body help
Discussion in 'Detailing' started by lotsoftoys, Oct 7, 2011.
  1. Oct 7, 2011 at 5:46 PM
    lotsoftoys
    lotsoftoys [OP] pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    so anybody a body man? i have a small spot behind a rear tire where it looks like the clearcoat is coming off... is there a body man trick to stop or slow this process? or do i have to have it all sanded down and completely redone?
  2. Oct 8, 2011 at 1:06 PM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Not an expert but could it be the protectant film that is applied at factory is coming off, sure would be cheaper to replace the film than paint.
  3. Oct 9, 2011 at 4:06 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    A pic would really help... If it is peeling clear, there's only one way to fix it, and that is to sand the panel down, and re-paint/clear. Try and get a pic up, so I can get a better look at it.
  4. Oct 10, 2011 at 3:11 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    yeah im sure its the clear coming up. its hard to get a pic of it becaus eof the white paint. is there clear coat touch up? id be down to try that?
  5. Oct 11, 2011 at 6:32 PM
    Dadic 78
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    You can buy clear coat in a touch-up stick, or even a rattle-can. It's not the best in a rattle-can, and to be honest, either method will look shoddy... But at least it will stop peeling. Just wet-sand the edge of the peeling clear, use some 1500 grit, and take it easy, so you don't burn through the white base coat, otherwise you'll have to replace that as well.
  6. Oct 11, 2011 at 6:40 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    thank u sir^ repped
