Blowout on I-55 southbound last night
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ProvelTaco_STL, Oct 7, 2018.
  1. Oct 7, 2018 at 11:22 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Stock jack is fine. It does its job. Make sure to position it correctly.
    I had a blown tire after a small all fender bender and changed the tire pretty close to F1 standards...
  2. Oct 7, 2018 at 11:27 AM
    ProvelTaco_STL
    ProvelTaco_STL [OP] Well-Known Member
    2018 Black Tacoma TRD Pro
    Incorrect, Stock jack is a piece of junk
    Alesimo likes this.
  3. Oct 7, 2018 at 11:31 AM
    eon_blue
    Azusa, CA
    If you're lifted then the stock jack won't help you, unless you put it under the lower control arm which isn't exactly recommended. If you don't have sliders or steel bumpers then a Hi Lift won't be anything but a very large and awkward paper weight, I'd recommend a bigger bottle jack from Harbor Freight or similar. Or if you have the means to store it in your bed, an aluminum floor jack maybe.
    over60 likes this.
  4. Oct 7, 2018 at 12:21 PM
    ProvelTaco_STL
    Not lifted....stock pro
  5. Oct 7, 2018 at 12:23 PM
    eon_blue
    Azusa, CA
    Weird...guess they cheaped out on putting decent bottle jacks in them. A good aftermarket one will do the trick, the HF ones are pretty inexpensive
  6. Oct 7, 2018 at 12:39 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I am lifted and have the accesory strap for the HiLift- that works, but you need a jack stand or trade off with the good spare as a stand, after you lift the dead tire. I also have sliders, and a cool little adapter for using the HiLift on the round slider tubing (Shmellmopwho built it), but I was also planning to sometime get either a larger HF pneumatic bottle jack to use with my on board air compressor to power it- no oil (very little, actually to lube it only) will allow me to store it without leaks and spills.
    You could also make or buy one of those sliding bases to replace the wheels on a aluminum HF hydraulic racing jack.
  7. Oct 7, 2018 at 2:13 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Sure that wasn't a bullet.
  8. Oct 7, 2018 at 2:16 PM
    lynlan1819
    Tacoma
    Lifted
    I keep a small floor jack in my truck,never had a problem.
  9. Oct 7, 2018 at 2:53 PM
    ProvelTaco_STL
    It’s not that it was a problem.....it just wasn’t ideal. I am aware that there is a lack of hi jack points on the tacos. That’s why you said I was going to get the Wilco hitchpoint for rear and was asking for cheap options for the front
  10. Oct 7, 2018 at 2:53 PM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    I thought the same thing but while on the side of the road something else would have happened.
  11. Oct 7, 2018 at 2:55 PM
    ProvelTaco_STL
    “Someone doesn’t like those cans!”
    tAcomaPueblo likes this.
  12. Oct 7, 2018 at 2:57 PM
    ProvelTaco_STL
    I saw the piece before I ran over it, just was in thick traffic and couldn’t really avoid it. It popped up quick as I began to pass someone. Otherwise yes, I would have been looking for lee Malvo before I got out
  13. Oct 7, 2018 at 2:58 PM
    ProvelTaco_STL
    I wonder is the first lee malvo rdference on TW?
  14. Oct 7, 2018 at 3:28 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Damn!!!!! That’s crazy.
    Glad you came out if this ok.
  15. Oct 7, 2018 at 4:19 PM
    #35
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    That is crazy. Glad you are ok.
