Bluetooth goofiness solved...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by colepc, Apr 24, 2016.
  1. Apr 24, 2016 at 6:32 AM
    colepc
    colepc [OP] Member
    Terry
    2016 Black TRD Off Road
    none yet
    Howdy,
    First post to what appears to be a great forum. I'm a 1st time owner of a Tacoma; mine is 2016 Black TRD OffRoad with tech and premium JBL package. I've had the truck for about 3 weeks.
    I noticed about 2 weeks ago that whenever I return to the the truck after having left with my iPhone connected via Bluetooth, the audio would play intermittently. That is, power the truck on, phone connects to BT, and whatever audio was playing (either Pandora on the truck or iPhone audio being streamed) would play for a second, then a second of silence. This would repeat indefinitely. The only fix I found was to turn off my bluetooth on the phone, then turn back on again.
    I found that my daughter had entered her phone as an additional one on the truck's system and believed the symptom to be coincidental to this. I removed her phone from the truck, leaving only my original iPhone 'registered'. The symptoms all stopped after doing this.
    Hope this helps someone.
    LTacoman likes this.
  2. Apr 24, 2016 at 6:46 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Cool - thanks for the heads up. Possible the Tacoma didn't like her taste in music as well :rockband:
  3. Apr 24, 2016 at 6:58 AM
    Alpha2
    Alpha2 Well-Known Member
    Jeff
    Ft. Collins
    2016 Barcelona Red TRD Sport
    SnugTop, Bed rail LEDs
    Darned kids! Glad you figured it out. Those weird little problems can drive you nuts.
  4. Apr 25, 2016 at 10:05 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    Thanks for posting this. Sorry, but I'm not exactly sure what you mean by "registered". Do you mean the quick contacts? If so, does that mean you have no quick contacts?
  5. Apr 25, 2016 at 11:22 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Mine does this, my girlfriends phone is paired but it does it weather im at her house or mine even if shes not around.
    Same for you? Or did it only happen when her phone was within distance
  6. Apr 26, 2016 at 4:07 AM
    SqFt
    SqFt Well-Known Member
    2016 Tacoma TRD Sport
    I have two phones paired and this connection error will sometimes occur. What I did was delete the pairing on both the entune unit and the iPhone for my phone, then re-pair. Now every now and then I will get the connection error, but for the most part it works fine. Also, I have settings synced to my individual phone. I thought it may loose those settings when I deleted it, but it retained all the unique settings for the phone when I re-paired it.
  7. Apr 26, 2016 at 5:20 AM
    colepc
    colepc [OP] Member
    Terry
    none yet
    Instead of "registered", I should have said "connected". When there were 2 phones connected and listed as being available to use with the radio, the symptom was there. When I removed the 2nd phone from the connected phones list, the symptoms stopped.
  8. Apr 26, 2016 at 5:30 AM
    Alpha2
    Jeff
    Ft. Collins
    I also found yesterday that when I took the quick contacts off the home page that I got text messages again.
  9. Apr 26, 2016 at 8:11 AM
    vuTron
    SF Bay Area
    Got it. Thanks. I'll test my system today. Thanks for sharing.
  10. Apr 26, 2016 at 8:40 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    I've had this same problem but never thought about deleting my daughter's. Thanks OP, I'll try it, and yes you've been helpful.
