Body Armor Rock Steps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dxpsman, Jan 5, 2014.
  1. Jun 19, 2014 at 10:54 AM
    #141
    oldswab
    oldswab Well-Known Member
    Jonathan
    Kansas
    14 dbl cab TRD OR 6MT
    Elevated likes this.
  2. Jun 19, 2014 at 11:45 AM
    #142
    Jhunter
    Jhunter Well-Known Member
    Atlanta
    Black '14 TRD DCSB
    Just getting started
    Kingston - I put the brackets on the truck first (hand tight). I then set the rails on two automotive jack stands and adjusted height as needed. I then bolted the bracket to the step (hand tight). Before I tightened up all the bolts, I checked the height and alignment. I put BLUE Loctite on every bolt just in case. I will tell you that getting the bolts from the bracket to the step tight are a real pain. Maybe I just didn't have the right wrench. 1 hour max and you're done.
  3. Jun 27, 2014 at 9:16 AM
    #143
    BBell
    BBell Well-Known Member
    B
    Northwest
    13 Tacoma TX
    2013 Tacoma TX 4.0 6 Speed Manual Volant CAI and air scoop Volant throttle body spacer DigiFit Weathertech Kevlar Seat Covers - Grey Interior LEDs Fab Fours PreRunner Bumper Body Armor Rock Sliders Painted radiator Rigid Industries 3x3 D2's DTL lighting kit Rigid Grill and 20" SLR2 light bar Plasti- badges Plasti- front grille surround Plasti- rear bumper MATT black rear taillights Night Raider rear LED light bar :D
    I went redneck with my "jack" stands. Also used blue loc tite. Got one bolt hand tight, switched to the other end. And then worked my way back just to hand tight. Then went back with the socket wrench. Torqued to 3/4 and then a last round to full.
    Also took an hour.
  4. Jun 27, 2014 at 9:28 AM
    #144
    mikevee
    mikevee Well-Known Member
    Socal
    14 prerunner trd offroad
  5. Jun 27, 2014 at 6:30 PM
    #145
    2wdTRD
    2wdTRD Well-Known Member
    Alabama
    Prerunner TRD Sport
    TRD Exhaust,
    I have had them on my truck for about 3,000 miles now I have not had one issue with them except one side was not tapped for the bolts when I got them. I love how they curve inward so I don't have to step over them when getting out. One other issue during installation was the most forward mounting bracket has 2 holes and came with two bolts but the factory mounting on my 2013 only had one hole but they still hold firm, they weigh about 45 pounds a piece so get a friend to help you hold them while you mount them. In my opinion they are worth every penny I love them over the factory ones. I weigh 210lbs and put my full weight on them regularly and they don't even flex.
    Sorry for the crappy pictures just went outside and took them!
  6. Jun 27, 2014 at 6:39 PM
    #146
    TheTacoAdventurer
    TheTacoAdventurer Well-Known Member
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
    I had the same issue as you with the single hole for the front bracket. Haven't had any issues with them without that bolt. They've been on for probably 2000 miles and through some light off roading.
  7. Jun 28, 2014 at 10:44 AM
    #147
    HandOfGod
    HandOfGod Well-Known Member
    Tacoma TRD 4x4
    Stock
    So these will fit a 2014 double cab? About to pull the trigger, like the look and great anti ding guards!
  8. Jun 28, 2014 at 10:52 AM
    #148
    2wdTRD
    Alabama
    Prerunner TRD Sport
    TRD Exhaust,
    Yes they will fit.
  9. Jun 28, 2014 at 11:01 AM
    #149
    RevoTaco
    RevoTaco Well-Known Member
    SoCal
    Sold - 08 6SP 4x4 AC TRD Off-Road
    My issue is that with them appearing to just be plate metal, that they'll bend like tin foil as soon as you actually use them like a rock rail with the full weight of the truck pressing on an adjacent rock...
  10. Jun 30, 2014 at 4:28 PM
    #150
    BBell
    B
    Northwest
    13 Tacoma TX
    They are solid the step itself is a little thin to bear heavy weight of a rock or the truck BUT, once again, these are body mounted steps, not frame. You wouldn't want to use these to the same extreme as true rock sliders without risking body damage.
  11. Jul 1, 2014 at 11:26 AM
    #151
    oldswab
    Jonathan
    Kansas
    ^this. They're nice looking, "lower profile", non-tubular, non-chromed out steps, at an excellent price point. They hide the ugly underside nicely, as a bonus. They go on pretty easy--it's a one man job with a bucket on the opposite end of you.
    And that's it...
    After I get it paid off, I might slap some rock-sliders on and do some more heavy 'roading with my Taco, but these are not those.
  12. Jul 1, 2014 at 12:42 PM
    #152
    ME OFF Rd
    ME OFF Rd Well-Known Member
    Jim
    Maine
    2013 TRD Off Road Edition
    - Digital Fit WeatherTechs - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's with ToyTec 2" AAL
  13. Jul 1, 2014 at 12:54 PM
    #153
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    I really liked these about 1-2 years ago. Was looking at steps since my wife was preggers at the time.
    Was actually home visiting, drove out to their address .... and.... closed. Not really an unusual time either, and no truck out front to check it out. Glad there's finally a review.
    Might ditch the Avid tube steps for these.
  14. Jul 1, 2014 at 12:54 PM
    #154
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Whenever a company tells you that they are using 5mm steel in their products that's the first red flag that should go up. Cheap thin foreign steel that's bolted to the body of the truck may look cool, but has the same functionality as any other tube step on the market.
  15. Jul 1, 2014 at 9:11 PM
    #155
    HandOfGod
    Tacoma TRD 4x4
    Stock
    Pulled the trigger since I don't really go off-roading and these will make great anti-door-dingers. Came to $278.02 shipped with tax on Amazon. Estimated delivery: July 31, 2014 - Oct. 8, 2014 So hopefully I will get them sooner and shipped in good shape.
  16. Jul 2, 2014 at 6:31 AM
    #156
    Jhunter
    Atlanta
    Black '14 TRD DCSB
    These are not 'Sliders' and I don't think anyone is advertising them as a serious Off-Road option. I bought them as an 'style' option vs the old traditional 'Tube Steps'. I get tons of compliments to the newer look. Plenty strong enough to stand on when washing the roof line.
  17. Jul 19, 2014 at 9:34 PM
    #157
    RileyLAFD
    RileyLAFD Well-Known Member
    Riley
    City of Angels
    '14 DCLB Magnetic Grey
    I guess I've got to start this very soon....
    These would be nice, if mounted to frame instead. I think I will buy and then make a plate to amount to frame and weld the two together. (Plate and steps)
  18. Jul 20, 2014 at 4:31 AM
    #158
    TheTacoAdventurer
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
    If you do that, please let me know how it goes. I was thinking of having someone do the same.
  19. Jul 20, 2014 at 5:57 AM
    #159
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    Why on earth do they not make these for the access cab?!
    Id love to have them for the sole purpose of aiding in keeping rocks from being slung up on my door from my tires...
    Plus the truck sits a bit higher so steps for the wife would be nice
  20. Jul 20, 2014 at 6:22 AM
    #160
    Creole Knight
    Creole Knight Man's got to know his limitations.
    Ulysses
    So. Cal
    05 Super White PreRunner
    gear shift knob and other things.
    Keeping my eye on this one.
