Blue "Genie" Taco (Hybrid)
Discussion in '2nd Gen. Builds (2005-2015)' started by Squatcher, Dec 11, 2013.
Thread Status:
Not open for further replies.
  1. Dec 15, 2013 at 3:45 AM
    #181
    Squatcher
    Squatcher [OP] Well-Known Member
    Dean
    California
    Speedway Blue "Genie"
    Blacked Out Hood Scoop, Cherry Bomb Extreme Muffler, Line Out Converter/8 inch Sub, GTA Car Kit, Plasti-Dipped Logos & Rims, Rubbermaid Splash Guard, Lightweight Battery, Fitch Fuel Catalyst, K&N Drop in Air Filter, Flex a Lite Fan w/Thermostat, HIDs, LED License Plate Lights, etc. 4x4
    Things I might do:
    Remove sound system (I installed before I went on mileage fit)
    Remove HIDs (static on fm sucks)
    Note: I removed 90% of unnecessary weight from inside, like the manual, tire pressure gauges, CDs, 1 umbrella instead of 2, etc, etc.
  2. Dec 15, 2013 at 6:38 AM
    #182
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    I am running the AFE Cold air on mine and it has the open filter in the bay and when I am moving it is with in 2-3 degrees of the outside air.
  3. Dec 15, 2013 at 7:04 AM
    #183
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Cool I guess this gues isn't full of it.
    Lower it and get a aeroshell.
  4. Dec 15, 2013 at 7:08 AM
    #184
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    So you want to put in a BAS? And have some electric assist?
    Hm.
  5. Dec 15, 2013 at 5:35 PM
    #185
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The scoop actually is in a low pressure zone.
    If you were to open it up, it would be a hot air exit.
  6. Dec 15, 2013 at 9:00 PM
    #186
    Squatcher
    Dean
    California
    If I land a firefighting job, or any other job paying me $50,000 or more, yes I'd install a Belt Alternator Starter (BAS) that would be pricey...
  7. Dec 15, 2013 at 9:04 PM
    #187
    Squatcher
    Dean
    California
    You can thank me later on this one lol...just make your hoodscoop a functional snorkel...that way you don't have to drill through the firewall. Wouldn't be as high, but still higher than engine bay.
  8. Dec 15, 2013 at 9:06 PM
    #188
    anders99
    Matthew
    Penscola, FL
    Until you hit a puddle at higher speeds and to comes over the hood
  9. Dec 15, 2013 at 9:08 PM
    #189
    Squatcher
    Dean
    California
    Thank you. If I had to do it all over again now knowing that I'm being laid off...I'd buy the fan again. Probably not all the other stuff. So far Fitch Fuel Catalyst works more like a vacuum, because it SUCKS!!!!. Still waiting for something. Now it's the Bitch Fuel Catalyst to me...
  10. Dec 15, 2013 at 9:09 PM
    #190
    Squatcher
    Dean
    California
    Lol, can somebody say hydro lock? FOCK!
  11. Dec 15, 2013 at 9:11 PM
    #191
    anders99
    Matthew
    Penscola, FL
    It rained so hard for 3 days down here in FL and the storms drains couldn't handle it so the streets had about a foot of water standing. I saw a couple of small cars stopped in the lanes.
  12. Dec 15, 2013 at 9:11 PM
    #192
    Squatcher
    Dean
    California
    I also wanted to get the Uni-Chip, but $599? Really? Wtf? Does it save any...and I mean any gas?
  13. Dec 15, 2013 at 9:14 PM
    #193
    Squatcher
    Dean
    California
    Which is why I have a 4x4. Can't be cheap with everything, but yes I'm cheap with gas. I hate pumping gas. I know how to make a car electric, but I'm just waiting for my engine to blow. Having electric would be best after this motor, but until it blows, BAS would keep me smiling.
  14. Dec 15, 2013 at 9:29 PM
    #194
    Rich91710
    Rich
    Los Angeles
    08 Base
    Main reason I don't dive into my fender and remove the factory "noise-reducing clusterfuck"
    What reduces noise also provides space for water to collect.
  15. Dec 15, 2013 at 9:31 PM
    #195
    toyodajeff
    jeff
    06 reg cab sr5
    I'm pretty sure most people that install snorkels actually pickup a few mpgs
  16. Dec 15, 2013 at 9:31 PM
    #196
    Rich91710
    Rich
    Los Angeles
    08 Base
    $50k?
    That's barely above poverty in SoCal
  17. Dec 15, 2013 at 9:46 PM
    #197
    Squatcher
    Dean
    California
    When I had my AFE installed, I noticed that the heater core was always "HOT". Even with the heat off, it was burning hot. Put your hand on the carpet/plastic housing of lower center console by the gas pedal. If really hot, your engine is running hotter than normal.
  18. Dec 15, 2013 at 9:52 PM
    #198
    Rich91710
    Rich
    Los Angeles
    08 Base
    Intake is not going to make a difference in coolant temperature.
    The heater core is ALWAYS running at coolant temp in the Tacoma.
    Some vehicles, moving the heater control to "hot" diverts coolant to the core, but on the Tacoma, the heater core is always at coolant temp, and the temp dial adjusts the position of the mixture door.
    But you knew that.
  19. Dec 15, 2013 at 9:55 PM
    #199
    Squatcher
    Dean
    California
    Honestly, is 400 miles per tank...(city)...normal for a 6cyl 4x4 automatic? Did I do something revolutionary by hitting 400 city, or is this common for others? Remember...4x4.
  20. Dec 15, 2013 at 9:57 PM
    #200
    Squatcher
    Dean
    California
    Haven't thought about that lol. Thx for the tip!
Thread Status:
