BNIB 4:88s, ARBs, Compressor, And Master Install Kits
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by PreRunnerSeth, Apr 8, 2013.
  1. Apr 8, 2013 at 11:40 AM
    PreRunnerSeth
    PreRunnerSeth [OP] Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    *********************SOLD
  2. Apr 8, 2013 at 1:20 PM
    Manwithoutaplan
    ID
    this is good deal the lockers alone are grand each.
  3. Apr 8, 2013 at 1:20 PM
    TacoIII
    TacoIII Mr. Boombastic
    Andrew
    Albuqerque
    10 Taco 4x4 off road package
    3" OME 886 coils, ARB bumper warn M8000, Lightforce 240's and 255/85 16 KM2, Redline hood struts,arb twin air compressor, 4.88's, Tepui kukenam, Pelfreybilt bed rack and rear high clearance with swing out, and custom offroad bodywork
    Been looking for this package!!!!!!
  4. Apr 8, 2013 at 1:27 PM
    PreRunnerSeth
    Apex, NC
    I would sell the gears, Lockers, and Install kits seperate from the rear for those TRD OR guys. but not looking to sell just the lockers.
    Make me a reasonable offer.
  5. Apr 9, 2013 at 7:57 AM
    PreRunnerSeth
    Apex, NC
    Bump.... Make me a reasonable offer.
  6. Apr 9, 2013 at 8:40 AM
    Porkchop228
    Porkchop228 Well-Known Member
    Biloxi,MS
    07 DCSB 4X4 9" LIFT W/35'S
    6" Fabtech and 3" body lift with gap guards, 315-75-16 BFGoodrich A/T, Westin Ultimate Bull Bar, LED Duallies, UWS black lo-pro toolbox, black nerf bars, K&N intake, Sportsman Camo Covers front and rear in Mossy Oak Break-up, Weathertech front and rear floor liners, Illuminated 4x4 switch
    Will this work in a 07 4x4 tacoma V6?
  7. Apr 9, 2013 at 8:42 AM
    Manwithoutaplan
    ID
    is your truck a sport or off road?^
  8. Apr 9, 2013 at 8:43 AM
    PreRunnerSeth
    Apex, NC
    Yes, Unless you have a TRD OR In which case you could use everything but the rear locker.
  9. Apr 9, 2013 at 8:47 AM
    Porkchop228
    Biloxi,MS
    It is niether but it does have the LSD in the rear, open in the front.
  10. Apr 9, 2013 at 8:49 AM
    Manwithoutaplan
    ID
    I believe the base model come with the 8.4 rear which would not work for you ^
  11. Apr 9, 2013 at 8:52 AM
    Porkchop228
    Biloxi,MS
    Just my luck.....
  12. Apr 9, 2013 at 8:56 AM
    Large
    Large Red
    So everything will work but the rear locker for a sport corect?
  13. Apr 9, 2013 at 8:58 AM
    PreRunnerSeth
    Apex, NC
    If I have someone with a sport tacoma who is %100 commited i might be able to exchange the rear locker and gears for a tacoma.. let me check into it and Ill get back.
  14. Apr 9, 2013 at 8:59 AM
    Manwithoutaplan
    ID
    You would have to ask sierra gear to see if their a difference in Off road and sport ring/ pinion.
  15. Apr 9, 2013 at 9:04 AM
    Manwithoutaplan
    ID
    8″ Toyota V6 Sierra Gear & Axle Part #
    8″ Toyota V6 3.90 Ratio R&P V6 SG TOYV6-390
    8″ Toyota V6 4.11 Ratio R&P V6 SG TOYV6-411
    8″ Toyota V6 4.56 Ratio R&P V6 SG TOYV6-456
    8″ Toyota V6 4.88 Ratio R&P V6 SG TOYV6-488
    8″ Toyota V6 5.29 Ratio R&P V6 SG TOYV6-529
    8″ Toyota V6 5.71 Ratio R&P V6 SG TOYV6-571
    8″ Tacoma Sierra Gear & Axle Part #
    8″ Toyota Tacoma 4.11 Ratio R&P SG TOYT-411
    8″ Toyota Tacoma 4.56 Ratio R&P SG TOYT-456
    8″ Toyota Tacoma 4.88 Ratio R&P SG TOYT-488
    8″ Toyota Tacoma 5.29 Ratio R&P SG TOYT-529
  16. Apr 9, 2013 at 9:07 AM
    Porkchop228
    Biloxi,MS
    From the parts list it looks like the front would work but not the rear. Unless its the same part for both just different part numbers.
  17. Apr 9, 2013 at 9:09 AM
    Large
    Large Red
    I wouldn't be asking if I wasn't serious, this is the setup I've been looking for. I was under the impression the Sport had 8.4" rear differential and the OR has 8"
  18. Apr 9, 2013 at 9:11 AM
    Manwithoutaplan
    ID
  19. Apr 9, 2013 at 9:12 AM
    PreRunnerSeth
    Apex, NC
    It is a different rear, but I can get the arb, r&P, and install kit exhanged for the right one. Ill get back to you. might be a little more money. but i think i can do the asking price even if its more money.. within reason.
  20. Apr 9, 2013 at 9:13 AM
    Large
    Large Red
    :frusty:
    Ah well, I had other plans I guess I will have to tend to ... :spy:
