Blue Sea Fuse Block Install
Discussion in 'Technical Chat' started by tmreyes1, Jan 29, 2013.
  1. Jan 29, 2013 at 11:00 PM
    tmreyes1
    tmreyes1 [OP] Well-Known Member
    T-Rey
    TX
    2017 TRD
    Well here is my take on the aux. fuse block install. I know it has been done before, but here is my take on it. Credit to everyone else who has done it and given me ideas.I decided on the 12 slot fuse block and had a 80 amp breaker that I will be switching out with a 100 amp when I hook up more to it
    Started with a scrap piece of metal I had. I traced around the breaker and fuse block to ensure it was gonna fit and I liked the layout
    I then drilled the holes for the mounting locations.
    Bench test fit and in vehicle test fit
    I was going to paint it black, but I saw the Duplicolor OEM touch up paint and decided to give it a try. Excellent color match
    Ready for final install
    Connected to battery and done.
    It is hard to see in the pic, but I did run a support from the bottom of the plate to the master cylinder to prevent and vibration issues. I cut it and bent to shape from left over metal then sprayed it to match. Right now I only have my bed lights going to the fuse block, but I need to move my CB and other things when I get time.
  2. Jan 29, 2013 at 11:02 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Nice job
  3. Jan 29, 2013 at 11:55 PM
    tmreyes1
    T-Rey
    TX
    2017 TRD
    Thanks OZ. It was fun to finally get off my butt and do this one
  4. Apr 7, 2013 at 6:26 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Where did you order from? Got a web link to the breaker?
    Does the power wire feeding the breaker connect straight to the battery?
