Blue smoke!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07nctaco, Jan 16, 2009.
  1. Jan 16, 2009 at 2:05 PM
    07nctaco
    07nctaco [OP] Active Member
    nc
    07-DC prerunner
    :mad: I have about a second of blue smoke at start up!!! I know this is some sort of oil issue but the truck only has 23k on it. Any ideas or anyone with this issue?
  2. Jan 16, 2009 at 2:13 PM
    wes
    wes Well-Known Member
    Atlanta
    07 DC sport silver V6 auto
    URD CAI,URD Y-Pipe,,Wet-okle covers,Silverstar headlgt bulbs,Undercover bed cover,black nerf bars,Alpine 9883 Alpine speakers,Pioneer 10" sub,SIRIUS sat. Redline hood struts, white gauge led and shifter light "mod"
    does the truck burn oil at all(is the level ever low).if so it may be a valve guide seal or broken piston ring(s).i am not real familiar with the internal details of these 4.0's so
    this is my first guess.
  3. Jan 16, 2009 at 2:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Are you SURE its "Blue"? It could be the richening circuit. When it gets really cold, the ECU squirts more fuel in the engine. The result of this is a "puff" of smoke on start up.
  4. Jan 16, 2009 at 2:54 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not blue smoke, but I've seen white smoke come outta mine the other day.
    The truck gets driven every day. The other day, it sat for a day (I got the jeep outta the garage). The next day I started it up, a bunch of white smoke came out at start-up. That cleared up almost instantly - then it turned into the usual cold-air white puffin'(?)
    Mine's about 2 years old with only 14k on it.
  5. Jan 16, 2009 at 3:22 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Did you have a recent oil change. I had this happen when there was too much oil in the engine.
  6. Jan 16, 2009 at 3:25 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    If you're sure it's blue, have somebody else start it while you get a whif of it. If it's oil, you'll know it.
    Overfilled oil will do it. It could also be coming in through a stuck open PVC valve. Worst case is it's leaking by your valve seals.
  7. Jan 16, 2009 at 4:04 PM
    1 bad tacoma
    1 bad tacoma Well-Known Member
    rustburg Va
    05 trdsport 4x4
    grapics, 6" fabtech lift, volant intake with ram air scoop, cleared head lights, chrome kit, westin bull bar and steps, custom toyota emblem, throttle body spacer, flomaster 40 series, dick cepeck black and sliver dc1s, trd seat covers, thrid brake light cover, chrome tail lights
    if its over filled with oil it would smoke all the time wouldn't it, or till it burns the excess oil out
  8. Jan 16, 2009 at 4:09 PM
    CRFan1
    CRFan1 Well-Known Member
    Northwest Indiana
    Tacoma Pre-Runner
    DNX5120, Audsion AMp, Hertz Speakers
    How many miles? Sounds like valve seal or seals may be leaking. Smoke on start up is typical of that.:(
  9. Jan 16, 2009 at 4:18 PM
    07nctaco
    nc
    07-DC prerunner
    The truck is not driven daily so it does sit a few days without being driven.It only has 23k on it.I did just do a oil change and used 5.5 quarts and I know its blue because I used my remote start and stood behind it to make sure!!
  10. Jan 17, 2009 at 6:52 AM
    CRFan1
    Northwest Indiana
    Tacoma Pre-Runner
    Sounds like valve seals. I wouldn't be overly concerned but with that many miles it should be a warranty issue no?
  11. Aug 23, 2009 at 9:39 PM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    i get white smoke from time to time if i don't drive the truck for a day or so (usually happens when i drive my dads car for a day or two). usually it clears up to just the same thing a cold engine puff. i wuld still take the truck to the dealer if its under warentee
  12. Aug 23, 2009 at 9:52 PM
    shook0002
    shook0002 "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    Def. sounds like valve guide seals. You should be covered under waranty, I'd take it back to the dealer. They can do a leakdown test and pinpoint where the oil is going.
  13. Nov 21, 2009 at 12:01 PM
    it's in coma
    it's in coma Well-Known Member
    in the desert
    06 trd off road
    intake and exhaust
    reviving this from the dead because i have seen this happen to my truck, and i was searching for similar problems. It has happened when parked uphill on my driveway and nowhere else that i am aware.
