Blown shock covered under warranty?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BeerGuy, Apr 20, 2017.
  1. Apr 20, 2017 at 1:23 PM
    BeerGuy
    BeerGuy [OP] Active Member
    Los Angeles
    '16 TRD OR DCSB Manual 4WD
    Does anybody know if Toyota will replace a blown shock under warranty on a stock truck?
    2nd question...if the dealership is not going to replace it, does anybody know where I could buy a stock TRD OR rear shock that is not the Stealership?
    Thanks for any input :cheers:
  2. Apr 20, 2017 at 1:26 PM
    gr0ver
    gr0ver Taco Supreme
    Charleston, SC
    2017 MGM Tacoma TRD Sport 4x4 DCSB Manual
    I believe it's bumper to bumper coverage for a period of time. Unless you have any related modifications, I don't see any reason why not.
  3. Apr 20, 2017 at 1:27 PM
    Khrolar
    Khrolar Well-Known Member
    Vancouver Island
    4 door 2017 trd off-road,
    None... :(
    It depends, how did you manage to blow it?
    smitty99 likes this.
  4. Apr 20, 2017 at 1:28 PM
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    Good luck. I couldn't get GM to replace the Koni on a 1LE Camaro long ago. It was puking fluid but they wiped it off and said it was fine.
    tacoflavoredkisses1 likes this.
  5. Apr 20, 2017 at 1:28 PM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Check the for sale section here, should be plenty with
    all the ppl that upgrade the suspension.
    1bad2k likes this.
  6. Apr 20, 2017 at 1:33 PM
    9TRDTCO
    9TRDTCO Well-Known Member
  7. Apr 20, 2017 at 3:14 PM
    odinsbro15
    odinsbro15 Well-Known Member
    Eric
    LOS ANGELES CA
    2016 Gray Tacoma trd offroad DCSB
    ROUGH COUNTRY FRONT 2 INCH LEVEL KIT, TINT, DIPPED RIMS, DITCH LIGHTS, CUSTOMER REAR FACING LIGHT, INTERIOR MATS
    i got one replaced under warranty 2016 TRD OR DCSB
  8. Apr 20, 2017 at 3:14 PM
    odinsbro15
    Eric
    LOS ANGELES CA
    techinally they replaced both rears because they wouldnt have been evenly worn
    9TRDTCO likes this.
  9. Apr 20, 2017 at 3:50 PM
    BeerGuy
    Los Angeles
    Awesome. Thanks for the input.
    shakerhood likes this.
  10. Apr 20, 2017 at 3:54 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    You could check the 3rd gen parts market place on here.
  11. Apr 20, 2017 at 3:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    You could read your warranty paperwork.............
  12. Apr 20, 2017 at 7:11 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I had a rear replaced on Gen 2. It was leaking oil and no problem getting it covered.
  13. Apr 20, 2017 at 7:13 PM
    TakeNoteS
    TakeNoteS Well-Known Member
    Luke
    Kalama Washington
    2022 Silver Taco SR5 LB 4X4
    last I checked the shocks are considered a regular wear and tear item.... but you could just give your local dealership service a call........................................................................... :annoyed:
  14. Apr 20, 2017 at 7:24 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Doesn't Bilstein have lifetime warranty to the original purchaser?
  15. Apr 20, 2017 at 8:15 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    They must really like you. Shocks are generally considered wear items like tires and brake pads.
  16. Apr 20, 2017 at 11:53 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Shocks are covered under the 36 month/36,000 mile warranty for leakage. They are not considered wear items like tires and brakes. Toyota warranty policy does not allow them to be replaced in pairs, they are replaced individually based on warranty guidelines once the leak is considered bad enough.
    There may be a dealer or two out there replacing both, but they would have to lie to Toyota and claim both were leaking if they want to get paid for it.
    Jeff
    1bad2k likes this.
  17. Apr 21, 2017 at 12:32 AM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Good to know!
