Bluetooth OBD II scanners for iPhone
Discussion in '1st Gen. Tacomas (1995-2004)' started by jrallan26, Jan 30, 2018.
  1. Jan 30, 2018 at 8:36 PM
    jrallan26
    jrallan26 [OP] Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Does anyone use one? If so which one should I get. Are they worth it?
  2. Jan 30, 2018 at 8:43 PM
    Rburdeaux
    Rburdeaux Well-Known Member
    2004 Double Cab Prerunner
    that1guyty likes this.
  3. Jan 30, 2018 at 8:45 PM
    Rburdeaux
    and yes it is worth it
  4. Jan 30, 2018 at 8:46 PM
    jrallan26
    Iowa
    Can you clear check engine lights?
  5. Jan 30, 2018 at 8:47 PM
    Rburdeaux
    yes
    jrallan26[QUOTED][OP] likes this.
  6. Jan 30, 2018 at 8:53 PM
    jrallan26
    Iowa
    Thanks for the info.
  7. Jan 30, 2018 at 10:12 PM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    I use this: https://www.amazon.com/gp/product/B01C3HAHCS/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    It's a WiFi OBD II dongle. I know you asked for bluetooth, but it's a lot cheaper. It's not bad, but I found that this one causes the ABS light to flash if you leave it connected and turn the truck on. I ended up buying this cable and removing the pin causing that flashing to happen. I leave it connected all of the time now.
    https://www.amazon.com/gp/product/B00KYH9COE/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    I also use OBD Fusion ($10 IIRC) to do OBD II stuffs to the truck. It's pretty snazzy. It can clear trouble codes, run diagnostics, and allows you to create custom dashboards (pictured below).
    tony2018 likes this.
  8. Jan 30, 2018 at 10:15 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    BLUEDRIVER.
    Has been flawless.
    Now for day to day and towing info I use a scan gauge II. It makes more sense for a couple of outputs vs the BLUEDRIVER with my iPad for detailed in depth troubleshooting.
    Rburdeaux likes this.
  9. Jan 30, 2018 at 10:46 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I use the Kiwi3, leave it installed all the time, and love it. I use it with DashCommand on both Android and iOS devices, which seems like the nicest UI of the OBD apps to me. Reads all settings, can clear codes, etc. Also, very low profile compared to other options.
  10. Jan 31, 2018 at 4:53 AM
    jrallan26
    Iowa
    I don’t plan on keeping it in all the time but would be handy for a long trip.
  11. Jan 31, 2018 at 4:57 AM
    MeFryRice
    MeFryRice Well-Known Member
    Marietta, Ga
    '16 QS Tacoma DCOR4x4
    I have the Carista OBD II adaptor and really like it. You need to pay for the app if you're looking to open any/all available customization options but it's been nice to use.
  12. Jan 31, 2018 at 5:04 AM
    jrallan26
    Iowa
    Just purchased the blue driver. I’m guessing it tell me which app to purchase.
  13. Jan 31, 2018 at 5:05 AM
    jrallan26
    Iowa
    Which app do you use?
  14. Jan 31, 2018 at 5:11 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    And what pin is that? It's one of the reasons I don't leave mine attached all the time.
  15. Jan 31, 2018 at 6:34 AM
    hpidriver
    hpidriver Active Member
    '03 4x4 Xtracab 3.4L TRD SR5
  16. Jan 31, 2018 at 6:54 AM
    indetrucks
    indetrucks Well-Known Member
    Christian
    Southern CA
    Supercharged 03 TRD Tacoma 4x4 Xtra Cab 5spd
    I was going to leave mine plugged in but it triggers one of my warning lights on the dash (forget which one) until I remove it.
    Does yours leave any lights on when it's plugged in?
    Rburdeaux[QUOTED] likes this.
  17. Jan 31, 2018 at 7:59 AM
    Glamisman
    Glamisman Well-Known Member
    My experience is with BlueDriver... quick and easy to use. If all you want is a device to check codes and reset the CEL there are those types out there too. If you want more than that support from the manufacturer is important. My other truck, a Ford Ranger, has an issue that only appears in Mode 6. There is no description of the error for this in Mode 6 of the device. I undestand that for $99 they cant make this device do everything a more expensive scanner can do. An email to BlueDriver with the code and they showed me where I can look it up.
  18. Jan 31, 2018 at 8:18 AM
    Klierslc
    Klierslc Well-Known Member
    Dan
    Virginia Beach
    1998 Tacoma 4x4 e-locker
    The 20 dollar ones on Amazon work great. I use the torque lite app.
    Edit: not sure if those work for iPhones.
  19. Jan 31, 2018 at 2:40 PM
    vapilotda
    vapilotda Member
    Daniel
    2003 double cab Tacoma TRD limited
    It does on mine as well. My ABS light will light up after you turn the ignition off and back on again. I can't just leave it plugged in. I wonder if it's a function of the Bluetooth set up and if I bought a scanguage, it that would do it too.
  20. Jan 31, 2018 at 3:14 PM
    Tjk031
    Tjk031 Active Member
    Tommy
    2003 double cab 4x4 trd
    vapilotda likes this.
