Bluetooth mic placement
Discussion in 'Audio & Video' started by Voodoochild 2k9, Dec 11, 2012.
  1. Dec 11, 2012 at 12:22 PM
    Voodoochild 2k9
    Voodoochild 2k9 [OP] Well-Known Member
    Randy
    Florida
    TBD
    Undercover SE; DD Pioneer Radio
    What is your favorite place to mount the bluetooth mic on aftermarket systems? I have a Pioneer if that helps, not sure if there is a quality difference on different brands' mics. I would prefer a spot where the passenger can be heard as well, and maybe somewhat hidden if possible.
    I wish I could use the factory mic, but I've read that those are amplified and therefor will not work with aftermarket radios.
    Thanks for your inputs!
  2. Dec 11, 2012 at 12:25 PM
    Voodoochild 2k9
    Randy
    Florida
    TBD
    Off topic, but also if you have the new wire for the iPhone 4/4s where does the other end plug in? The USB and iPod end are obvious, but I don't recognize the third input. Will be getting an iPhone when I am eligible for an upgrade to my phone, and am planning for the install ahead of time.
  3. Dec 11, 2012 at 12:26 PM
    Ghoster
    Ghoster Well-Known Member
    Baltimore
    2012 PreRunner DCSB
    I ran mine up the drivers side pillar and across to the center. I stuck it to the glass at the very top behind the mirror. It worked well from there for me.
  4. Dec 11, 2012 at 1:05 PM
    Voodoochild 2k9
    Randy
    Florida
    TBD
    Was that a difficult run or pretty straight forward?
  5. Dec 11, 2012 at 2:28 PM
    Ghoster
    Baltimore
    2012 PreRunner DCSB
    Pretty straight forward. Stick your fingers up there and you will feel that you can tuck that wire in where the window and headliner meet. Fishing it through the dash wasn't too hard either. Just be patient and don't yank to hard on those delicate little wires.
  6. Dec 11, 2012 at 2:29 PM
    Ghoster
    Baltimore
    2012 PreRunner DCSB
    iphones plug in to usb plugs. Not sure how our cord has 3 plugs on it? Maybe a picture would help.
  7. Dec 11, 2012 at 6:33 PM
    Voodoochild 2k9
    Randy
    Florida
    TBD
  8. Dec 11, 2012 at 6:34 PM
    Voodoochild 2k9
    Randy
    Florida
    TBD
    From the Pioneer website:
    • Enjoy Advanced App Mode for iPhone® 4/4S or iPod® Touch 4th Gen on your AVH-P8400BH
    • USB and RGB Connections for Audio/Video Playback and Access to Compatible Apps.
    • Designed for Optimal USB Device Charging
    • Cable Measures 1' 8" with 6' 7" RGB Cable
  9. Dec 11, 2012 at 6:39 PM
    NWTacoGuy
    NWTacoGuy Well-Known Member
    James
    Pacific North West
    2010 TRD Off Road DCSB
    Fabtech 6", xd addicts/35x11.50 Nitto Terra Grapplers, Black badges, Pioneer HU, 11' grille, ect ect ect....
    I also have mine there too and it works great!! By the way I also have a Pioneer AVHP4400.
  10. Dec 11, 2012 at 6:48 PM
    Voodoochild 2k9
    Randy
    Florida
    TBD
    BTW what do you stick it with? 3M?
  11. Dec 11, 2012 at 7:00 PM
    NWTacoGuy
    James
    Pacific North West
    With mine I used the standard white Ipod cable and I can use it for all of the apps, Pandora...whatever else I want, it works just fine in my 4400.
  12. Dec 11, 2012 at 7:09 PM
    Voodoochild 2k9
    Randy
    Florida
    TBD
    The 2013 line has a different app mode I think. The new one is called Advanced App Mode. Don't know if this makes a difference.
    My main concern here is that I am trying to wire up the usb and aux inputs to the stock location (there is a thread on it somewhere in here). But I don't know where that third connection goes. I will try out the standard iPod cable and see if that works. I should be able to test it with my daughter's iPod touch before I get my iPhone.
  13. Dec 11, 2012 at 7:17 PM
    NWTacoGuy
    James
    Pacific North West
    Yeah I saw a thread around here with someone who retro'd a usb port into one of the button holes...looked pretty good. I just run mine from the back of the deck to the front console area because I like to always charge my phone while listening to Pandora. Also for the bluetooth as well, even though i can just use the HU for that.
  14. Dec 11, 2012 at 9:43 PM
    Voodoochild 2k9
    Randy
    Florida
    TBD
    The one I saw used a part from a Tundra that fit into the switch blanks for older Tacos (pre 2012). The part looks to be identical to what comes stock on newer models.
  15. Dec 11, 2012 at 9:45 PM
    Voodoochild 2k9
    Randy
    Florida
    TBD
    What'd you use to stick it with? I have a tint strip up there. Will that matter?
  16. Dec 12, 2012 at 9:39 AM
    Ghoster
    Baltimore
    2012 PreRunner DCSB
    Just a question, you aren't planning on getting a NEW iphone? An iphone 5 I mean? They use a different plug is why I ask.
  17. Dec 12, 2012 at 9:46 AM
    GerhartCss
    GerhartCss Well-Known Member
    Harrisburg, PA
    08 TRD Sport
    Pioneer AVIC-X710BT w/ PAC SWI-PS, Leaf Spring TSB
    Not sure about anyone else, but I have a Pioneer and also have it up there. Mine came with a clip so I just clipped it between the windshield and the headliner.
  18. Dec 12, 2012 at 4:46 PM
    mne3312
    mne3312 Well-Known Member
    Alabama
    '10 Prerunner SR5
    K&N Air Filter, Weather Tech Floor Mats, Weather Tech Deflectors, Truck Covers USA Roll Cover, 15% front 5% back Tint, Toyota Hitch Cover, Pop & Lock 8521, Pioneer 4400BH, Infinity 6-1/2" Speakers, 4-Channel Amplifier, Access Bed Mat
    I mounted the mic between the head liner and windshield with the clip that came with the 4400. The wire was plenty long enough to run up the side and across the top of the windshield. On another note, the iPhone 5 will not transfer video to the HU. I have the 30 pin to lightning port adapter and it does not transfer video. The only thing the adapter is good for is charging the phone in the truck. I hope Pioneer is in the process of producing a lightning cable for the latest Apple products. These are not the best pics, but I think you can see that the clip fits perfectly with no tape or glue holding it in place.
  19. Dec 12, 2012 at 4:52 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    this part is not very long FYI. my HU came with a usb adapter. that had a male and female usb ends. i had to get this^^ but mine has a 3.5m jack kind like head phones and the USB. idk what other little plug on that one is. but it also works with ipod classic/video.(idk what gen mine is i have had it for 4 or 5 years tho.) i have it all tucked and ran into the center console.
  20. Dec 12, 2012 at 4:54 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    so do i.
    i just stream pandora thru bluetooth from my phone. don’t need to plug it in.
