door and you will notice a big difference as well. I deadened my doors with the stock speakers and a Kenwood excelon for a while and it was a very noticeable difference in sound and bass response for the factory speakers. This past week i finally added my Morel 6x9's up front running off an audio control L4.800.
    Now I'm cooking with grease, just have to decide on a sub for the rear.
