Blue Sea Fuse Block Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ilovetacos, Jul 18, 2010.
  1. Dec 25, 2010 at 10:51 PM
    #41
    ilovetacos
    ilovetacos [OP] Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    Cool...It's a good deal! It's comes bare so be ready to paint it. I used Rustoleum bedliner out of a can. Has held up fine over the last year.
  2. Dec 26, 2010 at 2:29 AM
    #42
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Cool man, post pics when you're done![/QUOTE]
    Will do
    Hopefully I'll have time soon into new year, I'm working a ton now
  3. Jan 4, 2011 at 11:13 PM
    #43
    MJonesTrumpet
    MJonesTrumpet Well-Known Member
    Michael
    Central PA
    Hey this is kinda off topic...but...does anyone know what size connectors we need to hook up to the blue sea fuse box? I need to hook up my lights, I finally got the box all hooked up, but nothing is hooked up to it, because I dont know what size connectors with the right size O rings to get...
  4. Jan 6, 2011 at 11:18 PM
    #44
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    Are you talking about these:
    or these:
    It depends on what size wire you are using.
  5. Jan 8, 2011 at 12:10 PM
    #45
    MJonesTrumpet
    Michael
    Central PA
    I was thinking about the second ones, but the problem I keep finding, is I cant get the washer head small enough with a bigger butt end for the correct guage of wire...This is an extreme example, but do you know if they make that little red guys washer, with the big yellow butt? Thats the problem I keep running into
  6. Jan 8, 2011 at 12:18 PM
    #46
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    I don't see why you would have to use that large gauge of wire when connecting items to the fuse block. I wouldn't use wire any larger than 12 gauge which will fit into the "red" connector.
  7. Jan 9, 2011 at 1:32 AM
    #47
    MJonesTrumpet
    Michael
    Central PA
    Well mostly because its not my wire. Its aux lights and fog lights, and Im not going to change out the entire wiring for them...PIAA used larger wire than I would have, but, im certainly not going to try to rewire it all. Thats why I'm trying to figure out where I might get some funky connectors.
  8. Apr 25, 2011 at 2:24 PM
    #48
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    sub'd
  9. Jul 27, 2011 at 3:49 PM
    #49
    ExpoSpy
    ExpoSpy Well-Known Member
    Brian
    Temecula
    I know this is an older thread but...I noticed that you have a Red Top with the side posts. did you attach the factory terminals to the sides and then the aftermarket stuff to the top terminals? I am working on my distro block and I have a Yellow Top with side terminals and I want it to be a clean install. Thanks for the help
  10. Jul 27, 2011 at 4:48 PM
    #50
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    I actually have the Yellow Top D34/78 now which is the same size as the Red Top I previously had.
    Yes, I have the factory terminals to the side posts and aftermarket terminals to the top posts. In order to do this I had to buy a longer ground cable that connects to the inside fender area and I also had to extend the factory positive cable about a 1/2" with an aftermarket battery clamp. The factory postive cable pretty much has no slack after connecting it but it fits fine and have no no issues.
    In this picture you can see the new ground cable connected to the body of the truck. I don't remember the exact length I purchased, maybe 12". You can also see the factory positive cables pulled tight to the positive side post of the battery.
    In this picture you can see how I connected a new clamp to the factory positive cable. I had to modify the factory clamp to get this aftermarket gold clamp on there. I then cleaned up the wiring with shrinktubing.
  11. Jul 27, 2011 at 4:58 PM
    #51
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    really nice and clean set up
  12. Jul 28, 2011 at 7:16 AM
    #52
    ExpoSpy
    Brian
    Temecula
    Awesome! Thanks for the additional pictures!
  13. Jul 28, 2011 at 4:24 PM
    #53
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Not as clean as the above, but here is my knstall
  14. Nov 1, 2011 at 8:36 AM
    #54
    itsryan
    itsryan Active Member
    Chino Hills
    11 4banger 4x4 SR5- sold
    2.5i 2015 Subaru Outback
    Awesome build bro! i want to put in a secondary fuse box like that. what size circuit breaker should i use?
  15. Nov 1, 2011 at 9:44 AM
    #55
    ty77064
    ty77064 Member
    Ty
    Houston
    Nice set-up. Where and how did you secure the battery box?
  16. Oct 4, 2012 at 12:31 PM
    #56
    shweller
    shweller Well-Known Member
    Corona
    2010 Tacoma TRD Sport SB 4x4
    PoP 'N' Lock Satoshi Grill (Did it Myself) DSM UCA's (Desert Products) FXR 1.1 w/Gatling Gun Shrouds Phillips 85122 Method Racing Wheels HID Hella 500's behind Satoshi grill Fog Light Anytime Illuminated 4x4 Switch Ultragauge PIAA 510"s King Coilovers w/resi's Rear TSB Leaf Packs All Pro Sliders Bolt on sliders 255/75 R17 BF Goodrich Mudders Spidertrax wheel spacers Neoprene arm rests Weathertechs Wet Okoles w/TRD Allpro Ofrroad Apex bumper and IFS skid plate
    Thanks OP for the inspiration. I finally got around tofabricating a mount and installing my fuse block to get everything off of thebattery. Thanks!
  17. Oct 4, 2012 at 12:33 PM
    #57
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    I think this is my next mod as well :)
  18. Aug 1, 2014 at 10:21 AM
    #58
    J88logue
    J88logue NorthWest Member
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
  19. Oct 6, 2014 at 10:27 PM
    #59
    PPansini10
    PPansini10 Well-Known Member
    Paul
    NJ
    09' DCSB 4x4 TRD Sport
    Bringing this thread back to life... when connected the tsunami fuse holder, where does it connect to?
    EDIT: i saw he has it running to his amp, if i don't have an amp or anything, do i need it?
  20. Dec 28, 2015 at 7:50 AM
    #60
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    where do you plan on mounting the relays when you do add light bars if you haven't already? sorry for reviving old thread
