BODY ARMOR SUGGESTIONS 03 TRD
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyTaco1992, Nov 16, 2010.
  1. Nov 16, 2010 at 11:01 AM
    ToyTaco1992
    ToyTaco1992 [OP] Member
    Land of Entrapment
    2003 Tacoma TRD
    All Stock As of now.........
    I have been having issues finding Plate style bumpers for my 2003 They dont seem to make many for my year??
    Plate style bumper, rear bumper, Tire/gascan mount on the rear bumper.
    Bolt on rock sliders?
    RECCOMENDATIONSS PLEASE!!!!
  2. Nov 16, 2010 at 11:05 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
  3. Nov 16, 2010 at 11:11 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    you've posted two extremely common questions...use the search
  4. Nov 16, 2010 at 5:38 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Quick answer....
    CBI makes great plate style front and rear bumpers. rear swingout and sliders.
    Shrockworks makes a great plate style front bumper too.
    ARB front bumper.
  5. Nov 16, 2010 at 8:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  6. Nov 16, 2010 at 11:05 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Be careful of the tire/gas can mount for the rear bumper, as if you're serious about offroading, you'll end up bending your frame due to the extra weight, so you'll need to either box the frame or reinforce it. There's a few places that sell the frame reinforcement.
    If you're just going to looks, its probably not quite as necessary, but might still be a good idea.
    As far as bolt on sliders go, there are a few options, but will require either drilling into the frame, or bending your cab above the frame. If you look at the frame, you'll see there really isn't much space at all to wrap a load bearing attachment to the frame. Most bolt ons seem to take the direction of drilling from what I've seen.
  7. Nov 17, 2010 at 11:39 AM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    wow that looks great!
