Boat towing
Discussion in 'Towing' started by Maysville06, Jan 24, 2012.
  1. Dec 3, 2014 at 7:40 PM
    Narwhal
    Narwhal Member
    Andrew
    bilstein 5100, method wheels
    Does anyone have experience pulling a 26ft boat that weighs about 5500 lbs wet and loaded?
    Im concerned about the large size and also pulling it out of the water.
    I have the 2014 4x4 with tow package.
  2. Dec 4, 2014 at 10:03 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    If you read the docs concerning the Tow options from Toyota you will find that the port installed set up as listed in the first post is only rated at 3500# max. and usually has a 4 prong plug.
    If you have the full factory tow package you will have the 7 pin connector, a class IV hitch, a Tranny cooler (if an auto trans), and engine oil cooler, and factory sway control (some added computer stuff)...also bigger battery and alternator. The Factory Tow package allows up to 6400# towing with the proper weight distribution hitch. You also have to deduct any weight that is in the truck...people / gear etc from the tow rating, so at 5500# you would be pushing the max with a Tow Package. As to if you can tow it....sure! The question is can you safely tow it....with that weight the trailer should have good brakes on all axles and a distribution type hitch to be safe.
  3. Dec 5, 2014 at 6:58 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    4 Low - no sweat as long as you have traction.
  4. Dec 5, 2014 at 7:48 AM
    Narwhal
    Narwhal Member
    Andrew
    Thanks for the response guys...
    I think im going to have to pass on the boat even though its an awesome deal.
    From what Ive read and heard so far it will work, but it will tear up my truck over time.
  5. Mar 4, 2015 at 7:02 PM
    Triple D
    Triple D Well-Known Member
    Florida
    07 4x4 Double Cab Sport Pack.
    I have the tow package and frequently tow a 17' whaler and 19' Mako. Never have had any issues but definitely recommend staying in 4th and keeping the speed around 55-60 mph with the bigger, heavier boats. Any faster and you'll be getting around 8-9mpg.
  6. Apr 24, 2015 at 12:27 PM
    onebadtaco
    onebadtaco Active Member
    Taylor
    Jefferson, GA
    14 DCSB TRD Sport 4x4
    20% tint, AFE Pro Dry S air filter, widow visors, trimmed front mud flaps, 3" predator running boards, husky weatherbeaters
    How do you like the Mako? I am looking at getting a Mako 18 lts this weekend.
  7. Apr 25, 2015 at 8:56 AM
    Triple D
    Florida
    Mako is a great boat but it depends what year you're looking at. Ours is a 1994 (191 model) with the "deep V" hull and is a very versatile boat. Ocean fishing in 3-5' seas is doable if you're experienced. Also, time and time again we run it to the "backcountry" spots here in South Florida and find we can get in very very shallow water. I've seen the newer ones and don't think the quality matches what Mako used to put out....you couldn't buy our boat at Bass Pro Shops back in the day. Good luck!
  8. Apr 28, 2015 at 3:27 PM
    Bstnsportsfan
    Bstnsportsfan Member
    SE Florida
    2012 DCSB SR5
    I agree with Triple D. The classic makos aren't the same as the Bass Pro Makos. For the money of a new mako, lots of ther options to consider especially slightly used.
