Blue remote wire from amp.
Discussion in 'Audio & Video' started by Tidrow, Sep 22, 2010.
  1. Sep 22, 2010 at 5:21 PM
    Tidrow
    Tidrow [OP] Well-Known Member
    Austin
    PreRunnin' 08
    BHLM, All Black grill, Fog light Mod, AFE pro dry, 20% tint, Weathertechs, Kenwood deck, Bridgestone AT Revo 2
    Qucik question... where's the blue remote wire from the amp go to? Pics would be sweet. Thanks all,
  2. Sep 22, 2010 at 5:27 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Depends, are you running the stock or an aftermarket head unit? If it's aftermarket there should be a connection for the remote turn on, if not you'll have to tap into a wire that gets power with the ignition on.
  3. Sep 22, 2010 at 5:38 PM
    Tidrow
    Austin
    PreRunnin' 08
    sorry for not being more specific. I have the deck installed a while back. I'm hooking up an amp with a sub. I was wondering were to run the blue wire from the amp. Doesn't it go to a fuse or something.
    Or are you guys saying to run the amp remote wire to the blue one coming out of the head unit?
  4. Sep 22, 2010 at 5:59 PM
    jtav2002
    Josh
    Reading, PA
    Doesn't go to a fuse, it will go to your headunit. One of the wires on the aftermarket headunit should be labeled as the remote lead turn on. I believe that it was in fact blue on the last aftermarket headunit I had. This connection is specifically for this purpose.
  5. Sep 22, 2010 at 7:50 PM
    Tidrow
    Austin
    PreRunnin' 08
    thanks for the tips on the amp. I have it hooked up now but there is only treble coming through the sub. It is a four channel amp and I'm not sure how to hook the speakers up. Anythoughts?
  6. Sep 22, 2010 at 8:14 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    i just installed a new deck and 4 channel amp this weekend. It was not hard at all and this was my first time. I however did not use the stock wiring. I re-wired from the amp to the speakers. so a pos and neg from each channel of the amp to the speaker.
  7. Sep 22, 2010 at 8:53 PM
    Tidrow
    Austin
    PreRunnin' 08
    I'll do it this way when It comes time, just worried about powering a sub at the moment.
  8. Sep 22, 2010 at 8:56 PM
    Tidrow
    Austin
    PreRunnin' 08
    thanks everyone, the blue wire has been handled :D
