Body lift bumper space
Discussion in '2nd Gen. Tacomas (2005-2015)' started by machotaco2012, May 27, 2016.
  1. May 27, 2016 at 10:16 AM
    machotaco2012
    machotaco2012 [OP] Well-Known Member
    •3” front blocks •2” steel rear blocks •1.25" spidertrax spacers for clearance •285/70/17 (33's) Ko2's •20% tint
    Will i have a gap between my bumper if i put a 1-2 inch body lift on my 2012 tacoma?
  2. May 27, 2016 at 10:17 AM
    Large
    Large Red
    between your bumper and what?
  3. May 27, 2016 at 10:18 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    yes, unless you raise bumper. 1" you can stretch the stock one some and make it look right, 2" = gap unless you modify
  4. May 27, 2016 at 10:19 AM
    mightytacoman
    Kel
    4.5L 1grfe
    bumper is mostly on frame, so it isnt raised with the rest of the truck in a body lift
  5. May 27, 2016 at 10:19 AM
    Large
    Large Red
    alright .. that didn't answer my question
  6. May 27, 2016 at 10:21 AM
    mightytacoman
    Kel
    4.5L 1grfe
    a gap between bumper and headlights/grill or bumper and taillights/ tailgate
  7. May 27, 2016 at 10:25 AM
    Large
    Large Red
    where did the op say that?
  8. May 27, 2016 at 10:27 AM
    mightytacoman
    Kel
    4.5L 1grfe
    Figured its implied since he cant actually have a gap in the bumper itself. Not about to have a dick measuring contest with you Large. Just trying to help the guy out.
  9. May 27, 2016 at 10:30 AM
    Large
    Large Red
    I think you're wrong. The plastic bumper cover (also called the bumper sometimes) is attached to the body, not the frame. If he had a plate bumper, there would be a gap between the grill and the plate bumper since it mounts to the frame.
    edit: I could be wrong, I would take advice on here with a grain of salt.
  10. May 27, 2016 at 10:35 AM
    Large
    Large Red
  11. May 27, 2016 at 10:35 AM
    mightytacoman
    Kel
    4.5L 1grfe
    The rear bumper is attached to the frame. I honestly dont remember how a stock front bumper cover is attached but I do remember other members having a gap after the bodylift. Plus i've done a body lift on my tacoma and had a gap that required modification.
  12. May 27, 2016 at 10:36 AM
    Large
    Large Red
    Rear bumper yes, there will be a gap for sure. Front bumper no. Either way I always recommend against a BL if you can.
  13. May 27, 2016 at 10:38 AM
    mightytacoman
    Kel
    4.5L 1grfe
    I recommend against going over a 1" body lift, and IF you're gonna do it, upgrade to grade 8 hardware
  14. May 27, 2016 at 10:45 AM
    machotaco2012
    Im pretty sure he added a new bumper bracket that modified the height. My only concern is if im going to have to add a new bracket anyway i could just go ahead and do a bigger body lift. i already got a 3 inch suspension lift.
  15. Mar 21, 2017 at 1:13 PM
    SPIN Offroad
    SPIN Offroad Well-Known Member
    SPIN
    Asheville NC
    Black 2014 DCSB TRD Off-Road "TAKEESHA"
    3" toytec suspension lift/1" Toytec body lift, In-channel AVS vent shades, tinted front windows, OEM color matched grill surround, plastidipped front badge & rear bumper, Debadged emblems + All LED interior+vanity& tag lights. Third tail light TRD black matte overlay, Aftermarket 6K HID projector headlights, Smittybilt D-shackle in receiver hitch slot, 17" FUEL Vapor wheels 285/70/17 Nitto Trail Grapplers, Weathertech floorliners w/TRD OFFROAD decals, 3" NFAB textured nerf bars, DEPO black tail lights. black on black perforated leather Clazzio seat covers with custom TRD headrests. TO BE CONTINUED...
    Thinking sbout a 1inch body lift too. With aftermarket front bumper there will be a gap, no gap on front with stock. Rear there will be a gap however big your body lift is off the frame unless u Ninja-Rig it (weld fabricate new brackets)
  16. Mar 21, 2017 at 1:20 PM
    twhalm
    twhalm Well-Known Member
    Denver, CO
    2015 TRD/OR Manual, OME , Dual battery
    If you are going to weld stuff to make your body lift fit...you should probably reconsider some life choices that brought you to that point.
    ace96 likes this.
  17. Mar 21, 2017 at 1:26 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    as others have said, no gap on the front, 1" gap on the back. 1" body lifts are great setups to help get a little more tire clearance and other things.
    SPIN Offroad likes this.
  18. Mar 21, 2017 at 2:10 PM
    SPIN Offroad
    SPIN
    Asheville NC
    Hey man body lifts arent for everybody -or this thread apparently! Some people dont wanna trim to fit bigger tires either. Different strokes...whatever anybody else does or doesnt wanna do to their truck is no sweat off my balls, but why people intentionally bash whatever thread is about is strange to me. I get it most people dont like the idea of a body lift, I fig a 1" body lift is minimal , and adding that to a 3" suspension lift might be what SOME people are seriously considering . Would i have regrets if i did it... Who knows? But would I want to hear what others that actually have it say something INFORMATIVE whether it be good or bad...YES!
  19. May 21, 2018 at 11:58 PM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    What do people do to fit the front bumper reinforcement after a 2 inch body lift. Its pushed against the front bumper cover and doesnt fit correctly. Does anyone sell an adapter bracket to bring the front bumper reinforcement up an inch or two?
  20. May 22, 2018 at 9:27 AM
    jmarquez808
    Jess
    Hawaii
    Anybody sell custom brackets to raise my reinforcement bar 2 inches doesnt fit with this body lift.
