Blue Sea aux fuse block install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tooblutacoma06, Jan 14, 2010.
  1. Jan 14, 2010 at 7:48 PM
    tooblutacoma06
    tooblutacoma06 [OP] Member
    Kellon
    Houston
    I hate messy wires. This is a great way to clean up all your wires and make your accessory wiring much safer and easier to get to incase of problems.
    I started with a cardboard template for the mounting plate:DSC01551_2a3913e29ccbb1c71c8654594eddef48851c6189.jpg
    From there, I went to my local metal supply shop and picked up a 12"x12" section of 3/16" aluminum (I forget which alloy it was. Make sure it's workable though). I had the shop put a 90deg bend in it. I then cut it to the dimensions of the template and had it powdercoated:
    Equipment installed on the mounting plate: Blue Sea Systems 12 circuit fuse box and a Blue Sea Systems 100A panel mount breaker.
    I wanted to get nice solid battery terminals as well. I opted for military spec terminals. They are extra beefy and won't corrode on me.
    Here is the panel mounted. As you can see in the photo, I also added relays to the panel for current and future accessories. I have relay sockets that will allow for easy removal of the panel if need be. I have room for atleast 3 relays on the panel.
    I wish I would have taken before pictures. I feel a whole lot better about my wires now. Everything is nice and clean and easy to get to. I highly suggest one of these fuse blocks for auxiliary circuits. Let me know what you think!
    kark, ryanbitt, jamesfishn09 and 14 others like this.
  2. Jan 14, 2010 at 7:53 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    that is the way i like it there, good job.this could be a sticky.
  3. Jan 14, 2010 at 8:03 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Nice work.
  4. Jan 14, 2010 at 9:52 PM
    krans
    krans Well-Known Member
    Kenny
    Huntington beach/ West min duh
    09 Sport mall crawler
    Icon extended travel with resi front and rear,Camburg UCA, All pro standard leaf pack, Fogs anytime, General grabbers AT2,Custom stainless steel brake lines,bed box, Bestop soft top,50' light bar, amber rigid pods,CBI ditch mounts with LED pods,TRD intake,Anti dark hoodlights/rock light/LED whip,FX-R retros and Gibson catback..more mods to come
    Nice work! Very organized.
  5. Jan 15, 2010 at 5:31 AM
    911-3.2 Well-Known Member
    CT
    Sold - 2010 Access Cab 4x4 I4 SR5
    Curt Receiver Hitch, Access Literider Tonneau
    Looks nice. I have that same one in my boat. Blue Seas makes some nice stuff!
  6. Jan 15, 2010 at 5:46 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    X2 makes mine look like a hack job! lol
  7. Jan 15, 2010 at 8:24 AM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    i have a similar set up. that mount is nice. wanna make one for me??!!??..... nudge nudge, wink wink :)
    Kpatt9 likes this.
  8. Jan 15, 2010 at 8:33 AM
    Ronin
    Ronin iTaco
    Al
    Rockwall, Texas
    2008 Tacoma Sport 4x4
    low range leveling kit
    Very nice. Very professional.
    -Al
  9. Jan 15, 2010 at 8:30 PM
    tooblutacoma06
    Kellon
    Houston
    Thanks guys! Everything works really well with this setup. I'm still not done cleaning up all the wires and tidying everything up. I'm using sockets for easy disconnects from the relays. With my next wiring project (roof lights) I'll almost have the block filled! That's kinda crazy.
    If you guys want a bracket like mine made, PM me and we can discuss a price and details.
  10. Jan 15, 2010 at 8:54 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Nice job in the install. I like your wiring, I like that your not using the cheese-ball pre insulated stereo shop connectors that you have no idea if you got a good crimp or not. Use a quality connector and shrink wrap the end. This would make a great sticky.
  11. Jan 18, 2010 at 9:14 PM
    tooblutacoma06
    Kellon
    Houston
    Skimping on connectors can cause troubles that's for sure! It's worth it to take a few extra seconds to make sure the crimp is secure and seal it up with heat-shrink. Thanks!
  12. Jan 18, 2010 at 9:40 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    great job!
  13. Jan 18, 2010 at 9:42 PM
    eschmunk
    eschmunk Well-Known Member
    Stuttgart, Germany
    09 Prerunner TRD Off-Road
    GrillCrafter Upper and Lower, Lamin-X Fog Light Covers, Di-Noc Carbon Valence Cover, WeatherTech Digital Fit Liners, Rubbermaid "ActionPacker" containers for bed storage.
    Definitely want to do something like this. I might try it out once I do my OBA/Trainhorn setup. Would be good for driving lights as well. Good job.
  14. Jan 18, 2010 at 10:34 PM
    AlexForbesR6
    AlexForbesR6 My R6 Eats Me
    Alex
    Houston, TX
    07 4x4 6-Spd
    very clean install
  15. Jan 23, 2010 at 6:02 PM
    tooblutacoma06
    Kellon
    Houston
  16. Jan 23, 2010 at 6:20 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    forgive my ignorance, but what is the point/purpose of the breaker? i have one of these and have been meaning to install it, but might add that breaker if it makes sense to me. is it absolutely necessary?
    could you please expand on that and where you got it, thanks!
  17. Jan 23, 2010 at 9:24 PM
    tooblutacoma06
    Kellon
    Houston
    The circuit breaker takes the place of a fuse. Instead of having to replace a fuse incase it blows, you just flip the switch. Same as a house. To me, it's a more robust and a cleaner option. Also, if I'm out on the road or off the road and don't happen to have fuses with me, I can just flip the switch and have everything working again. A little more spendy but worth it.
    I'm thinking I ordered mine from boatersworld.com but you can just search blue sea 12v circuit breaker and you'll have tons of results.
  18. Apr 7, 2010 at 9:15 AM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    Nice work OP. I'm thinking about doing "add-a-circuits" but this looks like a much better way to add accessories.
    I have a couple questions. The answers will probably be simple to you...I'm a 12V noob!
    - I see that you have a large fuse mounted near the battery. Since you said you don't have a fuse between the battery and the aux fuse box, I'm assuming that fuse I'm seeing is for a stereo HU inside the cab? Why did you opt not to run whatever that is off of the new aux fuse panel?
    -Do you have multiple grounds coming off the battery? If so, what is the purpose of multiple grounds?
    -Do you have a wiring diagram that you could share? Hate to be a copy-cat but I like the way you did went about installing the aux panel.
    Thanks in advance:thumbsup:
    bajatacoguy likes this.
  19. Apr 12, 2010 at 5:26 PM
    tooblutacoma06
    Kellon
    Houston
    Hey Tim! Thanks for the compliments. It took a while of planning and sourcing parts to get it all done.
    1) You are correct. The fuse in the clear plastic holder is the fuse for my stereo system. The reason it is not in the Blue Sea box is because its amperage exceeds the max amperage limit for the box (I think it's 40A per circuit). And also, I opted to install a circuit breaker between the auxiliary fuse block and the battery instead of a fuse. I would highly, highly recommend installing either a circuit breaker or a fuse large enough to cover your circuits in front of the fuse box. The circuit breaker is great because you can reset it if it blows instead of buying more fuses. It's 100A rated.
    2) The grounds from the battery were rewired with 4 AWG wire. I have the original grounds and one that goes to the fuse block so that I could ground the circuits to the fuse block instead of random places on the truck. It's just cleaner and more accessible this way.
    3) Unfortunately I don't have a wiring diagram drawn up. If you follow the pictures though, it's pretty easy. I didn't do anything spectacular or different than OEM. Just added the necessary power and ground wires for the fuse block. The wiring for the individual circuits depends ofcourse on the add-on. If you have anymore questions just let me know.
    I hope I could help a little bit anyways. Good luck!
  20. Apr 12, 2010 at 8:17 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    I am getting ready to tackle this feat...I already have the fuse block and circuit breaker. I am working on the steel plate. Thanks for ideas and write up!
