Bluetooth Work Well?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomtn, Jul 27, 2011.
  1. Jul 27, 2011 at 12:57 AM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    Wow, when setting up the Bluetooth, the tutorial voice is super loud! No way to turn it down either. Then when talking the person's voice seems to fade in/out. Then it won't let me access the phone book, keeps saying the phone book is empty. I have an iPhone 4.
    Are others having good luck with theirs? I'm not sure if I like it or not. Or have I not set it up right?
  2. Jul 27, 2011 at 5:53 AM
    Drouse
    Drouse Well-Known Member
    Dan
    Pittston, PA
    2011 Tacoma DCSB TRD Sport
    I'm currently on the hunt for a 2011 w jbl/bluetooth. Can either of you guys confirm if you can stream audio thru the bluetooth?? Thanks
  3. Jul 27, 2011 at 8:32 AM
    Spitz Stang
    Spitz Stang Well-Known Member
    Mark
    Houston, TX
    2012 DC TRD OR 4x4
    OME 885 / Dakar,5100's, 265/65-16
    Mine is a 2010 with JBL/Bluetooth and it does not stream audio. I don't believe they made changes for the 2011.
  4. Jul 27, 2011 at 9:12 AM
    Drouse
    Dan
    Pittston, PA
    thanks guys
  5. Jul 27, 2011 at 9:53 AM
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    Unfortunately the built in bluetooth doesn't access the phonebook stored in the phone.
    Annoying I know, considering my $20 POS bluetooth headset can do this.
    What you have to do is program each person you want to call into the Headunit and it seems to do a voice recognition on the recording of the name you gave it. Kind of annoying but once you get it all set up it works fairly well.
  6. Jul 27, 2011 at 10:00 AM
    skiracer0112
    skiracer0112 Well-Known Member
    Bryan
    Breckenridge, CO
    '11 Silver Double Cab 6-speed TRD OR
    I have not had any real problems with my phone and the BT in my truck. The minor inconvenience that I have encountered is that sometimes it will have some difficulty pairing with my phone and I will have to power cycle my phone. This was a problem with my old headset too so its not that big of a deal. Agreed that no access to the phone book on your phone is frustrating but its much better once fully set up.
  7. Jul 27, 2011 at 10:22 AM
    rhavin42
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    Guess it's good I don't have many friends :D
