Blue Sea panel and Breaker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Leggo, May 25, 2012.
  1. May 25, 2012 at 1:33 PM
    Leggo
    Leggo [OP] slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    So I figured I would install a Blue Sea fuse panel and resettable 100 amp breaker in my truck. My panel under the dash is getting full of add a fuses. Figured I'd show how it went.
    The first thing I did was to go about mounting the panel and breaker to a piece of 1/4 " ABS sheet(cut down a bit) I bought from McMaster-Carr. I marked, then drilled and tapped the holes for the panel and breaker (1/4" x 20 ) and used stainless screws
    The second thing was to mount that panel to the fuse box cover of my truck with all stainless steel hardware.
    [​IMG][​IMG]
    The next thing was to install it and hook up the cables. I bought the cable and then the lugs and made them to length, I used the marine shrink tube with the glue inside. Done!
  2. May 25, 2012 at 1:38 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I have a breaker for all my audio stuff in the truck. Best decision I ever made.
  3. May 25, 2012 at 3:20 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Looks great! That's how I want to mount my aux fuse panel since my winch solenoid box is takin up space behind the fuse box. One question tho, is it difficult to access the fuse box now?
  4. May 25, 2012 at 4:07 PM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    I am running a similar setup on my Yamaha Rhino. Holds up well to the elements.
  5. May 25, 2012 at 5:58 PM
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
  6. May 25, 2012 at 9:20 PM
    Leggo
    Newton,Ma.
    no the fuse box opens the way it always did. just open and tilt towards the battery. Presto! I plan to run all power leads from the battery side so I can still lift and tilt the whole panel towards the battery to access the fuse box. I do however need to loosen the 10mm ground screw to let the ground cable pivot. All the cables are connected in this photo.
    It works just fine, I started hooking things up today
  7. May 28, 2012 at 9:53 PM
    DueNorth
    I really like how you've set this up. One other question tho, have you lost some of the easy access to the fuse box now that you've ran some wiring into the fuse panel?
  8. May 29, 2012 at 7:12 AM
    Leggo
    Newton,Ma.
    Not the slightest. The wires are minimal compared to the power and ground cables. Really very simple,. I am pretty much a fussy prick about functionality.
  9. May 29, 2012 at 9:07 AM
    badger
    badger Well-Known Member
    07 SR5
    I have a Blue Sea panel in my truck as well, but I nounted mine in the cab. If you mount in the engine bay you still end up running a ton of wire through a crowded firewall. I have an ignition switched relay under the hood thhat feeds the power supply to the panel. By far most of my aux power needs are in the cab.
  10. May 29, 2012 at 12:59 PM
    2ski4life7
    2ski4life7 Well-Known Member
    Grant
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Where did you get the cables?
  11. May 29, 2012 at 1:08 PM
    Leggo
    Newton,Ma.
    Great idea about the relay. I worry about leaving things on without knowing, then finding a dead battery later. Not sure how that works with a 100 amp breaker tho.
  12. May 29, 2012 at 1:11 PM
    Leggo
    Newton,Ma.
    I bought all cables from Amazon.com, lugs from Grainger, Sheet ABS from Mcaster-Carr, and panel and breaker from West Marine Inc.
  13. Jun 19, 2012 at 11:40 AM
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    Do you have this running off of ign power or is it hot all the time?
  14. Jun 19, 2012 at 1:47 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    looks good . the bluesea stuff is great and lasts for years . heres how i did mine a few years ago.
  15. Jun 19, 2012 at 1:54 PM
    Large
    Large Red
    Nice ^
    Details on that setup ?
  16. Jun 19, 2012 at 3:46 PM
    Defined
    mike
    southern california
    like? it runs lights , trans fan, ham radio, and still have a spot or two left for future stuff
  17. Jun 27, 2012 at 6:35 PM
    Leggo
    Newton,Ma.
    for now it's hot constant. I am going to get a high amp relay to make it ignition only.
  18. Jun 27, 2012 at 7:32 PM
    badger
    07 SR5
    Sorry for the delayed reply. I used a 12v continous duty starter relay. Not all starter relays are continous duty, so check the box. I found a keyed hot wire in the factory fuse box to trigger the relay. I would probably mount the breaker that you have before the relay. Pretty simple.
  19. Jun 28, 2012 at 12:44 AM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    I think I have that same Blue Sea panel and mine is rated for 80amps. I saw you are using a 100amp breaker. I'm wondering if you have the same panel and if so, is your breaker at too high an amperage?
  20. Jun 28, 2012 at 10:32 AM
    Leggo
    Newton,Ma.
    perfect, thanx.
