Boat Ramps
Discussion in 'Towing' started by hwy17cruzer, Jul 29, 2010.
  1. Jul 29, 2010 at 6:53 PM
    hwy17cruzer
    hwy17cruzer [OP] Member
    Santa Cruz, Ca.
    06 Taco 2.7
    swaybar
    Tacoma Forum; I'm driving a 06 2.7 ltr access cab 5 sp with 82k miles. I tow a 2600 lb sail boat no problemo! The only issue I'd like to resolve is the boat ramp drama. It seems geared a bit high for the ramp tug. I'm thinking of lowering the rear end gear ratio to resolve this. This truck will do 70 in 3rd gear, so there's plenty room for some sacrifice at the high end. And I rarely used 5th gear anyway. Advice?
  2. Jul 29, 2010 at 7:35 PM
    hwy17cruzer
    Santa Cruz, Ca.
    06 Taco 2.7
    swaybar
    On my 06 2.7 ltr 5 spd I have drama getting up a steep boat ramp with a 2600 lb boat & trailer. Other wise this truck is the BOM! I wanna lower rear end ratio to resolve this Advice?
  3. Jul 29, 2010 at 7:41 PM
    Ese Loco
    Ese Loco Taco Man Sam
    Vero Beach, FL / Tampa, FL
    2009 DC TRD Off-Road 4x4 V6 6-speed
    Legal Florida Tint all-around, 1.5" add-a-leaf, bilstein 5100 rear shocks, Light Racing Coilovers, Removed secondary air filter, K&N airfilter, Amsoil 100% synthetic motor oil, Amsoil synthetic severe gear in rear differential, Differential breather mod, Painted rims and logo's black, amsoil oil filter
    re-gearing sounds like what your leaning towards, its gona cost a pretty penny but if thats what you really want it should be work it.
    ever consider upgrading to a 4.0 V6?
  4. Jul 29, 2010 at 7:46 PM
    jandrews
    '09 FourDubDee TRD OR
    Define "drama"? If you're losing traction there's a million factors in play...is the boat ramp wet (probably)? Is is dirt or asphalt? Quality tires? 4 wheel drive?
    If the vehicle just seems to be struggling, well, yeah, that's power and gear ratios may be able to help you solve that.
  5. Jul 29, 2010 at 7:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    DO you have a 5 lug Tacoma?
  6. Jul 29, 2010 at 8:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What? Re gearing should only cost about $500.00 for everything. Much cheaper than geting a V6... :confused:
  7. Jul 29, 2010 at 8:16 PM
    hwy17cruzer
    Santa Cruz, Ca.
    06 Taco 2.7
    swaybar
    I did consider a v6 4wd pathfinder, but I love this 2.7 Taco. ( I bought new) it does everything well except the ramp. I drove a stick for 30 years, well schooled, no slipage of the rear wheels. Just gotta rev it a little too high a little too long and feather the clutch too long to get 'er done. (It's more about the resistance of the water on the trailer than weight) At 82 k the last ramp pull did her clutch in. I'm thinkin' it's cheaper to swap out the rear diff than to up grade to a new ride. I see alot of off road posts about this but none on the street trucks. I'm hoping it can be done easily for 3-6 hundred bucks.....
  8. Jul 29, 2010 at 8:19 PM
    hwy17cruzer
    Santa Cruz, Ca.
    06 Taco 2.7
    swaybar
    yeah, wheels are 5 lug, if that's what you mean...
  9. Jul 31, 2010 at 12:46 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    How often do you use the boat? If you re-gear the engine will be running at a higher rpm all the time. Things will wear out faster and your mileage will plummet. Is the cost of a clutch worth the cost of running lower gears all the time?
    I'd just get the clutch if it were me and use a heavier pressure plate.
  10. Aug 1, 2010 at 8:26 AM
    hwy17cruzer
    Santa Cruz, Ca.
    06 Taco 2.7
    swaybar
    I'm currently researching just what gear ratio is optimal. Bottom line is, clutch is shot and I need a new one. I will heed your advice and opt for the heaver duty pressure plate. The towing issue is a real counundrum. I commute 100 miles a day in the truck. Mostly on curvy mountain roads with speed limits of 50mph (Zealously enforced!) I do have a stretch of 15 miles of freeway where I can hit 80mph. So my Tacoma runs at 2.5 k rpm at 25 mph in 2nd gear. 2.5k rpm at 45 mph in 3rd gear, 2.5k rpm at 60 mph in 4th gear, 5th gear I rarely use and don't remember rpm data. The truck feels best at about 2k rpm. I'd really like to get 1st gear down to a real granny gear and use 2nd-5th as driving gears. At least that's the plan. Any advice is appreciated. THx in advance to this forum it's already been very helpful.
  11. Aug 11, 2010 at 3:17 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    You might come out cheaper to sell your truck and buy another one with 4WD, this will give you the lo gear that you are looking for.
  12. May 15, 2011 at 9:13 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    70 in 3rd gear concerns me
  13. May 16, 2011 at 5:57 AM
    52419 Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    if you do regaer i recomend randys ring and pinion dad has his stuff done there and i do to and ill swear by it, great service freindly and fair!
