Body Armor Sport Rack??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09DBLCAB09, Feb 25, 2013.
  1. Feb 25, 2013 at 9:44 AM
    09DBLCAB09
    09DBLCAB09 [OP] Well-Known Member
    Does anyone have this for their truck? It's only $350... I just wanted some reviews before pulling the trigger
    ChadsPride and ODNAREM like this.
  2. Feb 25, 2013 at 9:50 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I kinda like it.
    ChadsPride likes this.
  3. Feb 25, 2013 at 9:51 AM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Meh. It mounts to the bed rail system, not much strength there.
  4. Feb 25, 2013 at 9:56 AM
    Pugga
    Massachusetts
    From their website:
    The Sport Rack mounts to the OEM track system on the Tacoma plus two legs bolt to the bed at with the two body bolts this adds the needed strength to the bed.
    The back bolts are only helping to offset the cantilever so they don't need to be overly strong. You'd have to pull the track system straight up for it to fail.
  5. Feb 25, 2013 at 9:59 AM
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    How much is the cab basket? It says requires PN 5129 Cab Basket.
  6. Feb 25, 2013 at 9:59 AM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    I think there was a thread on it a while back when it first came out...
    I think it looks pretty good. I think the tube diameter is a littler larger than I would personally prefer (although, who really gives a shit).
    I think the main concern is about its weight capacity. Because it mounts to the bed rail system, you can't really use it for much. The bed rail system is only meant to hold so much, and because the weight and center of gravity is distributed over the cab, you cant use it much more than for lights. However, if looks is what you are going for, they why not?! Like you said, it is only $350..
    If you do get it make sure to put up a review!
  7. Feb 25, 2013 at 10:02 AM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    I'd like to see it mounted onto the cab personally. I think it would look a lot better if it was all the way forward. You could use it as a spare tire basket among other things. Maybe we should have someone built that prototype..
  8. Feb 25, 2013 at 10:08 AM
    thelivestone
    thelivestone Well-Known Member
    paul
    Cape Canaveral, FL
    2017 Crewmax
    stock for now
    I think it looks pretty good. just would be concerned with the weight over the cab, other than that.... I approve.
  9. Feb 25, 2013 at 10:13 AM
    06sr5prerunner
    06sr5prerunner DILIGAF
    luis
    midland tx
    2006 sr5 prerunner
    bhlm paint wheels duplicolor plasti dip white grill. billies 5100. bf goodrich at 285's 75 16 black valence led corner lights expedition bed rack by anb fabrication spidertrax wheel spacers rotopax fuel tanks 4gal mounted on bed rack quickfist mounts for shovel. ddm hid kit 35watt 6000k hi/low beam
    i have my bed rack off of my bed rails and definitely you can put some weight. i dont know about bed rail specs and all that but i have easily put about 350 lbs or more on my bed rack thats off my bed rails. have my hi lift and used to have my spare 285/75r16 strapped to it.
  10. Feb 25, 2013 at 10:20 AM
    MIAtaco
    MIAtaco Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
    where did you find this?
  11. May 7, 2013 at 5:41 PM
    abnranger
    abnranger Member
    Curtis
    Va
    05 Tocoma, SE V6
    just mounted it (Body Armor Sports Rack) tonight after work...heavier than I thought and stronger. The design is well thought out, the two parts that mount to the side rails pull back on the basket and the straight up mount behind the cab helps with stability, support and balance. The weight is 250 max as per Body Armor guidance, I would feel no worries putting 3-350. The only thing that surfaced that was unexpected was the floor bed mounts...I had to cut/ "customize" the raised portion near holes to set flat on bed. Next project is adding the Body Armor front bumper after I get a set of new tires... anybody mount the bumper ?
  12. May 7, 2013 at 6:17 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    built my own:) Are you satisfied with the rack? get some pics up!!
  13. May 7, 2013 at 6:33 PM
    abnranger
    abnranger Member
    Curtis
    Va
    05 Tocoma, SE V6
  14. May 7, 2013 at 6:36 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    I would like it to mount to the cab mounts personally.
  15. May 7, 2013 at 6:39 PM
    snowgod06
    Rob
    06 Access Cab
    mines bolted through the bed rail caps, through the bed, with backing plates. 4 bolts per side, had about 450# on her so far.
  16. May 7, 2013 at 6:39 PM
    abnranger
    abnranger Member
    Curtis
    Va
    05 Tocoma, SE V6
    I like the Body Armor rack and the way it looks, yours is cool batman, nice job...did Alfred help you ?
  17. May 7, 2013 at 11:17 PM
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    I'm interested. Do you think a ARB tent would fit up there and handle 350lbs of body weight plus tent weight?
  18. May 22, 2015 at 7:19 AM
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    Bump. Anyone else have one of these or have any reviews? It's tickling my interest.
    "The basket part number is 5129 and is a required element of the SportRack system. The length of the SportRack is long enough to handle bike racks, kayaks even a roof top tent."
  19. May 23, 2015 at 2:02 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Interesting in what its capable of!Very cool!
  20. May 23, 2015 at 7:54 PM
    Rc taco
    Rc taco I Need a Tow
    Tempe az
    '16 Rubicon Unlimited
    All of them
    I order one long ago that what obviously used when advertised new. They didn't send any hardware nor instructions and the company was less than pleasant dealing with. I ended up craigslisting it for like $100
