Blue smoke on start-up, sometimes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doug S, May 23, 2019.
  1. May 23, 2019 at 6:30 PM
    Doug S
    Doug S [OP] Well-Known Member
    NJ
    2015 DCSB Pyrite Mica SR5
    Hi,
    2015 DC v6, 37K miles, oil changed religiously @ 3K using Toyota dino oil and filter.
    Looking back I think I've noticed this before from inside the truck, caught a puff of smoke when I started it but checked it off as condensation smoke.
    Been noticing a second or two of blue smoke when I start it after its been sitting a day or two, I have a remote start and I've been checking. Happened twice this week or so, after sitting three days I got a good sized puff of smoke, after sitting overnight I got just a tad. But the rest of the time it's been fine including other times when sitting over night. Always parked in the same spot, oil is filled perfectly.
    Anyone else have this?
    Any ideas what this is and why it comes and goes?
    I'm not happy to see this, I keep my trucks a long time, atleast I used to..
    Thanks
    D/s
  2. May 23, 2019 at 6:37 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    That's guides or stem seals. Not good on such a low mileage engine.
  3. May 23, 2019 at 7:01 PM
    Doug S
    NJ
    Yeah, I figured that's what was causing it and I'm wondering why it's intermittent and I have no measurable oil loss between changes... Also curious if
    anyone else has had it??
    Thanks..
  4. May 23, 2019 at 7:04 PM
    oregongrown
    oregongrown Active Member
    Salem oregon
    2013 TRD offroad double cab
    Wow. Sounds like valve stem seals. I can't believe that on such low mileage. My initial thought would be to try a high mileage oil and see if that helps at all. Those types of oil have additives to slightly swell seals. That would be the least cost to try first.
    HillJackJDS likes this.
  5. May 26, 2019 at 1:50 PM
    Doug S
    NJ
    I guess this is rare, nobody else has spoke up as to having this issue. Been driving toyota trucks since 85, I bought the 15 instead of the 16 because it was a proven design...just my luck... The motor is still on warranty but I know they wont do anything, it's intermittent and right now there is no perceivable oil loss. but it's there and I don't like it or trust it... I own 4 Toyotas at present and they have ticked me off on one of the others so I think now might be a time to look elsewhere... Been looking at the ranger but the full sixe 150 has some nice options on the King ranch...My buddy just got one for 53.5 out the door, the Tacoma pro is 45.... not much of difference in price but the King ranch is loaded
    Thanks
  6. May 26, 2019 at 1:57 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    Sure sounds like valve seals. I can't say how common this might be. I've only had Toyota 4 or 8 cylinder engines, never owned a V6. If you do get a new truck go with the F150, I doubt you'll regret it...
  7. May 26, 2019 at 3:22 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    check the pcv valve.
    whatstcp likes this.
  8. May 26, 2019 at 8:14 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I've noticed this on my wife's van a couple of times but at the time, I decided it was because I had moved it a few hours earlier and literally only ran the thing for like 20 seconds. It was still on high idle and not warmed up at all. I figured it had a little more unspent fuel in the cylinders or something to that effect.
    It never uses any oil and I've only seen it do it a time or two. Any chance you ran it for just a short period before? If you're not losing any oil as can be seen on the dipstick, I wouldn't sweat it unless it gets worse.
