Body armor advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Davis1891, Dec 6, 2020.
  1. Dec 6, 2020 at 8:21 AM
    Davis1891
    Davis1891 [OP] Well-Known Member
    Alberta
    2020 OR DBSB
    None yet
    Hi everyone.
    Ive stepped up my off-road experience a bit this year and it's time for a few upgrades, and I'm looking at armor. Went out wheeling yesterday for over some dips and definitely kissed the ground several times. It was my most technical outing yet
    Ive got a 2020 OR, and I'd say that I'm probably looking at moderate trails and useage. I'm not looking at doing extreme rock climbing, but lots of mud, trails, ruts, dips, hills...you know, that kind of stuff.
    I haven't lifted my truck, I will later on, but I'd rather get this out of the way first.
    Front bumper first and then rock sliders, and I've already got those figured out, but it's the skid plates I'm curious on.
    Moneys a bit tight, so it'll be a work in progress, a little bit here and there so my 2 questions are...
    Which skid plates are absolutely essential to begin with?
    Aluminum or steel for my needs?
    This is also my daily driver so I need that balance of protection vs weight and gas mileage
  2. Dec 6, 2020 at 8:25 AM
    Hammerma
    Hammerma Well-Known Member
    2019 trd sport
    Put a 2x4 under the accelerator pedal.
    allenn and trktwo like this.
  3. Dec 6, 2020 at 8:33 AM
    angerbot
    angerbot Well-Known Member
    Aluminum is probably a good fit for your usecase, but it is more expensive so take that into account. I'd start with just the front skid, I have coverage all the way to the t-case and honestly the front is the one that sees the most hits. RCI makes a good set that integrate nicely together and you can add them one at a time. A word of advice if you go that direction though is spend the money and time to get an exhaust reroute first so that the rear skid plate can be flat, I get hung up a lot there.
  4. Dec 6, 2020 at 8:59 AM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    I would do the sliders and at least the engine skid plate before the bumper. The transmission skid plate is fairly inexpensive and may be a consideration at the same time as the engine skid. Look around for used as well, you can get some great deals, I was able to purchase a DV8 Offroad steel engine skid for $50.
  5. Dec 6, 2020 at 9:12 AM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    Agree with this order, sliders then skids, then bumper. I have full aluminum skids, yes the have taken hits and work well. I went with aluminum to mitigate weight and because I don’t intend to bash my truck into the terrain. A comment, if you will eventually get a full set of skids pick a single vendor now. Otherwise you’ll probably have interference when you add the other skids.
  6. Dec 6, 2020 at 9:19 AM
    EchoDeltaSierra
    EchoDeltaSierra Well-Known Member
    Georgetown, TX
    2020 TRD Off-Road
    Nitro 4.88 gears OME suspension ST/Maxx 255/85R16s
    +1 to this. On my 2020 TRD-PR build, I did sliders, skids, and bumpers. That's the proper order of progression (IMHO). Also, I did have steel full skids on my 2010 Tacoma and switched to aluminum on my 2020. No regrets, they've taken hits well, and are hella easier to be removed for maintenance.
    Davis1891[OP] likes this.
  7. Dec 6, 2020 at 9:26 AM
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
    The TRD aluminum front skid plate provides protection at the alignment tabs. The RCI front skid doesn't. Thus I went with the TRD front plate, RCI transmission and transfer case skids, all aluminum. I enlarged the front mounting slots of the RCI transmission plate so that the TRD plate can be mounted flushed with it, lessened the clearance loss.
  8. Dec 6, 2020 at 9:36 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Skids and sliders first. Steel (3/16) not aluminum. Only used the winch (and thus bumper) a few times. This past year I had to winch up to a flat spot so I could turn around. This was while “he who will not be named” was pointing to the map saying “it says its a blue trail”. That “blue” trail had dragons teeth that would have stopped Rommel.
  9. Dec 6, 2020 at 9:40 AM
    Davis1891
    Alberta
    2020 OR DBSB
    None yet
    Thanks. Will definitely go this route
    smw62891 likes this.
  10. Dec 6, 2020 at 10:30 AM
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    Great advice!
  11. Dec 10, 2020 at 10:35 PM
    Ebeast
    Ebeast Well-Known Member
    2017 Super White Tacoma TRD Offroad
    i would say rock sliders always first. After for skid plates, since you already have a steel one in front can take some hits, i would say definitely go for a transmission skid plate next. RCI is my go to on that.
