BlueTooth on new Tacoma
Discussion in 'Toyota Trucks & SUVs' started by TacoTut, Oct 20, 2011.
  1. Oct 20, 2011 at 7:45 AM
    TacoTut
    TacoTut [OP] New Member
    Eric
    Greenville/Spartanburg, SC - GSP
    2012 Pre-Runner
    I'm having trouble connecting my iPhone 4 to my new Tacoma.
    No problems pairing it has an audio device to play iTunes through the speakers and control at steering wheel.
    Problem is I can't pair it as a Phone.
    Any suggestions?
  2. Oct 20, 2011 at 8:13 AM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    sledgehammer.... best solution ever...
    Joking
    check bluetooth settings in iphone for call settings?
  3. Nov 2, 2011 at 4:55 PM
    MBRGuru
    MBRGuru Member
    Were you ever able to get it paired for phone? Are you seeing an error message?
  4. Nov 16, 2011 at 9:43 AM
    Mitch658
    Mitch658 New Member
    Tulsa, Okla
    2011 Tacoma Crew 4X4
    Lift kit
    I would go back and let my salesperson do it..
  5. Nov 26, 2011 at 6:59 AM
    Rain
    Rain Well-Known Member
    Washington
    2011 TRD Off Road
    Thought I'd post here instead of starting another "Bluetooth Problem" thread.
    I have a 2011 Tacoma and a Samsung Infuse 4G. They are both great (especially the Tacoma) but they don't play well together!
    It is easy to set up and get paired. Problem is, they lose connection and I have to pair several times per week. It only takes a couple of minutes, but it shouldn't be that way. Dealership can't figure it out. When I try to use it I get a "Not Linked" message. If I try to select phone it can't find the phone, even though when I have it "List Phones" it is there.
    Any suggestions would be greatly appreciated.
  6. Nov 26, 2011 at 7:23 PM
    Tacoma Mike
    Southern Maine
    Ok
    Your not going to like what i say but here it is.
    In both instances.
    Try another phone. If it works ok ,it's the phone.
    It does not make a difference if your phone is on a stupid list or not.
    E-tune is even worse.
    One of the service writers has his phone paired to like 15 different cars..
    Always try another phone before you waste the dealers time.
    Dropping your pair and error messages in every instance we have had is with the phone.
  7. Nov 26, 2011 at 9:13 PM
    Rain
    Washington
    2011 TRD Off Road
    Sounds good Mike. I'll give it a try. Thanks!
  8. Nov 27, 2011 at 6:02 AM
    Tacoma Mike
    Southern Maine
    :thumbsup: Give us a report back.
  9. Jan 26, 2012 at 1:09 PM
    Bayrider
    Bayrider Active Member
    Kal
    Hatteras,nc
    4dr,4wd,v6 auto
    Did you ever resolve pairing problem. I had someone under 40 pair mine as I was not able to grasp what the heck the Toyota manual was saying. Even the , person doing the set up had trouble,especially when it came to entering names and nos. I bought my wife a Blue Ant Blue Tooth unit for her Avalon and it literally took 5 mins. It downloaded the entire phone book in 10 sec. and has worked beautifully since. I live too far from the dealer to have them set it up but if that is the only way................ Let me know if you found the magic touch.
  10. Jan 29, 2012 at 7:01 AM
    Rain
    Washington
    2011 TRD Off Road
    I didn't resolve it, but I did find out that it is the phone, not the truck. And I've gotten very fast at re-pairing, to the point that it is almost a non issue. Apparently, all Samsung phones are experiencing the same issue, but I like my Droid enough that I'm willing to put up with it. What phone do you have?
    Thanks for asking.
    BTW, being under 40 would probably make a lot of things easier/better! ☺
    Let me know if you are still having trouble and I'll a step by step process.
  11. Jan 30, 2012 at 5:30 AM
    Bayrider
    Kal
    Hatteras,nc
    4dr,4wd,v6 auto
    my phone is a LG Octane. Last week it lost pairing, voice on BT said cannot connect, check phone. I was not able to re-pair and just let it alone for a few days.. Yesterday I received a call and the darn thing fixed itself. Magic. This is the 2nd or 3rd time it has happened. I find the instructions in the Taco manual very confusing, even for experienced techies. Thanks.
  12. Feb 28, 2012 at 9:08 AM
    birdsflysouth
    birdsflysouth Member
    TRD SR5 Tacoma
    Not sure if your original problem (quoted below) has been resolved or not but thought I'd respond with a solution that worked for me (iPhone 4 / 2012 Tacoma).
    If you have already paired your phone for audio, delete it.
    Press the "Unhook" button on your steering wheel which will prompt setup of the phone.
    Follow the commands and when prompted setup for internal audio.
    This will allow both the phone AND audio to work.
    I initially setup the bluetooth audio first and also had problems trying to pair the phone afterwards.
    Setting up via the phone function resolved the issue for me.
    C
  13. May 5, 2012 at 11:56 AM
    Beaver
    Beaver Member
    Kootenays, British Columbia
    2012 doublecab long box 4x4 SR5
    When I bought my truck I had a Blackberry, it paired easily to my truck and had no problems. I quit my job and my phone went with the job. I've got a Sony xperia and can not make it work with my bluetooth in my Tacoma. I can play music from it but I can not use it to talk hands free. Any suggestions?
  14. Aug 26, 2012 at 9:14 AM
    dfrugia
    dfrugia Well-Known Member
    Goose
    Roswell, NM
    2012 DC TRD OFF RD 4X4
    Running boards w/steps, Weathertechs
    I am having the same problem as above. My iPhone 4s worked great then one day it wouldn't work...I can get it to play music via bluetooth but it is no longer working for handsfree. I have deleted the phone from the system and reconnected several times. Still no fix.
    Brother likes this.
  15. Dec 31, 2012 at 12:03 AM
    neli2k
    neli2k New Member
    Neli
    Juneau
    Tacoma 2013 extra cab
    Bed shell
    My iPhone won't connect with bt in my 2013 tacoma. In my truck radio I go to setup, blue tooth, registered devices, add new. Then I go to my iPhone, settings, Bluetooth, car multimedia, it keeps saying connection unsuccessful. What am I doing wrong?
  16. Jan 13, 2013 at 12:23 PM
    Bamafever50
    Bamafever50 Member
    Birmingham,Al
    13' Prerunner Dbl Cab V6 TRD Sport
    I'm not sure but I have th original iPhone tht connects with my new Tacoma. The audio will not sync up due to th g but th phone was simple. Make sure to enter the code for access on your phone if needed "0000".
  17. Aug 7, 2014 at 5:51 PM
    Robwmc
    Robwmc New Member
    North Carolina
    2012 PreRunner SR5
    I have a 2012 Prerunner SR5, I paired my phone and didn't realize what I was doing and setup Bluetooth audio. I was told I could plug in my Sony MP3 player in the AUX and then press the AUX and play the music. Every time I push the AUX it wants to pair with a Bluetooth Audio device. Can I remove the Bluetooth Audio setup from my system? and How do I do that?
  18. Jan 11, 2015 at 11:51 AM
    Semperpar07
    Semperpar07 New Member
    The problem is that you bought a prerunner :)
  19. Oct 8, 2016 at 5:35 AM
    emooleson
    emooleson New Member
    It seems like getting a new phone was my problem. I resolved it by choosing the option in my iPhone to "forget this phone". After doing that I was able to pair my phone's Bluetooth with my truck.
  20. Oct 8, 2016 at 5:43 AM
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    I have had my Tacoma 23 months and no issues with mine, my wife paired the Iphone up.
