Blown rear axle seal
Discussion in '4Runners' started by buzzard1992, Sep 14, 2012.
  1. Sep 14, 2012 at 6:39 PM
    buzzard1992
    buzzard1992 [OP] Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    My sister 99 runner blew an axle seal. How hard are these things to change. I know I'll need a bearing pressed in to do the outter. Are these the same as the Tacoma axle? It has the rear locker as well
  2. Sep 15, 2012 at 12:50 PM
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    You probably don't have to mess with the bearing on the axle assembly. Unless you feel it's time to do so. To change the seal just pull the assembly out and you'll see the seal in the axle housing. You'll probably want a seal puller.
    Use this for a guide..
