Boat ramp questions....
Discussion in 'Towing' started by nate1253, Jul 25, 2012.
  1. Jul 25, 2012 at 8:29 AM
    nate1253
    nate1253 [OP] New Member
    Nate
    Florida
    08 PreRunner Reg Cab 2WD
    Leveling Kit 2.5" in front 1" in rear, 265/76/16 tires
    I have an 08 reg cab 4 cyl manual prerunner. I am looking to buy a boat in the 16-18 ft range. Looking at Carolina Skiffs and the Mako ProSkiffs, something under 3500lbs. Im sure I wouldnt have any problem towing the boat on the roadway. Im a little concerned about the ramp and getting it in and out, with the manual and 2WD. Any thoughts?
  2. Jul 25, 2012 at 8:35 AM
    nate1253
    Nate
    Florida
    Thanks
  3. Jul 25, 2012 at 8:47 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    As long as the ramp is CONCRETE or Blacktop--No problems--if its GRAVEL--you will be spinning your wheels---This is where the 4x4-is needed
  4. Jul 25, 2012 at 9:21 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Yeah x2 on the gravel part. Go to nice landings
  5. Jul 25, 2012 at 9:31 AM
    Bennett707
    Bennett707 TWSS Enforcer
    Oregon
    '04 V6 3.4 TRD
    zip ties and scotch tape
    Disclaimer: From this picture, it does not appear any tacoma's were soiled by this incident.
  6. Jul 25, 2012 at 9:34 AM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    x3
  7. Jul 25, 2012 at 9:37 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i have a 4 banger and even on the black top ramp by my house and 31s i had to throw it in 4wd. it was so hard to not spin the tires on the moss with the manual!
  8. Jul 25, 2012 at 9:39 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    I don't get it :notsure:
  9. Jul 25, 2012 at 10:01 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Not always true.
    How steep is the ramp? Does the concrete ramp have a textured surface, or is it covered in moss/algae?
  10. Jul 25, 2012 at 10:07 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    This...
    My parents have owned a marina before I was born... I have seen it all.
    OP ~ you will need to find a ramp that works for you and you may have to put in or take out at certain points during high/low tide.
    NO ONE can say youll be fine or you won't. Believe me the marinas are used to people screwing up at the ramp so don't be worried. Just use common sense.
  11. Jul 25, 2012 at 10:08 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Freshwater or saltwater launch?
    If you're launching - or especially retrieving - in a a tidal area you want to be cautious of low-water retreival.
    The bottom of the ramp will be slimed. You can get stuck down there - and the tide's coming in, to make it worse.
    If it's a busy ramp - someone will pull you out.
    If it's a lonely spot - you may need to unlaunch the boat and hope you can still retrieve the empty trailer.
  12. Jul 25, 2012 at 10:10 AM
    Racer X
    Racer X Well-Known Member
    North Carolina
    07 FJ Cruiser
    I use to pull my 18 ft. center console with my 1997 Nissan and it had a 4 cylinder. Never had any problem on ramps. I've never had to use 4 wheel drive on any ramp, but I've never tried any unpaved. When you are pulling the boat out, the tongue weight of the trailer and boat will help give you traction.
  13. Jul 25, 2012 at 11:52 AM
    iamstik81
    iamstik81 Member
    Corey
    New Orleans
    2005 Double Cab TRD Sport.
    Pioneer Double Din, Focal Compents Front, Focal Coax rear, JL audio 500/5, 2 JL 10w1's. Custom molded Scangauge II mount, white dash lights.
    I pull a 19ft lowe aluminum boat with my 05 dcsb v6 Prerunner. I have launched at both dirt and concrete launches with no problems. However i live in La, and everything here is FLAT. Common sense is key in this situation.
  14. Jul 25, 2012 at 12:34 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Haha I know I was jokin. I use a boat ramp at least twice a week
  15. Jul 25, 2012 at 1:18 PM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Welcome to the forum, Nate. Anyway, just like any other hill or incline, you'll be just fine as long as you can maintain traction. Well used or maintained ramps are seldom a problem, while others can be covered with algae, moss, or similar slippery surface contaminants.
    Check before use. If you suspect a problem, sprinkle a little sand or dirt over the areas your tires will travel and don't back down the ramp any further than necessary.
    Of course, a 4x4 provides significantly better traction, with the front tires often well above any slippery surfaces. That's not much use to you now, but perhaps worth considering when you purchase your next vehicle.
  16. Jul 25, 2012 at 1:28 PM
    SouthernTaco
    SouthernTaco Active Member
    Scott
    Charleston, SC
    '10 PreRunner SR5 4-banger AC
    I have a '10 prerunner with the 4-banger and stick shift. I regularly pull a 17' boston whaler with a 115 2-stroke. Whaler's are not light.
    I haven't had a problem to date, and I pull at coastal ramps.
    I've also pulled a 21' Triton, although it was a bit sluggish.
    Take it slow up the ramp and just don't spin the wheels. The 4-banger can handle it. Unless the ramp is crappy or your load too big, 2WD will be fine.
    Just my 2-cents.......
  17. Jul 25, 2012 at 2:51 PM
    nate1253
    Nate
    Florida
    Thanks for the input everyone. Ive never pulled anything with this truck. I dont want to spend the money on a boat and then have to buy a truck to pull it. Just wanna see if anyone had any issues with the same setup that I have. The boats im looking at are fairly light and we have pretty good ramps around here. I do have Nitto Terra Grapplers. They may help with the traction...?
  18. Jul 25, 2012 at 2:58 PM
    97yota4wd
    Eric
    Mesa, AZ
    id just bring a shovel to throw dirt under your tires incase you need traction. if theres not dry dirt around..... maybe just throw a sand bag in your truck incase you need it. just an idea
    FWIW, a friend of mine had a giant ass diesel pusher with like a 30 footer, couldnt get out of the lake with that fat thing. he had to sell it to get a 4wd just so he can go to the lake!! haha
  19. Jul 25, 2012 at 3:06 PM
    670
    670 0~ 0~ 0~
    Pacific Northfresh/P-Town
    2011 OFFROAD MGM
    Icons ext travel all around with dakars springs, TRD exhaust
  20. Jul 25, 2012 at 3:16 PM
    xyourlocaldjx
    xyourlocaldjx Well-Known Member
    my buddy has a 29foot rinker... He pulls it with a titan no problem, but our trick is...
    As he steers the boat onto the trailer... as soon as he hits the front bumper stop on the trailer we haul ass out lol. so it's basically the boat hitting the trailer moving the truck fwd and gassing it out. the boat aint going no where, trust me! lol
    Gravel, sand whatever.. it works =)
