Bluetooth music skipping issue resolved
Discussion in '3rd Gen. Tacomas (2016-2023)' started by unclebert, May 4, 2017.
  1. May 4, 2017 at 3:33 PM
    unclebert
    unclebert [OP] Well-Known Member
    North of Atlanta
    2017 SR5 Double Cab 4x4 MGM
    I have '17 SR5 with Entune Audio Plus, no JBL or Tech package. Like several on here, I have had chronic issues with Bluetooth connecting and music skipping. I found the solution below on the Internet and it has worked so far, 4-5 days of no issues. See below for settings correction.
    Go to Home Screen
    Settings
    Bluetooth
    Select your phone
    Hit the button that says "Device Info"
    Select "Connect Audio From"
    You then have two options, Vehicle and Device.
    Mine was set on "Vehicle". I changed to "Device" and it has been flawless for 4-5 days.
    It connects everytime I get in the truck, no skipping or having to toggle BT on and off to connect.
    I can also switch between FM, AM, or XM radio and back to Bluetooth using the mode button on the steering wheel. This almost always caused the BT music to skip when going back to BT music.
    I hope this helps some of you out there having the same issues. It's been my only real complaint with the truck so far....
    Edit: I have android Moto X Pure running 6.0
    Led_Tasso21, Shveet, cshrum and 5 others like this.
  2. May 4, 2017 at 3:56 PM
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    Just a note, it also states in the owners manual you should not have more than one music source connected at the same time, such as Bluetooth and another music device plugged in to the USB or AUX port.
  3. May 4, 2017 at 4:09 PM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    Cool. I'm going to try this. If it doesn't work then you'll have to fight me.
  4. May 4, 2017 at 4:11 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
  5. May 6, 2017 at 12:20 PM
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    This worked for me!!! Not sure what exactly it does but it worked!!
    unclebert[OP] likes this.
  6. May 6, 2017 at 12:30 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    That's soooooo wrong....
    What the hell happened to you during your timeout?
  7. Jun 23, 2017 at 11:51 AM
    Orlandoech
    Orlandoech Orlandoech
    Orlando
    Taylorsville, UT
    2020 Tacoma TRD Pro - AG
    1/2" HeadStrong Leveling Kit 1.25" Bora Spacers Wildpeaks 265-75-16s on stock Pro wheels
    Glad I came across this. Gonna have to try it today. I bought a 2017 Tacoma less than 5 days ago and already have the issue with Bluetooth skipping all over.
  8. Jun 23, 2017 at 12:05 PM
    ChrisK7UND
    Colorado
    It worked for me. I did notice that it switched back to Vehicle at some point. But I put it back and it seems to be keeping.
  9. Jul 21, 2017 at 8:46 AM
    jytran77
    jytran77 Member
    Covina, CA
    2017 Tacoma TRD OR DCSB
    I was having this same issue on my 17 OR and this fixed it, thanks!
  10. Jul 21, 2017 at 8:48 AM
    Orlandoech
    Orlando
    Taylorsville, UT
    also has worked for me since I adjusted the setting!
  11. Dec 7, 2017 at 6:39 AM
    Clevelandkid113
    Clevelandkid113 Member
    2017 Super White Tacoma TRD Off Road 4X4
    Mine is still skipping like crazy! Did anyone else have to do anything else?
  12. Feb 15, 2018 at 10:47 PM
    DSSK
    DSSK Well-Known Member
    2017 White Tacoma Limited 2WD
    Thanks OP!
  13. Oct 19, 2020 at 3:46 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Thanks OP, thread is still useful 3 years later
    Switching from "Vehicle" to "Device" helped me out when i switched to a new phone the other day.
    running a new Motorola G Power
    cheers!
