BMW Not starting
Discussion in 'General Automotive' started by 02YotaGuy, Mar 8, 2011.
  1. Mar 8, 2011 at 1:40 PM
    02YotaGuy
    02YotaGuy [OP] Full Spectrum Off-Road, Owner
    Matthew
    Tucson, AZ
    05 Tacoma, 94 FZJ80
    Salvage Title Mod, bed rack tire carrier, Rago Fabrication Ditch Light & Bumper bar brackets, LED rock lights, 5100s, 887s, stereo stuff.
    So I moved my 2001 BMW Z3 out of the driveway and parked it on the street yesterday, and this morning I went to get in it and leave the house and all I got when I turned the key was this annoying click click click... When I did my research I discovered that it is the starter... Not excited about that... So I bought the part and the repair manual and it turns out that I am supposed to lift the car up in order to remove the starter from below while also removing the intake manifold to remove the top bolts. While I love my BMW, I kinda think that this was not the best place to put a part that regularly dies. Has anyone else had to replace a starter on an E36 Bimmer or really and BMW with the inline 6 engine? I'd rather not pay $XXX for someone to do it for me.
  2. Mar 8, 2011 at 1:43 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Give it a tap with a hammer and see if that frees it up, sometimes the solenoid can get stuck. Then you can at least pull it in the driveway.
    You sure it's not the battery?
  3. Mar 8, 2011 at 1:44 PM
    chaz834
    chaz834 Tacoma 4 Life.
    Chase
    Kendrick, Idaho
    2012 Sport MGM
    3'' Tuff Counrty Lift, Moromoto Mini H1 Projectors 5000K 35W, BHLM, 30'' LED Light Bar, Black TOYOTA Emblem, Excelon Touch Screen Deck, Hertz Speakers,Excelon AMP, 2 10'' JL Audio Subs, Wet Okle seat covers, Weather Tech Floor Mats.
    x2^^^
  4. Mar 8, 2011 at 1:54 PM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Amarillo, TX
    OME Lift
    x2 try and jump it first. Sounds like one of your cells in your battery isn't charging.
  5. Mar 8, 2011 at 9:00 PM
    snowmansgarage
    snowmansgarage Well-Known Member
    Portland, OR
    '06 TRD Offroad AC Tacoma
    I've got 6+ years of working at a BMW dealership and rarely ever see a starter go bad. Have your battery and charging system checked.
    Also, call your local dealer and see if they take part in the "world class inspection" program. It's a free service provided to BMW/MINI customers which includes a thorough inspection of the vehicle including a battery test.
  6. Mar 9, 2011 at 9:12 AM
    02YotaGuy
    Matthew
    Tucson, AZ
    05 Tacoma, 94 FZJ80
    I tried jumping it first, it didn't seem to do anything. I'll try again after work, and I'l try hitting it, maybe that will help. I'm not sure if BMW of Honolulu does anything for free... They wanted $150 just to hook it to the computer diagnostic machine. I'll keep everyone posted on the progress. Thank You all for the advice.
  7. Mar 9, 2011 at 9:42 AM
    snowmansgarage
    Portland, OR
    If you're jumping it with another vehicle, make sure you raise the rpms of the charging vehicle to 2,000 or above for a minute or two before attempting to start the BMW. I can almost guarantee it's a dead battery...
  8. Mar 9, 2011 at 9:43 AM
    macgyver
    Brad
    Canton, GA
    This ^^^
    If the battery is really dead it may need this.
  9. Mar 11, 2011 at 3:38 PM
    02YotaGuy
    Matthew
    Tucson, AZ
    05 Tacoma, 94 FZJ80
    So, I took the Battery out and had it tested, The batter was completely shot. I have no idea how old the battery was but it's been replaced and the car has no more problems starting. Saved at least a couple hundred bucks not having to replace the starter, so I'm glad I got the advice of some individuals who are more knowledgeable in this are than me.
    Thank You again for the help.
