Bluetooth issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by John714, Oct 22, 2018.
  1. Oct 22, 2018 at 10:17 PM
    John714
    John714 [OP] Member
    2018 SR5
    I’m having Bluetooth connection issues in my 2013 Tacoma. It doesn’t automatically connect when I start the vehicle it usually does (Bluetooth is on, on the phone) and when I click “home” and “Bluetooth audio” then “select phone” to try and connect it, it says “Waiting on Bluetooth connection” then it sits there and doesn’t do anything..
    Has anyone experienced this before? If so what are some possible fixes ?
  2. Oct 22, 2018 at 10:41 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Delete all devices and re-pair them. You might want to check that pairing is A2DP.
    John714[OP] likes this.
  3. Oct 22, 2018 at 10:44 PM
    John714
    John714 [OP] Member
    2018 SR5
    It won’t let me view the previously connected users or even add/delete devices, are there any other solutions ? Thanks for your time and reply.
  4. Oct 22, 2018 at 11:02 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Has your phone ever been connected to the truck? If not, review instructions for pairing your phone and repeat the process.
  5. Oct 22, 2018 at 11:05 PM
    John714
    John714 [OP] Member
    2018 SR5
    Yes it was paired to the truck, this issue started occurring 2 nights ago and ever since then the Bluetooth for the truck itself hasn’t been working proplerly or connecting to any “paired” phones at all.
  6. Oct 23, 2018 at 12:16 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Maybe pull fuse for truck and start over.
  7. Oct 23, 2018 at 3:50 AM
    John714
    John714 [OP] Member
    2018 SR5
    Will try that thanks
  8. Oct 24, 2018 at 4:15 AM
    John714
    John714 [OP] Member
    2018 SR5
    It didn’t work, it keeps saying “Waiting on Bluetooth...” and stays like that regardless if I click on Apps then Phone or if I click Home then “Select Phone” option. Has anyone experienced anything like this? If so what have you done that fixed it ? Thanks.
  9. Oct 24, 2018 at 5:57 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Sure sounds like there’s no pairing or that Bluetooth is disabled on the phone.
  10. Oct 24, 2018 at 6:42 AM
    John714
    John714 [OP] Member
    2018 SR5
    I have had this truck since 2013 and paired all of my phones to it fine but this issue recently occurred where it would say “waiting on Bluetooth” and wouldn’t do anything else but the phone itself connects to my 2018 Tacoma and other vehicles with Bluetooth just fine
  11. Oct 24, 2018 at 6:48 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Have your you tried turning your phone off for at least 20 seconds?
  12. Oct 24, 2018 at 7:24 AM
    John714
    John714 [OP] Member
    2018 SR5
    Yes and it won’t connect with any other phones either that are able to connect to other vehicles with Bluetooth
  13. Oct 24, 2018 at 12:05 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Mine (2013) will no longer pair with the truck just like you describe. It will not send a signal to the phone.
    But I don’t use blutooth so I really could care less.
  14. Oct 24, 2018 at 12:36 PM
    John714
    John714 [OP] Member
    2018 SR5
    I use the boothtooth function very often due to receiving calls often and using the hands free function. I just ended up ordering this piece from Amazon that plugs into the car like an adaptor that comes with 2 USB ports and can also use hands free / Bluetooth.
    Handsfree Call Car Charger,Wireless Bluetooth FM Transmitter Radio Receiver&Mp3 Music Stereo Adapter,Dual USB Port Charger Compatible for iPhone,ipad,Samsung Galaxy,LG,HTC,Smartphone https://www.amazon.com/dp/B01M0SFMIH/ref=cm_sw_r_cp_api_zLm0BbYX43P7T
  15. Oct 24, 2018 at 12:46 PM
    Gabrieljacksonems
    Gabrieljacksonems New Member
    Gabriel
    2015 White Tacoma Pre-Runner
    Emergency Lights Off-Road Tires
    Mine has been having the same problems. Mine will not even show bluetooth as an option in settings. My USB port has been acting weird as well and will only connect to my phone sometimes. (Less than often). Going to dealership today. Seems a lot of people are having this problem. Will post what they respond with.
    John714[OP] and PackCon like this.
  16. Nov 20, 2018 at 7:10 PM
    GFF Taco
    GFF Taco New Member
    Davey
    2014 Taco Double cab Falcon Cadge
    Okay so "waiting for blue tooth" tried to connect any and all the phones that have ever been connected with the radio failed to fix anything. Then I read about turning ignition to on but not starting engine and letting the radio power on then holding in the "app" button at the same time turning lights on then off 3 times (I thought someone was jerking my chain) brought up a diagnostic screen. In the bottom left corner toggle button "INT" it will say something about personalize data yes or no, I pressed yes and exited out by holding in the power button and then blue-tooth was working again.
    Hope this helps, if your like me there was no way I was going to wait a month for it to magically start working again.
    Cheers
    tcBob and John714[OP] like this.
  17. Nov 20, 2018 at 9:02 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    I guess I will keep this in mind if mine starts to act up.
  18. Nov 21, 2018 at 5:11 PM
    John714
    John714 [OP] Member
    2018 SR5
    It worked!!! Thank you very much GFF Taco
  19. Apr 14, 2019 at 4:54 PM
    wmbii
    wmbii New Member
    2015 Tacoma TRD off-road pyrite mica
    Unbelievable! It did work, then it went away, then I was able to reload it. Not sure how long it will work, but an unbelievably funky fix.
  20. Jul 31, 2019 at 1:30 PM
    SingletrackMind
    SingletrackMind Member
    2015 DCLB 4x4 SR5 Blue
    I did a similar technique posted by another, except hold down memory clr instead. It didn't work, so I'll try your idea of INT and personalize data 'yes', then exit with power button.
