Bluetooth Phone Problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by billsimon, Dec 27, 2015.
  1. Dec 27, 2015 at 7:36 AM
    billsimon
    billsimon [OP] New Member
    Hi,
    I got my 2016 Tacoma OR for about 2 months. I absolutely love it.
    However the bluetooth phone stopped working a month ago. The phone can pair and connect to the truck. Playing music is fine. When making/receiving calls, there is no sound coming out of the truck's speaker. While both parties can confirm the call is connected, none of us can hear anything. It happens to both iPhone 6 Plus with iOS 9.2 and various Android phones.
    I brought the truck back to the dealer service department. They told me Toyota is aware of the issue and working on a software fix.
    However I've searched the forum and haven't been able to find any reference to the problem. I am wondering if anyone has experienced the same issue and know how to deal with it.
    Thanks,
    Bill
  2. Dec 27, 2015 at 7:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not on the truck, but I'm having my own issues with Bluetooth and the iPhone 6 w/ 9.2 with my hearing aid. It's been 3 months that I've been trying to troubleshoot. Just recently, talked with 2 different people (Apple Genious bar, and Tech on phone) and they're all scratchin their heads.
    Have you tried using someone else's phone?? I'd suggest 'forgetting' your device and try using someone else's phone. If you can find someone with an older version or older phone that you can run some tests.
    Find someone else with 3rd Gen and same phone/etc and compare your 'settings' to make sure you have all settings properly set.
    Check your 'General' / 'Accessibility' / 'Call Audio Routing' setting. I'm not schooled on cars with Bluetooth (my 2007 doesn't have it) but you could try and play with these settings and see what happens. My husbands is on Automatic.
  3. Dec 27, 2015 at 9:14 AM
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    I am good on a iPhone 6 9.2 with no problems. As suggested disconnect your phone and in the iPhone select forget this device. Let it pair up again. Then ensure you have the correct source selected when you make the call. I know you can switch between sync and iPhone.
  4. Dec 27, 2015 at 9:26 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    My iPhone 6 9.2 works as advertised.
    G.
  5. Dec 27, 2015 at 10:28 AM
    Wraith600
    I should add, the one bug I have like everyone else is to do with the quick 4 dial contacts. Don't add any when you pair up your phone again. That's a known issue.
  6. Dec 27, 2015 at 12:23 PM
    billsimon
    Thank you all for replying on this thread.
    I have tried "forget the device" and pair the phone again, I have also tried in iPhone settings|general|accessibility|call audio routing. None of them helped. I have also tried to pair up with different android phones. Same problem.
    From the replies, it works properly for most people. I am suspecting it's a defect for my truck. But why the dealer says it's a known issue, for which Toyota is working on a software fix.
  7. Dec 27, 2015 at 7:59 PM
    Wraith600
    I don't know if it's the same "known issue" we are talking about. I haven't seen anyone here post it absolutely not working but more or less the same problems.
    Ask you dealer if they have another 16 to try your phone on it / pair it up if possible. If it doesn't work I would look at your phone, not the truck unit.
  8. Dec 28, 2015 at 7:05 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    While my bluetooth phone seems to work like it should, if I'm listening to music over bluetooth with it, the music screen will flicker every now and then. It flickers to the bluetooth logo and back to the music very quickly. You can barely see what image it flickers too, but you notice it when it changes. It's only over bluetooth and not CD, AUX, or radio. Running an iphone 6s here as well. It doesn't matter if I have the music screen selected where it displays over the entire screen, or if I'm at the home screen wiht the nav to the right and the music to the top left. That one little section will flicker.
  9. Dec 28, 2015 at 10:48 AM
    kngharley
    kngharley Well-Known Member
    Corona, Ca
    Have you tried going into your settings on the stereo and adjusting both the send volume and receive volume? Mine were reset to zero once for no reason and after I adjusted it back it has worked fine since.
  10. Dec 28, 2015 at 7:21 PM
    billsimon
    Yes, I have tried to adjust volume, which wasn't reset to 0. I have also tried to reset my iPhone to factory setting by going to Setting|General|Reset|Reset All Settings. None of them helped.
    Have feeling it's hardware issue instead of software.
  11. Feb 4, 2016 at 6:55 PM
    Hollywood459
    Hollywood459 Active Member
    Woodstock, GA
    2012 DCLB TRD Sport 4WD - Magnetic Gray
    Has anyone encountered the issue where while bluetooth streaming music, you plug your phone into the USB port to charge it, and it cuts off the music? I can see on the head unit's display that the music has been paused, so then I press play on my phone, can see the track time continuing (on my phone), and the word "paused" disappears from the head unit's display. But no sound will come through the speakers. BUT - if I unplug the phone from the USB charging cable, and press play again, voila - the music comes back! This is driving me crazy. It's useless to not be able to charge your phone and play music via bluetooth at the same time!! :mad::annoyed:
  12. Feb 4, 2016 at 7:19 PM
    3rsdad
    3rsdad Member
    Roger
    Indy
    16 Silver O.R.
    Bone stock
    Unhook/ re-attach. You'll be good
  13. Feb 4, 2016 at 7:20 PM
    Hollywood459
    Woodstock, GA
    The problem repeats itself each time I plug the phone back into the USB cable...
  14. Feb 4, 2016 at 7:29 PM
    3rsdad
    3rsdad Member
    Roger
    Indy
    16 Silver O.R.
    Bone stock
    I have found that un original Apple cords ( especially longer) , don't have the transfer power. Even if they coiled around and not straight. My observation.
  15. Jul 11, 2017 at 1:54 PM
    sportwing1
    sportwing1 New Member
    2015 tacoma
    I have a 2015 Tacoma and every time I try to use my phone it comes back with check microphone or microphone not connected, my wife has a 2015 corolla and my phone works fine in it, guess I'll have to go to the dealer
  16. Sep 28, 2021 at 1:57 PM
    Konagrn
    Konagrn Well-Known Member
    Las Vegas, NV
    2019 Tacoma off road manual
    1.5" Eibach springs, 1.5" Icon add a leaf, Bilstein 5100 shocks, 1" rear blocks.
    Hey Bill. This is exactly what is happening to my 2019. Music plays fine but calls are not coming out of speakers and I must turn the volume all the way up to hear very faint sound. Also the "beep" mode is on and no beep sounds when pressing buttons. At the dealer now. They said I might get charged $140 diagnostic fee if it's not a factory problem but I'm sure it is. How did you fix yours?
  17. Dec 1, 2021 at 5:31 PM
    tacomike99
    tacomike99 New Member
    2012 Grey ext cab TRD
    I am having a similar problem with my 2012 TRD. The phone audio only comes out the small driver’s door speaker. Same for audio from setup commands. BT audio works fine. Did you find a solution?
  18. Dec 1, 2021 at 6:14 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Shoot me a PM tomorrow afternoon. I think I have an update file for that year.
  19. Dec 1, 2021 at 9:05 PM
    Konagrn
    Las Vegas, NV
    I took it in to toyota and they diagnosed the radio as defective but the new one they installed did the same thing. I didn't want to deal with it again so I bought a new alpine ilx-407 deck. Way better sound and works perfectly now. Just sucks you gotta buy all the back up camera and steering control and handbrake bypass harnesses. The entune worked fine before but after 6 months started acting up.
  20. Dec 27, 2021 at 4:38 PM
    Stunner04
    Stunner04 Member
    Miami
    2012 TRD Off Road
    Bone Stock
    Hi, everyone. I have a 2012 TRD and am experiencing the same issue as tacomike99. I have the generic non-JBL no video screen HU. My issue is the following... When using my phone to make a call, I can only hear the audio from the phone call through the left tweeter. It's the same issue regardless of making/taking a call. However, BT audio streaming works just fine for Pandora, Youtube, Etc. This odd behavior began about 6 months ago. Before that, all of my phone calls would come through all of the speakers, and it sounded great. Then, all of a sudden, there was a bit of static and that was that, the phone call audio now just came through that one little speaker, and it sounds tinnie and of poor quality. I've taken the radio out and unplugged everything, disconnected the battery, reset my phone, reset the BT, and phone BT. Honestly, I can't stand it. Any help with this would be greatly appreciated. I just want my truck back to how I loved it.
    Thanks!
